Old 10-04-2018, 02:29 PM   #1
2018 30' Classic
Houston , Texas
2 wheel drive vs 4 wheel
other than the obvious about driving on icy/wet roads or off road driving are there any advantages/disadvantages to having a 4 wheel drive TV over the 2 wheel---
Jonesuh is offline   Reply With Quote
Old 10-04-2018, 02:36 PM   #2
2007 22' International CCD
My favorite use is on wet grass, snow, or soft sand at the bottom of the slope out of the campground toward the paved street...
Then it's 4WD low range, and the rear differential lock set while the TV and AS slowly climb out without digging in...just above idle...and in as straight a line as possible.
At that point, the 4WD system becomes 'priceless' unless someone friendly is along with a big winch and a very long cable...
Old 10-04-2018, 02:59 PM   #3
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
The disadvantages of 4WD compared to 2WD are initial cost, a slight reduction in fuel economy even when disengaged, and added weight which will effect maximum payload.
With regard to actual driving situations, however, 4WD gives you options which 2WD, even with limited slip, can't provide. I've been in situations as mundane as sandy soil with the trailer where I would have been totally stuck without 4WD. Even backing up the steep driveway at my house puts a lot of strain on the transmission unless I shift into 4WD in low range.
4WD is highly desirable in a TV and well worth the disadvantages, IMHO.
ďThe good thing about science is that it's true whether or not you believe in it.Ē
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 10-04-2018, 03:03 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Pro's
Better accleration on slippery surfaces
Maybe easier to resell, but less resale as a percentage of MSRP versus 2wd
Con's
More expensive to buy
More expensive to maintain, today's sytems are very complex.
Less payload capacity as 4wd systems tend to be packaged in with other heavy items.
Tougher to get things in and out.
Less MPG
Higher insurance costs
Tend to want to explore more, and if you don't have lockers, watch out.
I'd buy a 2wd with a front receiver for parking the Airstream, but also to be able to mount a winch.....trust me, you'll be better aware of your terrain and parking with a 2wd versus a 4wd, that will negate the need for 4wd.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 10-04-2018, 03:16 PM   #5
2018 28' International
Fayetteville , Georgia
You only need 4WD once to appreciate it...
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 10-04-2018, 03:21 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
ďIts better to have what you don't need when you need it, than not to have it when you donít.Ē
RLC
Instead of going to íStarbucksÖI make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 10-04-2018, 05:17 PM   #7
pjshier's Avatar
2017 27' International
Wasilla , Alaska
that's true, but is also true that...
I grew up getting stuck on rural trails hunting grouse and moose. Handyman jack, come-along, winch and friends got me home. My first positrack(sp?) equipped f100 was a true wonder. All to say that 2WD with some sort of lock-up is really great, and as others say: you will learn to be a true judge of terrain before you venture.
Now, all our rigs are 4X4. I feel too old to crawl around with get-un-stuck tools and bother. Just the other day I was making circuits to-from the landfill scale (no CAT scale here) with various hitch settings. Wouldn't you know that the loose gravel near the turn-around point spun a rear tire. No sweat. Turn the dial, pull the lock, off we go. I am annoyed by the unnecessary added height of the F350 4X4, cost, mileage. But I am much more relaxed, though not inattentive. I do not use 4X4 to get myself further stuck, but to solve the rare unexpected need as we boondock around Alaska.
Your mileage may vary, don't try this at home, etc. Happy hunting!
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 10-05-2018, 04:00 AM   #8
2014 27' Flying Cloud
Wenatchee , Washington
FWIW, when crossing a mountain pass, you donít have to chain up when chains are required if you have 4WD or AWD. (Iíve seen exceptions where all vehicles are required to chain up but those occasions are few and far between).
Thatís why my truck is 4WD and my wifeís car is AWD. I donít enjoy chaining up.
(Iím talking about running solo, I havenít towed in the snow before and probably never will.)
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 10-05-2018, 06:46 AM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not see any advantages but the obvious with 4 wheel drive. But the obvious advantages are pretty important. two wheel drive pickup trucks, and particularly heavy sprung ones, are terrible in slick or soft conditions. Not like driving a front wheel drive car.
Old 10-05-2018, 06:51 AM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
4wd pays for its self the first time you call for a tow truck.
When you need it, you really need it!
Old 10-05-2018, 07:03 AM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
4x4 without question. It's not for what you think you might need it for, it's for what you don't know you need it for until you need it.
If you tend never to go on wet grass, tow in inclement weather, or drive in snow, then 2wd might be better. Tow rating is slighter more and mpg is slightly better with 2wd. IMHO though, those hits when going 4x4 are far outweighed by the benefits of having 4x4. It's literally pulled my behind out of a few jams both camping and normal driving needs.
Old 10-05-2018, 10:12 AM   #12
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Gray Court , South Carolina
We often shift into 4-wheel drive in campgrounds while parking our Airstream. The grounds are often soft and the tires just slip in the dirt and grass until we switch from 2 to 4-wheel.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 10-05-2018, 10:20 AM   #13
2017 22' Sport
connelly springs , North Carolina
This is all dependent on where you go with your trailer, where you live in the USA, if you want to spend $2000 plus for a new vehicle having 4 wheel drive, and the 1-3 mpg gas difference. I have had both and from experience, I can honestly say it is up to what you feel comfortable with. I have a 2014 1500 Silverad with 2 wheel drive and limited slip 3.73 differential which I purchased new. I modified it with bilstein shocks, Michelin10 ply tires, added an anti-sway bar. I also have rear air bags, but they are not pumped higher than 10 lbs when towing. It works for me.
rustyoldman is offline   Reply With Quote
Old 10-05-2018, 10:33 AM   #14
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
Where we live, where we travel to, what we drive on, and 40 plus years of towing. TV vehicle 4 x 4, all our other vehicles are full time all wheel drive. Works best for us. Would we tow our 30' Classic w/a 2 wheel drive vehicle, not unless we had too, not very far or for very long.
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
sbowman is offline   Reply With Quote
Four Wheel Drive or Two Wheel Tow Vehicle? 1cericks1 Tow Vehicles 24 02-01-2009 02:22 PM
Tow vehicle 16' bambi...4 wheel drive needed? jane 2005 and newer - Bambi all models 4 06-08-2006 12:37 PM
Drive vs Over Drive joshua32064 Tow Vehicles 10 10-17-2003 01:25 AM
Front wheel drive ?? ALANSD Airstream Motorhome Forums 14 08-25-2002 12:47 PM
