Old 03-11-2016, 12:00 PM   #155
2015 27' Flying Cloud
Washington , Washington, D.C.
Originally Posted by gypsydad View Post
For overheating experience, going up the grade from Riverside to Las Vegas in 100+ degree temps last 3 years at 55-60 mph; no power issues, BUT, temp shot up a couple times into red zone, so immediately moved to "truck" slow lane and backed down to 40-45, shut down air conditioner.
Braking- I experienced similar issues as others stated; EB downshifted automatically on steep grade 6-7% to 2nd gear, and I slowed to 15-20 using trailer break switch on dash to help, but I still had front breaks overheat a few times. Engine breaking was not noticeably helpful. The area I am talking about is from Julian CA to Borrego Springs with several turns, but it was not hot out...just more than the EB can handle with my 25', I feel. I love the truck, don't get me wrong. In some areas of the country, I am sure there are no issues. Lots of torque and great ride.
I'm wondering if you have your trailer brakes adjusted correctly. I've pulled my FC 27 over the same route and the full length of the PCH and have never had an issue with overheating brakes. Granted, the larger 6.2 engine in my 2015 Sierra may provide more engine braking than the 3.5 engine in the Ford, but I can't believe that accounts for our different experiences (or that the Ford's brakes are so inferior, if at all). Iv
DC Bruce is offline   Reply With Quote
Old 03-12-2016, 03:11 AM   #156
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I think this is the answer. If so it's a downfall of the ecoboost.
I have the 5.0 now but will be looking at a new truck soon. The ecoboost is appealing except for this.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 03-12-2016, 07:37 AM   #157
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
For optimum engine braking, nothing beats displacement.
Old 03-12-2016, 08:15 AM   #158
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I will double check the adjustment on the breaks next trip. I had it a bit too tight last summer, and it would lock up easily, so I backed off a little. I will re-calibrate and see if that helps. Didn't like the soot on my wheels after the last trip for sure. As for 6.2 GM, the other attraction is the 8speed vs the 6 speed on my Ford. I did like the shifting response when I test drove recently on the freeway. It was pretty responsive up/down as I accelerated and decelerated in tow mode. I was not pulling anything, however. Think I would still give a good look at the F150 EB "if/when" they deliver the 8 or 10 speed gearbox being "rumored" last 4 years!
Old 03-12-2016, 09:08 AM   #159
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
On my 2015 Int 27fb, the brakes will not lock up. I can pull the emergency pin on the hitch and drive off in my truck with the trailer in tow in 2wd. The dealer said that this is normal. I will be headed to JC to have it checked out this summer. On my 2011 25fb, they would lock up. Does anyone know why this was changed on the 2015 styles.
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
Old 03-12-2016, 11:47 AM   #160
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
I would say your brakes need a simple adjustment.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 03-13-2016, 08:16 AM   #161
LaBigDogs's Avatar
They are self adjusting, the dealer adjusted them and then told me not to apply the brake when backing or it would go back to what it was. Well you know where it is today.
WBCCI 11100
Old 03-13-2016, 08:21 AM   #162
switz's Avatar
2014 31' Classic
Images: 8
I was under the impression that the 2015 wide body trailers have self adjusting drum brakes. The 23D seems to be an Airstream loss leader where cost cutting is evident everywhere. We are converting to auto adjust 10" drum brakes along with complete sets of new Timken wheel bearings in May.
Andy at CanAm adjusted the brake settings on the Tekonsha RF brake control system and there is plenty of stopping power
and can lock the 15" Michelin LTX (P) 235/75R15 XL tires mounted on the SenDel T03-56545T wheels. This system gets the brake power from their black box that has the trailer umbilical cord plug into it while it plugs into the 2007 Mercedes ML320,CDI. The brake power is direct from the trailer battery as no brake signal or power comes from the tow vehicle wiring as the wiring was not properly factory installed in the first three or four months of the 2007 model year production..
Old 03-13-2016, 08:22 AM   #163
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Our Bambi will not lock up brakes on pavement for the most part. If the roads are wet or sandy it can be coaxed to do so but otherwise no way!
