Old 03-16-2016, 01:26 PM   #169
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Love me some TFL Truck!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 03-16-2016, 11:51 PM   #170
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by rodsterinfl View Post
I found a great video review comparing pickup trucks featuring the Ford F-150 on You Tube titled
2015 Ford F-150 3.5L Ecoboost Platinum 4x4 Pickup Truck Review in 4K!
The guy does a really good job going through features and capabilities. The payload is really the big difference between truck class but see below. At one point (5:39), he compares towing and payload to competition and 3/4 ton trucks:
1/2 ton limits 2015 (max equipped)
payload
3300# Ford
2120# GM
1910# RAM
3/4 ton payload (competition)
RAM 2500 3970#
Silverado 2500 3760#
I also finished watching the mountain Gauntlet run videos and some interesting data was shared regarding braking on the different models. One of the best self- braking (holding to speed) was the 2.7 Eco- go figure. The worst was the GM 6.2 8spd.-12 times the brakes had to be used to slow the tow down to speed limit.
Hey, to each his own opinion....I love the EB except as mentioned....I do think Switz is correct about displacement being key in engine braking. I will keep an eye on 6.2...you really don't know how the Chevy in those videos was set up with gearing/tow mode... I saw the early EB video's which is why I have one...but owning/living is the real world for me... Good to see everyone tuned in...hope some real world owners can chime in here, vs the youtubs...
Old 03-17-2016, 12:38 AM   #171
2015 27' Flying Cloud
Washington , Washington, D.C.
As the owner of a 2015 GMC Sierra 1500 with the 6.2 and the max tow package, I know there are two huge problems with the TFL truck video. First, their test truck was not equipped with the towing rear axle and, more importantly, they didn't use the grade braking system correctly. While it's true that the "grade logic" system will activate engine braking to some degree on steep downhills, proper use requires engaging speed control, which TFLT says it never does. If you engage speed control, the transmission will start to gear down once vehicle speed exceeds the set speed by about 4 mph. If vehicle speed continues to increase, the transmission will continue to downshift, even spinning the engine over 4,000 rpm until the truck stops accelerating. The standard "hill descent control" alone is not nearly as aggressive in limiting vehicle speed.
So the TFLT "test" of that truck is pretty meaningless as it pertains to effectiveness of engine braking. BTW, if you apply the service brakes while engine braking is activated by the speed control, the speed control disengages but the aggressive engine braking does not until you apply the throttle.
I've never driven the Ford so I can't say it's better or worse than the GMC. But I've towed my FC 27 with this truck nearly 23,000 miles across country and all over the West, so I'm pretty familiar with how this truck works. I've never gotten the service brakes hot enough to even smell much less fade and I've been on grades far steeper than the 6% maximum specified for Interstate highways. Sure, I'm not saying I never use the service brakes. However, unless I can see that the end of the downgrade is close, I apply service brakes when vehicle speed goes over 65 and the rig is still accelerating (assuming the road is straight).
DC Bruce is offline   Reply With Quote
Old 03-17-2016, 04:20 AM   #172
m.hony's Avatar
2013 30' Classic
Same with the Tundra video-
They used a TRD Pro 4 wheel drive-
Likely the least towing capable Tundra-
I still enjoy TFL videos, though.
TAC #MS-10
Airforums #70955
Old 03-17-2016, 01:06 PM   #173
gypsydad's Avatar
Good input; thanks for your experience...6.2 looking better
Old 03-22-2016, 06:12 AM   #174
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
You are correct on the trucks not having the best setup options for their tests. The 3.5 ecoboost tested has a 3.31 rear in their test which means the truck tested did not have the max tow package; however, I learned some details for comparison. One thing I have mentioned over and over in the threads for truck shoppers is about the gearing and RPMs at speed of the various brands- it has a lot to do with what the tow experience will be like. It cannot be overlooked.
When someone shares about how much better they like towing with a diesel what qualifies that is really all that torque more than any other factor. I considered the Ram Diesel myself but was steered away from it by the manager for my AS payload- the payload rating was 1200# with max setup. Because of the technologies being implemented in the various engines they have to be geared differently. GMs need higher RPMs to get at their power due to push rod and other design factors. In the other 1/2 tons currently offered here is a tidbit of info based on the manufacturers own specs:
At 70 mph, what percentage of torque is available without shifting?
GM/Chevy- 40% (5.3 & 6.2/3.42)
Ram - 48% (5.7L/3.92)
Ford - 72% (3.5L/3.55)
These figures say a lot about what will happen while towing on hills, mountains, flat ground passes, etc.
