Old 06-30-2006, 10:26 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
90's F-250 questions
Does anyone have a manual for a 97 F250 or similiar (older body style) that they could scan or copy for me? I just got the truck, but no books came with it.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-30-2006, 10:33 AM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Alan, I have a '97 F150 and a '98 F150. If I'm not mistaken, the owner's manual is for BOTH weight classes. You live close enough that you could come help me put the belly pan back on tomorrow and we could could make a run to Office Depot for a copy.
Seriously, I'll check tonight when I get home and let you know.
www.nesa.org
Air No. 6427
Old 06-30-2006, 10:34 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Alan,
I have one when I get the chance I will copy it for you. Also check around in the salvage yards, quite often you can get on there. I have been given them before when buying other odds and ends.
Aaron
WBCCI #XXXX AIR #2495
Old 06-30-2006, 03:23 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You can try the ford website. It may take a little digging but I know they have owners manuals and towing guides in there. I have electronic copies for my 04 F-250 on my laptop.
https://myford.fordvehicles.com
Michelle TAC MT-0
Sarah, Snowball
Old 06-30-2006, 05:16 PM   #5
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
I know I have mine somewhere that I could make copies of for you. Anything you need info on right away for your 97 Powerstroke?
Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 06-30-2006, 05:33 PM   #6
HHP
HHP's Avatar
Yucca Valley , California
Right now, you can get a set on Ebey for 8 bucks...
1997 Ford F-150 F-250 Owners Manual Set F150 F250
http://cgi.ebay.com/ebaymotors/1997-...spagenameZWDVW
BTW, ask the seller if he has extra sets if you can't get this one....
HHP is offline   Reply With Quote
Old 06-30-2006, 07:32 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Michelle,
I went thru the rigamarole of signing up and then it tells me I am not authorized to access that page ...go figure I love pdf manuals, especially the good ones that you can search and link to stuff in them. Eventually I plan on buying the Adobe software to convert a bunch of my print manuals. I have about a dozen that I would love to get done.
Aaron
Old 06-30-2006, 09:44 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks all, I will be glad to help put that belly pan back on, if you need me Jim just email me,,, no problem. I will check the site and Ebay as well. I don;t even know how much oil to put in when I change it.
8 quarts?
AIR #005
retired!
Old 06-30-2006, 09:50 PM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
8 quarts?
The Ford site says the manual for my yr is unavailable.....so if anyone comes up with one I would appreciate a scan or whatever is convenient. Thanks guys!
AIR #005
retired!
Old 07-01-2006, 06:35 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
8 quarts?
Alan,
Mine is a 96 and takes 14 quarts on an oil change. Also find out what brand of oil the PO was using. And whatever you do don't mix brands if you add oil in between oil changes. FWIW I use Rotella on all of our diesel stuff around here. We buy it by the pallet For the PSD I use 3 gallons and 2 quarts. We usually buy a whole skid of gallons, then a couple of cases of quarts for the odd numbers and to add between changes. We have 7 diesel vehicles on site here. I will work on the scanning this week for you.
Aaron
Old 07-01-2006, 06:48 AM   #11
2002 27' Safari
Images: 14
Aaron, I couldn't have stated the same facts any better. we have 5 different diesel powered vehicles at home, but all are maintaned the same. Jeff
AIR: 649
TAC: CA-40
Old 07-01-2006, 10:44 AM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by wahoonc
Alan,
Mine is a 96 and takes 14 quarts on an oil change. Also find out what brand of oil the PO was using."
thanks! Unfortunately the po is not able to be contacted, and I had to add a quart yesterday. I used Rotella and figure I will change the whole thing this week, Wally world has the motorcraft filters on the shelf.
I did lube the steering points and greased every hinge and so on.
One other newbie truck guy question. Mine has the towing pkg with trans cooler and all, the rear bumper being that sold steel massive item with holes in it for tow ball. Can I use that with a ball for my Sovereign or do I stll need a receiver hitch?
Sure seems strong enough, but want to be safe and sure.
AIR #005
retired!
Old 07-01-2006, 11:22 AM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Alan,
I use either the Fleet Pride filters or the Napa Gold. Motorcraft should be okay if you can find them. Got a picture of the back bumper? It may be a Class V rated...mine is, however I wanted to be able to use the sway control feature and the adjustability of my normal hitch head. So I found a receiver that would fit. I wanted a Class V receiver but unfortunately no one makes one that will fit my 96 with the 10" deep drop cowbow bumper. Putnam used to and still lists one but the replacement number hitch doesn't extend far enough out. So I ended up with a Class IV rated at 800/8000 as a straight hitch and 1200/12000 as a WDH.
Aaron
Old 07-01-2006, 11:35 AM   #14
Keymar , Maryland
Sorry to hear that. I used it too get my owners manual before I actually recieved my truck.
I like the searchable feature as well. I will see if I can get it.
Michelle TAC MT-0
Sarah, Snowball
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Questions about a 2000 Land Yacht jberndt Mechanics Corner - Engines, Transmission & More... 3 01-08-2003 10:12 AM
Questions with regards to A/S Storage dbmarshall Our Community 12 11-01-2002 06:34 AM
Prospective AS owner with questions jborning Our Community 0 10-14-2002 08:50 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
