Old 04-13-2007, 04:21 PM   #15
Cracker's Avatar
Pittsfield , Maine
Originally Posted by coriolis1
This could also be caused by cranking the torsion arms in order to raise the front end of the truck. Doing this and then not having the front end realigned will cause premature wear on the outer tire edges.
Nope - I haven't done that and, for the record, the truck was just recently realigned by a very reputable commercial truck shop. They're the ones who pointed out that the "cupping" problem is common with the 3500 4 x 4 trucks.
Cracker
Cracker is offline   Reply With Quote
Old 04-13-2007, 09:13 PM   #16
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Some Basics...
The TRANSFER CASE behind the transmission is what engages/dis-engages the front drive shaft that supplies power to the front axle and also changes the gear ratio, i.e. 2WD,4WD-HI RANGE,4WD-LO RANGE.
The DIFFERENTIALS, front or rear,allow the axle shafts to turn at different speeds to allow the wheels to turn at different speeds while cornering. Example; when making a left turn, the right side wheels must be able to turn faster than the left side wheels.
The LOCKING HUBS, whether AUTOMATIC or MANUAL allow the wheels to rotate freely from the axles they are attached to, reducing drag and wear on the front axle.
BTW, preloading (cranking up) the torsion bars is a BAD idea, it prevents the suspension from moving through out it's full range of motion, resulting in a harsher ride. There are other ways to lift a vehicle.
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 04-13-2007, 10:08 PM   #17
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Duh! Forgot about that one. The little switch makes me forget about all te workings.
Michelle TAC MT-0
Sarah, Snowball
Old 04-13-2007, 11:40 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by thecatsandi
On my F-250 I have auto /engage setting on the hub. I cycle them at aleast once a week..
I was under the impression that just the hubs released and the power was still going to the front drive shaft at all times.
Hi, Yes you do have Auto and Manual settings on the hubs, In Auto mode the hubs are vacuum controlled to engage and dissengage them. This also works in conjunction with the transfer case as you shift in and out of 4X4 modes engages and dissengages the front differential at the same time. So, out of 4X4 with hubs on Auto, Your front drive shaft has no power to it and the front wheels are free wheeling.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-13-2007, 11:56 PM   #19
Salem , Oregon
Images: 18
If the hubs did not release it would make going around corners on hard surfaces nearly impossible. There is no front differential in the Ford Trucks.
All time four wheel drive is a different animal.
Hi, whether you have four wheel drive or all wheel drive you have a front and rear differential; And in some all wheel drive vehicles there is a third differential in the transfer case. As front and rear differentials have spider gears to allow one axle to turn at a different rate than the opposite side, the third differential in the transfer case also has spider gears to allow one drive shaft to turn at a different rate than the other one.
2005 Safari 25-B
Old 04-14-2007, 12:55 AM   #20
DFord79's Avatar
Yakima , Washington
You guys sure made this MORE complicated than it need be. Ford 3/4 , 1 ton, etc. have either auto lock or manual get out in the mud hubs that work the same way as they did 40 years ago. A transfer case the engages the from diveshaft that goes to the front differential that drives the axels. GM has a system more akin to a front wheet drive car. They are not as truck like as the Ford system. But they have more moveing parts and boots to replace over the years. Half tons are different. ...But I am only talking about trucks..not half tons. Ford has the same system of transfer case,,,front differential and manual hubs availible as they have since they came out with 4X4 in the 50's. AND ITS THE STRONGEST BY THE WAY....BUT ITS OLD SCHOOL. The auto lock hubs tend to fail if dirty....manual never fail.....but you have to get dirty. Its up to you.
DFord79 is offline   Reply With Quote
Old 04-14-2007, 07:29 AM   #21
Cracker's Avatar
Pittsfield , Maine
In summary, it sounds to me like dis-engaging 4 WD - be it Ford or GM - takes the whole mechanism out of the drive train if you have automatic hubs - which most of us probably do. That said, there's no "drag" issue robbing fuel.
Cracker
Old 04-14-2007, 08:00 AM   #22
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Correct. The only "drag" then is the increased weight of the 4WD equipment, usually a couple hundred pounds plus.
Old 04-14-2007, 08:12 AM   #23
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I noticed on my burb that it does not appear to be the old pig iron in the front, so hopefully it's a bit less weight, not that getting 11mpg towing, you'd really know the difference!
Old 04-14-2007, 06:33 PM   #24
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
MPG wit 4x4
The Dodge trucks now have synthetic lube in the differentials, t-case and transmission...evidently to minimize the effects of the hub-less design they've gone to. I have a t-case lever much like I've been used to on all previous trucks but no longer get to get out and turn the hubs. The whole front driveshaft, differential and axle shafts are turning with the front wheels, they're just not being "driven" until I move the lever.
Another forum had posted results of several guys testing the induced drag from a fully "part time" system (manual hubs, t-case lever) and a late-model with the "shift on the fly" hub-less design...the results were negligible.
Considering the frontal area most trucks, weight of entire rig with trailer, the minimal effect of the front drive system, regardless of type, is far offset by the benefit of having it when needed...and I have needed it many times.
I've further learned one of the reasons Dodge did away with the hubs was that the u-joints at the wheels (in the knuckle) would "dry up" due to lack of exercising...I never had any problems with them but I have heard of some that did.
B25guy is offline   Reply With Quote
Old 04-18-2007, 06:42 PM   #25
DFord79's Avatar
Yakima , Washington
Ford's 4x4 system add's approximately 450 lbs to a truck. So fuel mileage will suffer with 4 wheel drive from the weight even when not engaged and the added drag...yes...drag...remember you set about 3 inches higher and that mean more air passing under the rig...means more drag.
Old 04-18-2007, 08:42 PM   #26
So how about streamlining the underside of the truck?
Michelle TAC MT-0
Sarah, Snowball
Old 04-18-2007, 09:51 PM   #27
2005 22' Interstate
Afton , Virginia
That's a pretty good idea, Michelle about streamlining the underside of the truck. However, I do not know of any US built truck, car, or SUV that has that feature. It would reduce the drag caused by all the stuff hanging down, now wouldn't it?
Only thing is, a friend of mine had a Land Rover which had the underside enclosed. It must have been manufactured that way. He cursed the day he bought it because the drive train was in there. He dropped a universal joint and had to have it transported to a Rover garage to get it fixed.
regards
herrgirdner is offline   Reply With Quote
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
Question about a buying decision! escapeez Our Community 7 08-15-2002 03:29 AM
Tire sizing question casarodante Tires 5 07-02-2002 11:19 PM
