Old 07-13-2012, 08:15 PM   #1
1976 Argosy 26
Blandon , Pennsylvania
'94 full size Blazer
Does anyone pull with a "1994"ish full size Blazer/Yukon? Have a chance to grab one in really great shape... I have a 1976 Argosy 26...
Thanks for your thoughts...
lpgasguy is offline   Reply With Quote
Old 07-13-2012, 08:27 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thewheelbase is too short, t will not make a good tow vehicle. By te time you get it equipped to adequately tow your trailer, you could have used the extra time and money needed to purchase a more suitable vehicle.
Old 07-13-2012, 10:05 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings lpgasguy!
I agree with Overlander63 . . . . While the K5 Blazer may have a sufficient trailer tow rating, I would avoid it as a tow vehicle for anything longer than 20-feet and its stability would be questionable even at that length. Based on my 1995 K1500 Silverado, I wouldn't recommend it from the power standpoint . . . the pre-VORTEC 5.7 Liter lacks power for travel in mountains or hilly country (I had the 3.73 differentials and heavy duty trailer tow package). Another factor that oftens comes into play with K5 Blazers is the presence of aftermarket wheel/tire combinations that are larger than stock and intended for off-road use.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-14-2012, 06:40 AM   #4
1976 Argosy 26
How does everyone feel about the ford expedition with the 5.4. ?
Old 07-14-2012, 07:18 AM   #5
Well Preserved
1993 21' Sovereign
That would be much better than the Blazer. I have the 5.4 in my truck, with the 3.73 gears. That extra length makes it more stable.
Old 07-14-2012, 08:37 AM   #6
r carl's Avatar
Lin , Ne
Yup, I pulled my 30' Avion for 2yrs. If you can deal with only 200hp it will pull your lighter weight airstream ok. Yes it has a short wheelbase, but it also has a short overhang.
Old 07-14-2012, 10:11 AM   #7
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
This talk is making me nervous about towing my 22' Argosy with my 98 Tahoe 350at...
Savage68 is offline   Reply With Quote
Old 07-14-2012, 10:50 AM   #8
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Savage68!
Your Tahoe is more closely related to the Suburban than the K5 Blazer. The K5 Blazer is somthing like a Tahoe that is cut off behind the second row of seats. A 1998 Tahoe with the proper trailer towing package shouldn't have any problems witn an Argosy 22.
Kevin
Kevin D. Allen
AIR #827
Old 07-14-2012, 07:26 PM   #9
1976 Argosy 26
I guess perspective is everything... I pull the Argosy with a Ford Ranger now with a 4.0. I am used to the lack of power, but it gets the old girl from A to B...
Thanks for all your input!
Old 07-22-2012, 07:42 AM   #10
1976 Argosy 26
Went with a 2006 Expedition. Pulls great!! Thanks for the advice.
