08-04-2010, 08:01 AM
2001 19' Bambi
Dallas
4-Runner 19' Bambi combo
New to this forum, and have a question. My tow vehicle is a 2010 4-Runner Trail Edition, and has a big old 6 cylinder motor. It's rated to tow 5000 lbs, which is under the Bambi's loaded weight. But, I'm a little worried whether it can pull hard enough to trverse mountains. Next summer it's going to make a road trip to Alaska, and there are some huge peaks between Texas and Alaska. Does any one have any experiance or tips about towing with a 6 cylinder?
08-04-2010, 09:11 AM
2007 25' Safari FB SE
Eureka Springs
, Arkansas
I have a '02 Tacoma with V-6, 5 speed. I tow my tractor and equpment (about 6k lbs). It's adequate and stable, but more power would be welcome on hills.
I also have a '97 4Runner with V-6, 5 speed we bought new. It now has 254K miles and is a mechanical wonder! No major repairs ever and still looks new.
If you accept that one doesn't need to go 70 MPH up long grades, I expect you'll be fine.
I'd try your rig before buying another TV.
08-04-2010, 09:36 AM
2001 19' Bambi
Dallas
Thanks Bob, the shake down run is going to be this week end- heading up to Broken Bow OK for a quick camp out. I can't wait to see how the 4-Runner does.
08-04-2010, 10:02 AM
2012 25' Flying Cloud
Battle Lake
We also use a small trailer. My first concern is loading of the trailer. You indicated the Bambi weighs over 5000 lbs loaded. I believe the maximum total weight for the Bambi is 4500 lbs (I am not sure that is correct), so the trailer seems to be overloaded. So first, deal with getting the proper load on the Bambi, and very importantly balanced so that the front or the back of the trailer is not overloaded. Overload the back and you may have a serious sway condition, overload the front and you may have trouble using your weight distribution hitch to properly transfer weight to the front steering axle of the truck.
More importantly than the power of the little truck is its stability, and its payload capacity. It has a high center of gravity, live axle, and soft tires, as well as a relatively short wheelbase, none of which are ideal for towing stability. You must also keep the load in/on the 4-Runner itself (including trailer tongue weight, passengers, gear) within payload specifications for the truck.
So you must get these loads within specs. Then you need to find a (rare) shop who can properly install a good weight distribution hitch for you, and (even more rare) properly set it up for you. Then there is the problem of inadequate factory hitch receivers on many vehicles (and probably yours) that cannot withstand the forces of a weight distribution hitch. Again, you must find a shop who truly understands these hitches, and can reinforce or replace it as needed.
I have been dealing with these close margins on our own vehicles. The simple solution that so many have done is to simply go out and get much bigger truck than you might need. That's not the direction I'm going, but will work as well. You still have to keep the trailer load with its own limit, or you may suffer trailer tire, axle, and/or frame failures.
Doug
08-04-2010, 02:06 PM
2005 19' Safari
GLENDALE
, AZ
I have not driven a 4Runner, but if you plan on driving in the mountains, I'd seriously consider a larger TV. There are some long downgrades in the Rockies where even our Tundra (with the big V8) would not hold the speed down without riding the brakes a little. I suspect that you would have difficulty with your 4Runner on these grades.
I imagine that you might be fine on the flats, but when you hit the mountains, I think you will be reconsidering a larger vehicle. Before you head out to Alaska, I'd see if you can find a friend or relative with a full size pickup or Suburban-type vehicle to test drive towing your trailer. That might change your mind.
Just another opinion...
08-04-2010, 02:49 PM
Battle Lake
And a good opinion, Phoenix. I worry much more about coming down a mountain road than going up.
Am not sure how a heavier tow vehicle can slow the speed down though, or necessarily have better braking.
