Old 07-01-2006, 11:51 AM   #15
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I logged in again and it will only let me look at the 04 manuals. If you had to enter the VIN did you sub a zero for an "O" or the other way around?
Michelle TAC MT-0
Sarah, Snowball
Old 07-01-2006, 12:22 PM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Good question...but no O or 0 in my VIN It goes to the page but says I am not authorized to view this document. I am going to shoot an email to Ford support and whine about it. I do have the paper manual, just prefer the pdf versions.
Aaron
WBCCI #XXXX AIR #2495
Old 07-01-2006, 12:28 PM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Here in where the bumper bolts to the frame.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-01-2006, 12:34 PM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
here is a back end shot and a couple of my Sovereign's interior, we have ripped out and cleaned the flooring, getting ready to fix a rot spot and paint the trim with primer. I am doing the front lower walls in aluminum.
ID:	23049   Click image for larger version
ID:	23051   Click image for larger version
AIR #005
retired!
Old 07-01-2006, 12:34 PM   #19
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Alan,
Does the bumper have a sticker/stamping on it giving a rating? Mine has bigger brackets than that. I would seriously consider a receiver. Also how does the AS hitch height line up with bumper height? You want it as level as possible for towing.
Aaron
Old 07-01-2006, 12:40 PM   #20
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I will check those things. Bigger brackets huh? Mut be a true monster metal work. I can go with a receiver, and I have not tried to mount the hitch from the AS yet as I still am looking for the light connector to go to the trailer, one did not come with it.
AIR #005
retired!
Old 07-01-2006, 12:45 PM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
You will have to build your own cable. The AS end should be 7 pin round with round pins, you can get them at a good agri supply or big truck supply, the truck end when you hook it up should be the 7 pin blade RV style. Cable will be availble at the same places. You can buy the truck end stuff from Ford and it will be a plug and play. Mine has taps into the factory wiring harness at the rear of the truck. I have a terminal block on mine because I have a total of 4 different plug ports. One for a 5'ver RV, one for a Gooseneck, one for a conventional RV and a 4 pin flat...I be WIRED
Aaron
Old 07-01-2006, 03:55 PM   #22
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I got the owners manual from Ford -- downloaded it. Thanks the link worked.
You say the truck end of the cable should be the blade-pin kind?The truck has the round connector but I have a converter from my moho. I can't wire a round connector to the end?
AIR #005
retired!
Old 07-01-2006, 04:32 PM   #23
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Glad the link worked...you could use the round pin if that is what you already have. My trailer came with the RV blade plug as do most if not all TT's these days, so I figured go ahead and configure the truck for that. I have the round pin in the bed, because that is what all our goosenecks have. All fifth wheels I have ever seen have the RV style plug, so I put one of those in there while I was at it. I probably could make an adaptor ( I have yet to find one ready made) but it was about as easy to add the extra outlet. I have not found a standard name for the round pin plug, some people call them aircraft plugs, others round 7 pin. I do know they are used on the heavier trucks and trailers. Personally I think they are a better plug than the bladed plug. But are hard to find.
Aaron
Old 07-01-2006, 05:23 PM   #24
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
is this the connector...Northern Tool has it
Alan,
That is the RV 7 pin flat blade connector. The round pin that fits the front of the AS looks like this one. It came from Champion Trailers
Aaron
Old 07-01-2006, 08:33 PM   #25
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Alan, both my '97 and '98 F150's have the 7-pin flat. The function of each pin is imprinted on the connector cover. I bought a cable at NAPA here in McDonough that was 7-pin flat on one end, and had a pig-tail on the other. A 7-pin round hood came with it for the other end that you wire youself for your particular trailer pin out.
The fun part was figuring out what all the trailer end wires were used for. See the link below. On my camper, I had to match the colors inside the trailer to the chart, then wire the hood accordingly.
Good luck with it.
http://www.airstream.com/airstream/p...lug1966-81.pdf
www.nesa.org
Air No. 6427
Old 07-06-2006, 11:36 AM   #26
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I found both plugs the large aircraft and smaller blade for the truck end. Now a question on the weight distributing bars....the AS has the chains and those weight distribution stirrup things, and I have the receiver end with the two balls on it. I guess all I need is the bars.
How do I go about figuring out what bars to get? I might find a name on the hitch but haven't yet. Need a photo to help? I can post if so.
I also see that my steel truck bumper does not have a hole big enough for the 2 5/16 ball to thread thru, so I may have to get a receiver installed or someone with a torch to cut that hole. Still trying to see if this bumper will suffice to tow without the receiver mount added.
AIR #005
retired!
Old 07-06-2006, 02:57 PM   #27
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
here is photo of what I now have....tell me what I need...two bars? What kind and weight...saw some at Northern Tool will they work...." duh"
AIR #005
retired!
Old 07-06-2006, 07:54 PM   #28
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I put my umbilical together and plugged it in, no lights on the trailer.....is a 12v battery needed in the trailer ro the signal and brake lights to work???...if not I will be chasing wires to see what is up. I'm 99.9% sure I wired the umbilical right.
AIR #005
retired!
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Questions about a 2000 Land Yacht jberndt Mechanics Corner - Engines, Transmission & More... 3 01-08-2003 10:12 AM
Questions with regards to A/S Storage dbmarshall Our Community 12 11-01-2002 06:34 AM
Prospective AS owner with questions jborning Our Community 0 10-14-2002 08:50 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
