Old 07-07-2010, 09:30 PM   #1
1960 28' Ambassador
Colorado Springs , Colorado
95 Dodge Dakota
We have a 28 ft. 1960 Ambassador Airstream that is in South Dakota and I need to get it to Colorado Springs CO (600 miles) sometime in the near future, so we can work on it to fix up.
Can a 95 Dodge Dakota Sport club cab 2WD with a 318 V8 motor, tow this safely? According to the dodge dealer it is capabile of towing 6450 lbs. I am questioning this, has anyone towed a setup similar to this?
The weight of the AS on the title is 4580 lbs.
I plan to install a class III hitch with a 800 lb weight distribution connection and sway control.
Bill
lisabill is offline   Reply With Quote
Old 07-08-2010, 06:56 AM   #2
richinny's Avatar
2011 34' Classic
this thread should help:
http://www.airforums.com/forums/f463...cle-64453.html
check the sticker on the driver's door jamb. it will list the ratings.
verify that the tires on the truck now, match or exceed the tires listed on the tag.
verify the receiver specifications. i don't think you'll find one for that truck rated more than 7,500 lbs with weight distribution. if it has one already on it. inspect it and the frame for rust and cracks.
verify the gear ratio (3.55 or 3.92?)
there are a few other posts on dakotas in the forum. use the google search feature on the tool bar on top of the page and search for "95 dodge dakota".
i have an 88 and a 94. post if you have more questions :-)
Ricky
95 Dodge Dakota as a tow vehicle? Perfetto Tow Vehicles 8 05-13-2010 08:29 PM
HELP! 07 Dodge Dakota brake control wiring. SANTINO MARC Brakes & Brake Controllers 0 05-24-2009 08:22 PM
Dodge Dakota - TV? jmichaelr Tow Vehicles 7 07-08-2008 08:07 PM
dodge dakota towing 27' airmac Tow Vehicles 25 12-17-2007 07:25 PM
Dodge Dakota + Safari 23' Widgeon Tow Vehicles 6 11-20-2005 02:50 PM
