Old 07-16-2009, 04:06 PM   #15
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Originally Posted by ROBERTSUNRUS View Post
Hi, actually it is two key words. "Torque Converter." This is why an automatic trans has an advantage because the Torque Converter is, in other words, a Torque Multiplier. Anyway you still need 3:73 or 4:10 gears.
Update... A Torque Converter is a fluid coupler... Not a Torque Mutiplier??????
mustang is offline   Reply With Quote
Old 07-16-2009, 07:01 PM   #16
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
From how stuff works......"In addition to the very important job of allowing your car come to a complete stop without stalling the engine, the torque converter actually gives your car more torque when you accelerate out of a stop. Modern torque converters can MULTIPLY the torque of the engine by two to three times. This effect only happens when the engine is turning much faster than the transmission."
This may help clear the confusion. Adios, John
Diesel1 is offline   Reply With Quote
Old 07-16-2009, 11:14 PM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, read this please.
http://www.apsprecision.com/images/H...ers%20Work.pdf
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-17-2009, 07:43 AM   #18
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
There is alot of garbage out there, as we all know. A Torque Converter, is a fluid coupler. Depending on the settings inside, which can be adjusted for when you get a 1to 1 ratio... meening
when the engine accellerates, it turns vanes inside the converter. The faster the engine accelerates, the faster the vanes turn, there is a second set connected to the tranny's out put shaft. when it starts to turn, or rotate the tranny, iot is refferred to as flash, until they both rotate at the same rpms at the same time. Fluid is what does this, hens the name fluid coupler.
To change the stall speed or flash point if you will, you can adjust the distance between both sets of vanes, stator ect. to control how hard it locks, can be done this way also. the pitch of the vanes also play a part.
I guess in close, one could surmise that from the point it is slipping, to the point it locks up, factoring in slippage, until lockup it could be stated torque would increase. However It wouldnt continue to multply after lock up. It would be like saying when I start off weith my stick shift vehicle I slip the clutch as to multiply the torque, until I fully engage it.
Old 07-17-2009, 07:50 AM   #19
Diesel1's Avatar
1967 24' Tradewind
Better to be thought an idiot..................Adios, John
Old 07-18-2009, 08:42 AM   #20
1974 29' Ambassador
madison , Wisconsin
Thanks for the info.
jginter4240 is offline   Reply With Quote
GKN Axle Service and Maintenance Manual Inland RV Center, In Commercial Listings 0 08-23-2007 04:37 PM
2004 Dodge 1500 wkerfoot Tow Vehicles 6 04-12-2006 10:00 AM
Broken Axle on 2004 Int'l dkekrksk Axles 26 07-04-2005 09:27 PM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 05:53 AM
