Old 03-24-2015, 12:50 PM   #85
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
My daily drivers are an old V6 Pathfinder and an old 88 cubic inch Harley. Both get better mileage than the Tundra.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-24-2015, 04:42 PM   #86
OldVwHunters's Avatar
1969 18' Caravel
Northwest , Missouri
Images: 35
Originally Posted by m.hony View Post
I haven't seen very many regular cab Tundras. That thing oughta haul and have plenty of towing capacity.
Not many regular cab short beds out there, and 2013 was the end of the line. My Buddy and I put in a 36 hour day going out to get the Tundra, and that was the closest one in over a year of searching. I like the 20 inch shorter length, plus it's 400 to 600 pounds lighter than the rest of the Tundra's. Missouri gives a 180 day window on sales tax to buy a vehicle after you sell your old one, luckily I got the Tundra bought on day 180.
OldVwHunters is offline   Reply With Quote
Old 03-24-2015, 07:39 PM   #87
m.hony's Avatar
2013 30' Classic
Thus the 400-600 lb greater towing capacity-
TAC #MS-10
Airforums #70955
Old 03-29-2015, 09:27 AM   #88
TDOW's Avatar
1966 22' Safari
Madison , Wisconsin
My new to me Tundra
Just purchased last week...
2010 with 18,000 miles. Thinking about changing out the tires already as the P.O. had - all terrains - on 20" rims installed, and I find them noisy.
Do most of you have 18" rims?
Karen
TDOW is offline   Reply With Quote
Old 03-29-2015, 11:37 AM   #89
1969 18' Caravel
Images: 35
Mine has a pretty fresh set of 18" Cooper Disoverer tires, thanks to either the previous owner or the dealership. They are a little rough starting out, but after they get warmed up roll pretty smooth, and quite. If it were me I'd have gone with Yokohama, or Michelin.
Old 03-29-2015, 11:43 AM   #90
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I've got stock aluminum 18" with 255/70x18 Michelins. Other option is 18" 275/65x18. I would expect higher loadings on the 275 tires but my 255 Michelins are rated at 2465lbs at 44psi which together is 4930lbs which is over the GAWR of 3900lbs of the rear axle. I would expect slightly better gas mileage with the 255 tires.
Check the load ratings on the your current tires on the sidewalls.
Kelvin
Old 03-29-2015, 02:55 PM   #91
m.hony's Avatar
2013 30' Classic
Mine has 20's.
TAC #MS-10
Airforums #70955
Old 03-30-2015, 05:00 PM   #92
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by OldVwHunters View Post
Glad I made the switch even though I had to drive to Montrose Colorado to get the truck.
Did you get it at Turner? We bought our Tundra there in '07 and paid below invoice. Of course, we are a lot closer to Montrose than you are.
Gene
Gene
Old 03-31-2015, 11:01 AM   #93
1969 18' Caravel
Images: 35
Gene
Yes, I got My Truck Fred at Turner, I thought they were very nice to deal with, and coming from me (one that normally groups car dealers alongside shady lawyers, politicians, and pimps) that means a lot. I would highly recommend them. I dealt mostly with Ed who I thought did a great job.
Old 03-31-2015, 12:45 PM   #94
KJRitchie's Avatar
2008 25' Classic
Checked out Turner. They only have 5 Tundras in stock. Do they sell that well or has Toyota reduced production. Same issue in Springfield, MO. This is supposed to be Toyotathon month but no one has much Tundra stock. Maybe something new coming in 2016 other than a slight cosmetic change?
Kelvin
Old 03-31-2015, 05:46 PM   #95
gpt
2014 25' FB Flying Cloud
sequim , Washington
i sold both of my 4x4 Tundra's for the same reason, rotten fuel mileage and bumping right up against the tow limits of the truck. most happy with my overkill F350 diesel with headroom to spare and much improved fuel efficiency.
gpt is offline   Reply With Quote
Old 04-06-2015, 11:57 AM   #96
Master of Universe
Gene's Avatar
Montrose is not that large a town, so 5 Tundras on a dealer lot is plenty. They, like all dealers, can get new ones (and probably used ones) from other dealers. I dealt with the sales manager in '06 and '07 (2 different Toyotas) and that worked well, but he has retired.
Gene
Gene
Old 04-08-2015, 01:38 PM   #97
1969 18' Caravel
Images: 35
Turner is not a mega dealer that has to drive you around in a golf cart. They didn't need 500 Tundra's in stock, just needed the one that I wanted.
Old 04-08-2015, 02:00 PM   #98
1995 25' Excella
York , South Carolina
I'm still on the fence about getting a Tundra to replace my current 18-20 mpg Tacoma. I talked to a guy yesterday who claimed to get only 13 mpg on his Tundra empty, when just a week earlier I talked to someone that claimed to get 18 mpg pulling a big boat in the mountains. If you have a 5.7 Tundra please enlighten me with your own real world results.
Hello! My husband and I pull a 25ft Airstream with a 2014 Tundra with the 5.7 engine. This is our 2nd Tundra with the bigger engine. As crazy as it sounds, we have never checked the MPG! We figure, what big engine really gets good gas mileage! It tows very well and we feel very safe in it! If I had to guess the tow mileage... I would probably say 13/14 mpg, towing. That's with the fresh water tank full or there about and both propane tanks full! We love our Tundra! Hope this helps! ???? Beth
Beth
It's not what you look at that matters, it's what you see.
Henry David Thoreau
WBCCI #5659 Unit 22 Region 3 w/ sandlapper
Seven Brook is offline   Reply With Quote