08-04-2010, 02:55 PM
2004 28' Safari
Broomfield
I tow a 28 ft Safari with a 07 2500 Burb. I live in Denver and go to the mountains almost every weekend. I would not tow a 19 with a 4-Runner. Period. If you're going in the mountains with steeps, you're going to have hard time and have a white knuckle experience. This is my opinion. If you got a Hensley Hitch, that might help with sway, but a 19 seems like too much. Too bad they stopped putting the V8 in the 4Runner. The wheelbase should not be an issue.
08-04-2010, 03:34 PM
Battle Lake
Okay, this is where I get confused (and yes, I suppose its been discussed many times).
If a Suburban weighs about the same as a 28 ft Safari, and a 4-Runner weighs about the same as a 19 ft Bambi, why is that Suburban combo so much better than the 4-Runner combo, relative to white knuckles?
Doug
08-04-2010, 04:41 PM
St. Catharines
, South Western Ontario
We are aware of a number of V6 powered vehicles that have towed Airstreams to Alaska.
Things to keep in mind about towing and TV's is general is that at Tow Rating and the TV's weight has little to do with how well the combination will handle overall.
Some of the better performing combinations have TV's that are lighter than the trailer.
From an armchair position TV/Trailer performance can be difficult to evaluate.
08-05-2010, 06:09 AM
2001 19' Bambi
Dallas
Thanks everyone, for the opinions and the advise.
I have an electric brake controller device being installed, and am going to go for some mild mountains in Oklahoma this week end to check how the 4-Runner is as a TV for the Bambi. I will be very careful with the weight distribution also.
I really appreciate you folks!
08-05-2010, 08:01 AM
I am a bigger hammer guy (diesel Excursion and 25 foot Safari) and live in Colorado. With that being said, I wouldn't give up on your 4 Runner and Bambi without a trial run since the rig is within the tow rating of your vehicle.
You can drive through Colorado on I-70 and never face more than a 6% grade. There is about a 4 mile downgrade below the Eisenhower Tunnel and about a 3 miler on the west side of Vail Pass and that is it. If you gear down, don't ride your brakes and go slow you will have no problems.
White knuckle moments, if any, are reserved for places like the west side of Rabbit Ears Pass long 8% grade and Monarch Pass, steep grades and tight turns.
People have complained about brake shuddering and disc warping on the Tundra. There is a dealer installed brake upgrade if that is an issue with your 4 Runner.
Good luck and post about your trip.
08-06-2010, 12:40 AM
2005 19' Safari
GLENDALE
, AZ
The main advantages to a bigger, heavier tow vehicle is that it probably has a larger engine with more braking power; and being a heavier vehicle, it probably has bigger brakes. Both of these give you a larger safety margin on down grades (besides the obvious advantage of the larger engine going uphill). Ideally, you won't have to use the brakes at all on the down grades.
I'm not sure if they still do this, but the rangers used to check brake temperatures on one of the flat areas coming down Pike's Peak, just after the first of the steepest down grades. If your brakes were hot, they would make you park on the side of the road for 30 minutes until your brakes cooled off. Years ago, the ranger cautiously put his hand close to the hub on our front wheel to check and see how hot it was, then clamped down on wheel bare handed -- "Dead cold!" he said. "You must not have used the brakes at all." (We weren't towing, at the time.)
That's the way it should be. If your vehicle won't hold a safe speed in a lower gear, your tow vehicle is too small.
Other advantages of a larger TV (significantly larger than what is being towed): Less mechanical wear on the TV (engine, transmission and brakes), better braking, better hill climbing, better emergency handling, possibly better fuel economy, more room for your extra stuff, and in general, more easy cruising and less white-knuckle driving.
While the 4Runner may work OK for you, the concerns you have will be lessened with a larger TV...
