Old 03-29-2015, 07:25 PM   #43
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
Get the 4X4, it's worth it! Like a previous post, if you don't get it and get stuck...
Ford F-350 crew cab 4X4 diesel, 25' Jack Bauer edition AS
sparkymark is offline   Reply With Quote
Old 03-29-2015, 08:59 PM   #44
Francisco , Indiana
We went from a 4 wheel drive to a 2 wheel. We haven't had any problems since getting this truck.
Albeit we don't boon dock. We do have a limited slip rear end.
We didn't like the 4 wheel drive because of the added height getting in and out of the truck. It wasn't a lot but still very noticeable. We are pleased and have no regrets in out choice of a tow vehicle.
Hickory
hickory is offline   Reply With Quote
Old 03-29-2015, 08:59 PM   #45
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Isuzusweet View Post
True point as if you order a 4WD without either you actually have a 2WD truck. That being said there are pros and cons to both.
A limited slip is a have and forget item as it will automatically engage and disengage should wheel slip occur. The con is that at speed on ice going up a slight incline the axle may lock up and the truck will start to swerve to one side or the other. It does take a gentle and smart approach to the gas pedal on very slippery conditions at speeds with a limited slip. They have also been manufactured for years, are pretty bulletproof and will disengage to allow for turns without damaging gears.
A locker takes a lot more thinking about when to engage or not to engage as once locked the rear axle will not tolerant any speed difference between the two wheels on that axle without possibly damaging the pumpkin gears. A locker is also a lot more expensive $1,500 CDN versus $400.00 CDN for the Ford version. Also they will be more to maintain as they do have, in the Ford case an electrical motor actuator. ARB makes beautiful lockers that are air actuated.
I personally love lockers and had them on my Toyota Landcruiser but they are more applicable IMHO to true off road situations and rely on the user being smart about how to use them.
Cheers
Tony
This is soooo not true. A G80 Eaton locker is $400, and unlocks (and won't lock ) above 20 mph. And is totally automatic....no switches...just locks when there is a 100rpm difference between right and left rear wheel. They are idiot proof and a true locker, not a LS.
-Rich-
Old 03-29-2015, 11:23 PM   #46
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Exactly what I tried to say back in post#29. Limited slip,AKA limited grip. Better to have a 2whl drive with G80.
George
gandttimes is offline   Reply With Quote
Old 03-30-2015, 07:38 AM   #47
dznf0g's Avatar
Oswego , Illinois
George
Yup.
-Rich-
Want to buy diesel 4x4 for $5,000 or less! WaterSpryt On The Road... 4 07-21-2004 03:53 PM
Toyota, 4x4, V-8, Auto, Tundra pick-up Fogducker Tow Vehicles 13 01-28-2004 07:48 PM
4x4 Class 3 MH outclimbs A/S! Astrodokk Airstream Motorhome Forums 5 11-02-2003 04:53 PM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
