Old 01-19-2011, 06:33 AM   #1
Akron , Ohio
93 chevy G10 van v8 305
I own a 93 Chevy G10 van v8 305, how much trailer can I pull with that?
Ideally I would like something 27' but I don't know what the best size would be.
I've tried to find info on this but being a 93, chevy does't post it.
CampNoob is offline   Reply With Quote
Old 01-19-2011, 07:47 AM   #2
RichardT's Avatar
Need to know axle ratio and if it has towing package with trans cooler etc... But from what I see online 4500 pounds sounds typical and 5000 possible with correct options. Just type in g10 tow rating and you will find generic info...
The following is for a 1999 and should be the about the same.
G10 Van 4.3 V-6 A 4,500 (b,e,f,i)
G10 Van 5.0 V-8 A 5,000 (a,e,f,i)
G10 Van 5.7 V-8 A 6,500 (b,e,f,i)
RichardT is offline   Reply With Quote
Old 01-20-2011, 06:45 AM   #3
Akron , Ohio
Thanks for the info, I'm guessing most 16 ft campers would be ok but 20' or more may be pushing it.
Not really sure what these things weigh.
Old 01-20-2011, 06:50 PM   #4
JFScheck's Avatar
Rockville , Maryland
Images: 33
I think 20' would be ok - depends on the tongue weight and if you are using weight distro or not...
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-21-2011, 04:21 AM   #5
Akron , Ohio
I'm also learning the newer trailers seem to be lighter than the older ones. that changes my perception of what a 'deal' is. When I'm ready to buy, if ever, I may be worth the extra money to get newer for the savings in weight.
Old 01-21-2011, 07:10 AM   #6
SteveH's Avatar
Common Sense , Texas
Not sure about all models, but usually the reverse is true...the older trailers are lighter and more aerodynamic than the newer. I know that's true for the 25' and above.
Regards,
Steve
Old 01-21-2011, 07:33 PM   #7
JFScheck's Avatar
Images: 33
I agree, I think the newer trailers usually weigh more than the older models...
In Between Units
Airstream On Order
**I Love U.S.A.**
Old 01-21-2011, 08:47 PM   #8
Sudbury , Ontario
My 93 Chev G10 van with the 350 v8 pulls my 30 foot sailboat with no problem - boat and trailer weight is around 6500 lbs. If I recall correctly my van has the 3.50 rear end. The info posted by RichardT looks reasonable to me.
Alumination is offline   Reply With Quote
Vintage tow vehicle hampstead38 Tow Vehicles 309 06-23-2015 11:08 AM
