I just bought a 2007 Toyota Tundra V* 4.7 6700LB capacity.
What would be the largest Airstream in the 1960 to 1980's range I could Tow?
Short Bed
Double Cab
6700 Towing Capacity
Do you know that my 3 yr old has been to more states than I did before I was 30. Hopefully we will finish the map together and start over! Power Inverters and Solar
Recognize that dry weights are not necessarily "as equipped" weight. They're generally without LP tanks, or most of the "options". Weights from the '90s and later are closer to "as equipped" though. This chart will give you a good idea of what range you'll be in. The '60s vintage trailers will be much less weight than the '80s.
Roger
havin' to fix my broken Airstreams since 1987... AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter Former Airstreams: 1953 Flying Cloud, 1957 Overlander, 1961 Bambi, 1970 Safari Special, 1978 Argosy Minuet, 1985 325 Moho, 1994 Limited 34' Two-door, 1994 B190 "B-Van"
