Old 10-24-2011, 02:48 PM   #1
Tabasco's Avatar
1964 24' Tradewind
Stillwater , Oklahoma
72 Chevelle Wagon towing a 64 Tradewind?
is that even possible?
I have unexpectedly (long story) found myself in possesion of a 1972 Chevelle station wagon, it has the original 350 motor w a 2 barrel carb.
I'm obviously no mechanic. Would my grocery getter even have the power to pull my AS?
Any input/opinions would be appreciated.
Thanks!
Tabasco is offline   Reply With Quote
Old 10-24-2011, 03:08 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Tabasco!
Thanks!
A definitive answer isn't easy without more information, but the mid-size 1972 Chevelle could be able to tow your Tradewind. Since your Chevelle has a 2-barrel carburetor, it is unlikely that it has the options for towing but most of that can be addressed through upgrades. I suspect that you would be looking at the following upgrades as a minimum:
  • Four barrel intake manifold and carburetor.
  • Dual Exhaust system.
  • Heavy-duty replacement radiator with either 3-or-4-row core.
  • Heavy-duty transmission fluid cooler.
  • Differential gear change . . . likely has either 2.70 or 3.07 ratio from the factory . . . a 3.73 ro 4.10 ratio would be desirable for towing.
Fortunately, GM began installing hardened valve seat for unleaded fuel in 1971 so you should be safe in that area which is a big savings . . . my '65 Dodge required nearly $1,200 in head work to permit the safe use of unleaded fuel when I decided I wanted to use it as a tow vehicle. My family had a 1971 Buick Sportwagon special ordered new in 1971 with the trailer towing package and that included the following (which would have been a near twin to your Chevelle wagon):
  • 350 cubic inch V8 with four-barrel Quadrajet.
  • dual exhaust
  • 3.23 differential gearing
  • heavy duty alternator
  • heavy duty radiator
  • heavy duty wheels with H78-14 bias-ply belted tires
  • heavy duty shock absorbers
  • heavy duty springs
  • trailer towing wiring harness
Our RV dealer added a heavy duty transmission fluid cooler and the custom welded Reese class III receiver hitch. While the trailer that we had at the time wasn't an Airstream, it weighed about the same amount as your Tradewind and the Sportwagon was a wonderful tow vehicle.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-24-2011, 03:30 PM   #3
Tabasco's Avatar
1964 24' Tradewind
Shew. You're a wealth of information, Kevin. Definitely addressed some things that I wouldnt have even thought of.
Thank You!
Old 10-25-2011, 08:49 AM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
In addition:
The cooling and electrical systems get heavy workouts while towing that not many consider when looking at an old car as TV. Disposing of excess heat, and tracing down sub-optimal volt/amp readings, is part and parcel of making an old car worthy of towing. New wiring harnesses are a good idea for firewall forward components.
Suspension and body rubber is another.
It's more money, time and labor than most expect. The DIY-oriented are always a step ahead.
slowmover is online now   Reply With Quote
Dodge Power Wagon mojo Tow Vehicles 15 10-11-2011 05:43 AM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Towing with a TDI VW Jetta PA BAMBI II Tow Vehicles 102 07-21-2011 09:27 AM
Towing with a 1996 Roadmaster wagon Globie64 Tow Vehicles 7 03-30-2011 11:56 PM