Just for the record, even after I found that rust had allowed grease to leak past the seals and Dexter sent me all new braking parts, including drums, it still didn't lock wheels. When you see how the brakes work, it is understandable.
I'm sure that a disc brake equipped Airstream is another story altogether...
Bruce
Bruce B is offline   Reply With Quote
Old 03-13-2016, 09:03 AM   #164
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
My trip yesterday to look at dealer inventory presented two choices for 3.5 ecoboost with reasonable payload in an xlt with the 302a option package. A super cab with 6.5' bed and 2010 lbs cargo capacity but with the standard 23 gal fuel tank. Or a super crew with 5.5' bed but 36 gallon tank but less cargo capacity at 1790 lbs. Since this is a daily driver we already decided not to jump up to the f250. And evidently at this point time Ford is not taking orders on the xlt super crew with HD payload package, but will take an order on the super cab with 8' bed, but we'd rather not have that longer wheelbase, or be limited to the 301a option package. Seems there are always trade-offs, but realistically I think we can make either of the in stock options work with our goal of getting a FC 27FB.
fran&frank is offline   Reply With Quote
Old 03-13-2016, 09:27 AM   #165
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Get the Super Crew with bigger fuel tank. 1,700# payload is still good.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-13-2016, 10:16 AM   #166
Anna Maria , Florida
I have driven my 2012 EcoBoost over three years pulling our 30' International.
Every Summer we are driving through the Rockies. My wife loves Colorado. Never had a performance issue with the truck, uphill or downhill. I don't care what you drive descending down a steep grade one has to be measured and careful. Will a F-250 Diesel give you more braking power, yes it will, however for those few hours a season that I need to be patient going down hill with the F-150 I can not justify the additional cost of initial purchase and the additional operating cost, not to mention the stiffer ride. As I posted previously, a F-350 will give you even more braking power, and pulling your trailer, any size, with a Volvo Semi tractor you can go down hill 80 mph. Whatever floats your boat.
franklyfrank is offline   Reply With Quote
Old 03-13-2016, 10:40 AM   #167
penticton , British Columbia
same feeling here. I live in the Canadian roockies and we have some of the biggest/pass in north America.
My F150 as never had a issue with braking on those but when I pull my airstream, I m in vacation and not in a hurry, I have no issue staying in the slow lane, using engine braking to not let the speed go up and feather the brake of the trailer to slow down the total rig....I rarely have to use the truck brake at all. I also feel like I m often following the same pace as the commercial 18 wheelers.....slow and relax in those passes!
If I was in a rush and wanted to keep up with cars traffic...yep, I m sure braking would become a issue.
jonnyo is offline   Reply With Quote
Old 03-16-2016, 10:13 AM   #168
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
2016 Ford F150 vs F250
I found a great video review comparing pickup trucks featuring the Ford F-150 on You Tube titled
2015 Ford F-150 3.5L Ecoboost Platinum 4x4 Pickup Truck Review in 4K!
The guy does a really good job going through features and capabilities. The payload is really the big difference between truck class but see below. At one point (5:39), he compares towing and payload to competition and 3/4 ton trucks:
1/2 ton limits 2015 (max equipped)
payload
3300# Ford
2120# GM
1910# RAM
3/4 ton payload (competition)
RAM 2500 3970#
Silverado 2500 3760#
I also finished watching the mountain Gauntlet run videos and some interesting data was shared regarding braking on the different models. One of the best self- braking (holding to speed) was the 2.7 Eco- go figure. The worst was the GM 6.2 8spd.-12 times the brakes had to be used to slow the tow down to speed limit.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
F150 Ecoboost or F250 6.2L for 1968? Randy Gates 1965 - 1969 Globetrotter 25 06-16-2013 12:49 PM
F250 6.7 vs F150(Possibly EcoBoost or not) vs Nissan Titan AustinToast Tow Vehicles 25 03-22-2013 03:29 PM
F250 diesel vs. F150 gas tow comparison hhendrix Tow Vehicles 77 11-18-2012 05:23 PM
F250 vs F150 price urnmor Tow Vehicles 21 10-16-2012 05:31 AM
F150 or F250 Gas J Goertzen Tow Vehicles 28 05-15-2006 06:18 PM