As far as payload goes:
https://youtu.be/zYvNVmty7LM
The guy does a really good job going through features and capabilities. The payload is really the big difference between truck class but see below. At one point (5:39), he compares towing and payload to competition even between 1/2 ton and 3/4 ton trucks:
I too would think that the displacement would impact braking but the exact opposite was found in their runs, the smallest engine had the best braking. If you watch the vids, there are 3-4, you really get an overview of the various trucks in mountain driving- though not configured to their best, it still is interesting.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 03-22-2016, 07:12 AM   #175
Gainesville , Florida
I'm a big time diesel nut, but I wouldn't buy one with a 1200 pound payload. My trucks payload is 3500 pounds, of course it rides like a truck, because I wanted and needed that payload. But for 1200 pounds I would go gas.
avionstream is online now   Reply With Quote
Old 08-03-2016, 08:33 AM   #176
Zak
Tupelo , Mississippi
Ford150 vs F250
Originally Posted by fran&frank View Post
Just looked at an Ford F150 XLT extended cab with 5 L engine and the comparable F250 with 6.2 L engine. F150 had a cargo capacity of 2000 lbs, F250 2900. What do you think about the capabilities of the F150 for towing a 25 or 27' AS? It has the payload capacity but what about the 5 L engine? The attractive part of the F150 would be its gas mileage for daily driving. Coincidentally sticker price if around 44,000 for each.
What did you decide to get?
Zak is offline   Reply With Quote
Old 08-03-2016, 09:37 AM   #177
m.hony's Avatar
2013 30' Classic
Did you look at the 2017 F250?
TAC #MS-10
Airforums #70955
Old 08-03-2016, 05:54 PM   #178
2006 25' Safari
Images: 8
Good question Zak. So, FranklyFrank, now with all this bestowed wisdom, what did you go for?
It really comes down to if you need it for a daily driver, what the payload requirements are. I have one vehicle aside from a scooter so I want the car-like easier to park rendition of a truck but I completely understand there is a purpose for for bigger oil burners.
Old 08-07-2016, 12:44 PM   #179
Storm Master
Ampman's Avatar
2005 25' Classic
Don't let the gas mileage decide for you. I have a 2012 F250 cc 4x4 with the 6.2 and the unloaded gas mileage is 13.5 and 12 dragging the 25 ft. Classic. Hardly ever commute in it and always wondered if a F150 with the 5.0 would be better mpg. Well I just retired from my lineman career and got recruited to work for Google Fiber. Guess what trucks they have to tool around in? F150 cc 2 WD with the 5.0 engines. And the mileage is a whopping 13.5 empty driving around town. Makes me very pleased with my 6.2 and the extra capacity and stuff that comes with it. Just saying...
Ampman is offline   Reply With Quote
Old 08-07-2016, 04:08 PM   #180
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Amp man, that's as good as my 4x4 4.6 f150 gets.
I've been kicking around the idea of locking hubs for the front axle.
Has anyone ever tried this, and does it improve mpg much?
Silverflames is offline   Reply With Quote
Old 08-07-2016, 05:16 PM   #181
Storm Master
Ampman's Avatar
2005 25' Classic
I have not seen a locking hub set up for f150's. F250/350 have solid Dana 60 front axles with vacuum hubs. When those crap out just replace em with some Warns and cap the vacuum lines. Makes them mechanical operation but gives you the ability to operate the transfer case in low with the rear only. Helpful on tight parking under load without tearing up the turf. Thats what I did on my last F250 and they worked great.
Old 08-08-2016, 09:08 AM   #182
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Huh? My 2015 F150 2WD with the 5.0 engine gets 18 in town and 24 highway.
Ahab is offline   Reply With Quote
F150 Ecoboost or F250 6.2L for 1968? Randy Gates 1965 - 1969 Globetrotter 25 06-16-2013 01:49 PM
F250 6.7 vs F150(Possibly EcoBoost or not) vs Nissan Titan AustinToast Tow Vehicles 25 03-22-2013 04:29 PM
F250 diesel vs. F150 gas tow comparison hhendrix Tow Vehicles 77 11-18-2012 06:23 PM
F250 vs F150 price urnmor Tow Vehicles 21 10-16-2012 06:31 AM
F150 or F250 Gas J Goertzen Tow Vehicles 28 05-15-2006 07:18 PM