08-06-2010, 07:39 AM
2006 19' International CCD
Olathe
, Kansas
I just got back from a week in Colorado with a 19' Bambi and a Acura MDX. I didn't have any white knuckle moments (except a non maintained road to Cottonwood lake in Buena Vista CO) I have the tow package with transmission cooler and PS coolers. I also upgraded my Brakes, changed the fluid, have Reese WD bars and anti sway. I didn't win any races (slow is better even in a bug truck) but I went down some good grades on I70 and barley tapped my brakes (to avoid hitting someone going slower in front of me) the transmission did a great job slowing me down. We did have to pass a large class A that was smoking (brakes) all the way from Eisenhower tunnel to Dillon! He never even pulled over to let the cool off! Just kept ridding the brakes!
I would look over your brakes and make sure you have the proper coolers etc and just go slow and what ever gear you go up should be the gear you go down. Slow going down is a good thing. Happy travels.
09-12-2010, 06:56 PM
2001 19' Bambi
Dallas
OK, the 4-Runner is a good enough TV, had power to spare, and absolutly no issues. But, with 2 of us heading out and a big German Shepperd, there wasn't enough room for gear! We took an inflatible kayak, one cooler, chairs, charcoal + grill, all the camping stuff. We were will set up for a short duration trip, but need more room for gear on the 3 month trip to Alaska- so it will have to be a full size truck.
No fault of the 4-Runner, it preformed it's TV duty prefectly!
09-12-2010, 08:32 PM
Battle Lake
The Airstream is a self-contained camper. Maybe all the camping stuff, cooler for sure, charcoal + grill for sure, are not needed for the long trip.
As for food and water, it's available along the way.
If the 4-runner performs well, hang onto it. It's a reliable truck and that's important out in the boonies. Pack only what you need, then leave half of that at home. "Making do" is the skill and fun of camping.
Doug
09-12-2010, 09:50 PM
2002 19' Bambi
Northwestern Ontario
, - on the backside of the map and just above the big green spot
Just to let you know that you might not have to invest in a truck to carry around your "stuff" ....
We have a Pathfinder (similar in size to yours) to haul around our 19 Bambi, comfortably house our Border Collie, carry our outdoor gear (similar to yours), a 1000W generator and tote, substantial toolbox and "just-in-case" tote (no kayak + related equipment).
"Attica" owns the space behind the front seats - these are folded flat and a pet barrier installed between the seating area and the rear storage - lots of room for her bed, her toys, food and water, and "get up, nose around and stretch space".
And the rear? - with some imagination it packs nicely - really. In the beginning it took a couple of trial runs to get it right - but after 8 seasons (our previous vehicle was a smaller Pathfinder) it packs pretty smoothly - with the stuff you would want to use on a daily basis easily accessible.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
09-13-2010, 08:02 AM
2008 22' Safari
Oracle
Doug
Good point Doug.
09-14-2010, 08:00 AM
2001 19' Bambi
Dallas
Doug, I love what you said about making do with less stuff! It's a huge departure from the concept of what can be added to make camping more comfortable. For me, I think the suggestion to pack smarter would be better. The 4-Runner was stuffed on the last trip, and some of the stuff has already been relocated to the Bambi..
Note- take bar soap instead of liquid soap....
09-14-2010, 12:14 PM
2006 19' Safari SE
Tucson
Traveling with only what you need and will use is an art in itself, and we are constantly evaluating what we take... We actually have different "sets" of gear depending on where we're going and for how long. For instance: know there are fire restrictions?...don't take fire wood or charcoal grill...you won't be able to use either; if water will be available...travel with less-than-full fresh water tank... Going for a long weekend?...don't bother with a cooler. Will there be electricity?...Don't haul a generator... etc... We all learn over time... And we have learned to not take anything that we are likely not to need or use. We tow a 19' with a 6cyl Tacoma so we know that the lighter we travel the better off we'll be...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
09-14-2010, 02:57 PM
Vintage Kin
Fort Worth
Awfully good choice of shake-down territory out of Dallas! From the Ouachita's north towards Russellville is as good as it gets short the Sangre De Cristo.
