Old 10-27-2011, 08:51 PM   #1
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
25FB flying Cloud tongue weight
I as just curious about why the tongue weight is (above 800 lbs.) so heavy compared to a 23FB. Even some longer heavier rigs have less weight
danlehosky is offline   Reply With Quote
Old 10-27-2011, 09:31 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Has to do with location of equipment and position of axles. The 25FB would be a better towing trailer than the 23FB without any load.
But the 23FB has most of its storage space up front. When loaded it would see a substantial increase in tongue weight, a greater increase than the 25FB I would guess. The location of storage tanks also come into play here.
We can hope the engineers have considered all factors to ensure both trailers will tow well when in use. Note that on most models heavy kitchen equipment such as range and fridge are near the axles to aid stability.
I wouldn't select a trailer based on unloaded tongue weight unless you don't plan to take anything along. Using a tongue weight scale, you have some control of this weight, but keep the heavy stuff near the axles and have at least 10-12% total trailer weight on the tongue.
doug k
Old 10-27-2011, 09:36 PM   #3
dznf0g's Avatar
Oswego , Illinois
doug k
Good analysis....I wasn't going to comment unless I could crawl around one, but I think this comment is accurate. But, I'd lean more toward 12 - 15% tongue weight.
-Rich-
25fb, tongue weight
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Used '10 Flying Cloud 25FB Value bike_addict Trailer Values 0 09-04-2011 12:02 PM
2011 Airstream Flying Cloud 25FB - NO RESERVE !! eBay Watch Airstreams on eBay 0 08-30-2011 08:50 AM
Centramatics for 2012 Flying Cloud 25FB wlanford Wheels, Hubs & Bearings 14 08-25-2011 09:06 PM
2011 Airstream Flying Cloud 25FB - LIKE NEW !!! eBay Watch Airstreams on eBay 0 08-16-2011 02:20 PM
