Old 11-11-2010, 02:33 PM   #1
venice , California
96 Suburban Towing Capacity
I have a 96 Suburban 1500 LS 2WD, 5.7. What is the most Airstream I can reasonably tow? I've been looking at a 78 Overlander 27'...is that too much trailer? I'm new to trailers and towing. Thanks for responding.
dougtown is offline   Reply With Quote
Old 11-11-2010, 02:39 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
My 2000 Yukon XL will tow about 7,200. There's a web site that lists the specs on vehicles. I don't have it marked. Somebody will post your answer.
Old 11-11-2010, 02:50 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
That truck most likely has a 3.42 rear axle. If possible have it changed to a 3.73. Have an additional transmission cooler installed and have the oil lines installed so the new cooler is installed AFTER the radiator. Place the new cooler forward of the AC condenser. Everyone will want to install the oil lines for the cooler before the radiator but don't let them. You want the tarns cooled not heated by the radiator.
On mine I remove the transmission cooling completely from the radiator and run the trans at 160 degrees but it is not worth that now on a 96. The only reason they originally put the cooling in the radiator was for quick winter warm up.
2004 Excursion 4x4
Old 11-11-2010, 02:51 PM   #4
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
We tow our '83 Sovereign 31' with our 1995 Sub K1500 5.7 with no problems whatsoever. I run it in 3rd gear (no OD) at about 2600 to 2700 rpm, which gives about 60-62mph. We did a two week trip from KS to VA and back and averaged 10mpg.
Alsupp is offline   Reply With Quote
Towing Capacity Formula LloydN Tow Vehicles 24 01-30-2009 02:59 PM
How can you tell the towing capacity? Dreamnair Tow Vehicles 4 01-04-2009 07:40 AM
Towing Capacity streamlean Argosy Motorhomes 19 09-10-2007 07:38 PM
How much towing capacity do I need? altamont Tow Vehicles 19 02-25-2007 01:16 PM
Towing Capacity hwpeddie Member Introductions 11 05-28-2006 05:19 PM
