Old 04-10-2018, 05:17 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
4WD and 2WD Towing Question
The manual of my current 4x4 truck says it has a stated tow capacity of 6,100 lbs. A 2x4 truck of the same model is around 6,300 lbs. Does that mean if i am towing in 2x4 mode I can tow 6,300 lbs?
tjwoods1 is offline   Reply With Quote
Old 04-10-2018, 05:32 PM   #2
dznf0g's Avatar
Oswego , Illinois
No, it means that a 2wd weighs about 200 pounds less that a 4wd
-Rich-
Old 04-10-2018, 05:40 PM   #3
2016 28' International
Sioux Falls , SD
It is typical for a 4x4 to have less capacity due to added drivetrain weight.
You are restricted to 6100lbs.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-10-2018, 05:53 PM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
It means that a 4X4 truck weighs 200 lb more than a 2X4 truck because of the extra weight of the transfer case and drive shafts etc, which are sprung weights. You can only carry what the sticker on your door says (legally)!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-13-2018, 11:33 AM   #5
Vintage Kin
Fort Worth , Texas
Nothing “legal” about it. It’s the recommendation of a private party. Like your neighbor down the street.
Old 04-13-2018, 11:38 AM   #6
Vintage Kin
Fort Worth , Texas
You can tow whatever you’re willing to try. The “tow rating” doesn’t mean much. Leaves out how that decision is formed. We can build an 1800-lb trailer your truck could never get above 5-mph.
At best it’s ballpark.
Does your TT weigh 6,300-lbs?. Well, the shape of an AS is such it takes 20% less HP to pull. So let’s be realistic (in the way those ratings are realistic) and state your AS weighs only 5000-lbs.
Cool, huh?
MPG towing with 4wd Toyota Tundra GatorDave Tow Vehicles 32 07-01-2017 05:25 PM
2WD vs 4WD atheness Towing, Tow Vehicles & Hitches 57 11-19-2014 09:23 PM
NEED REAL WORLD DATA: 2WD vs 4WD mpg... westcoastas Full-Timing, Winter Living & Workamping 10 08-20-2014 09:49 PM
2WD diesel vs. 4WD gas - new twist on question mtbguy On The Road... 27 02-11-2014 09:42 AM
2WD or 4WD lvcat2004 Tow Vehicles 11 07-15-2009 05:06 PM
