Old 03-23-2008, 04:57 PM   #1
LucyPepper
Profile:  Currently Looking...
Salt Lake City , Utah
Wink 85 Ford F250 diesel pull 27ft. Ambassador??
Hi!
We just purchased an ol' 85 Ford F250 diesel to pull the AS trailer we are still in the market for..looking at around 27ft..Will this size be ok? New to diesel engines, will there be more of a "pull" on the engine, or would we be able to keep a constant speed?? Is this to big?? We got the diesel so that we would have more options. What do you think?? We may also we converting to burn vegetable oil. Not sure yet how it will effect the towing..Know anything about this??
Thanks!
LucyP
LucyPepper is offline   Reply With Quote
Old 03-23-2008, 05:04 PM   #2
2airishuman
2airishuman's Avatar
Profile:
can a 85 ford tow stuff?
sure.
much depends on the stuff.
to avoid wasting money, FIND the trailer first.
decide what trailer length, what floor plan, what era and so on first.
then select or modify the tv to meet the trailer needs...
for example you might decide a bambi or old small unit fit your needs perfectly...
for this the 85 ford is unnecessary.
OR u might opt for a nearly new, never used newer unit...
in which case the 85 ford might be inadequate.
there are LOTS of issues with old vehicles and old trailers...
but get the trailer sorted out FIRST.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-23-2008, 05:20 PM   #3
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
Having owned that truck, and towed not only that length trailer, but also a 31' trailer, the answer is,it depends.
If your new truck is an automatic, it will be seriously slow, as top end is about 60 mph, unless you get an over/underdrive kit (a couple thousand extra). It will pull any trailer of these sizes through about 1981 or so, after that, a newer trailer owner will have to add their input.
'08 F250/350 vs 2500/3500 diesel 4x4(?) crew cab Roamin' Cat Tow Vehicles 31 03-21-2008 07:03 AM
Ford F250 Brake Controller Harness for trade thecatsandi Towing, Tow Vehicles & Hitches 6 08-31-2007 10:25 PM
Anybody pull with stock Ford 7.3L Powerstroke diesel? JBCrete2 Tow Vehicles 15 08-08-2007 12:29 AM
Can I pull a 1980 Ford Courier Pickup??? Snadi Airstream Motorhome Forums 3 04-19-2006 03:04 PM
5.9L Jeep to pull 29' Ambassador? MiamiMike Our Community 5 03-14-2003 02:35 PM
