10-04-2018, 02:29 PM
2018 30' Classic
Houston
2 wheel drive vs 4 wheel
other than the obvious about driving on icy/wet roads or off road driving are there any advantages/disadvantages to having a 4 wheel drive TV over the 2 wheel---
10-04-2018, 02:36 PM
2007 22' International CCD
Corona
My favorite use is on wet grass, snow, or soft sand at the bottom of the slope out of the campground toward the paved street...
Then it's 4WD low range, and the rear differential lock set while the TV and AS slowly climb out without digging in...just above idle...and in as straight a line as possible.
At that point, the 4WD system becomes 'priceless' unless someone friendly is along with a big winch and a very long cable...
10-04-2018, 02:59 PM
2020 25' Globetrotter
Santa Rosa
The disadvantages of 4WD compared to 2WD are initial cost, a slight reduction in fuel economy even when disengaged, and added weight which will effect maximum payload.
With regard to actual driving situations, however, 4WD gives you options which 2WD, even with limited slip, can't provide. I've been in situations as mundane as sandy soil with the trailer where I would have been totally stuck without 4WD. Even backing up the steep driveway at my house puts a lot of strain on the transmission unless I shift into 4WD in low range.
4WD is highly desirable in a TV and well worth the disadvantages, IMHO.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
10-04-2018, 03:03 PM
Dazed and Confused
Hillsburgh
, Ontario
Pro's
Better accleration on slippery surfaces
Maybe easier to resell, but less resale as a percentage of MSRP versus 2wd
Con's
More expensive to buy
More expensive to maintain, today's sytems are very complex.
Less payload capacity as 4wd systems tend to be packaged in with other heavy items.
Tougher to get things in and out.
Less MPG
Higher insurance costs
Tend to want to explore more, and if you don't have lockers, watch out.
I'd buy a 2wd with a front receiver for parking the Airstream, but also to be able to mount a winch.....trust me, you'll be better aware of your terrain and parking with a 2wd versus a 4wd, that will negate the need for 4wd.
Cheers
Sidekick Tony
10-04-2018, 03:16 PM
2018 28' International
Fayetteville
, Georgia
You only need 4WD once to appreciate it...
brick
brick
2018 International Serenity
Cute wife...
10-04-2018, 03:21 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
“Its better to have what you don't need when you need it, than not to have it when you don’t.”
RLC
10-04-2018, 05:17 PM
2017 27' International
Wasilla
, Alaska
that's true, but is also true that...
I grew up getting stuck on rural trails hunting grouse and moose. Handyman jack, come-along, winch and friends got me home. My first positrack(sp?) equipped f100 was a true wonder. All to say that 2WD with some sort of lock-up is really great, and as others say: you will learn to be a true judge of terrain before you venture.
Now, all our rigs are 4X4. I feel too old to crawl around with get-un-stuck tools and bother. Just the other day I was making circuits to-from the landfill scale (no CAT scale here) with various hitch settings. Wouldn't you know that the loose gravel near the turn-around point spun a rear tire. No sweat. Turn the dial, pull the lock, off we go. I am annoyed by the unnecessary added height of the F350 4X4, cost, mileage. But I am much more relaxed, though not inattentive. I do not use 4X4 to get myself further stuck, but to solve the rare unexpected need as we boondock around Alaska.
Your mileage may vary, don't try this at home, etc. Happy hunting!
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
10-05-2018, 04:00 AM
2014 27' Flying Cloud
Wenatchee
FWIW, when crossing a mountain pass, you don’t have to chain up when chains are required if you have 4WD or AWD. (I’ve seen exceptions where all vehicles are required to chain up but those occasions are few and far between).
That’s why my truck is 4WD and my wife’s car is AWD. I don’t enjoy chaining up.
(I’m talking about running solo, I haven’t towed in the snow before and probably never will.)
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
10-05-2018, 06:46 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I do not see any advantages but the obvious with 4 wheel drive. But the obvious advantages are pretty important. two wheel drive pickup trucks, and particularly heavy sprung ones, are terrible in slick or soft conditions. Not like driving a front wheel drive car.
10-05-2018, 06:51 AM
Overland Adventurer
2009 34' Panamerica
Telluride
4wd pays for its self the first time you call for a tow truck.
When you need it, you really need it!
10-05-2018, 07:03 AM
Aluminut
2004 25' Safari
4x4 without question. It's not for what you think you might need it for, it's for what you don't know you need it for until you need it.
If you tend never to go on wet grass, tow in inclement weather, or drive in snow, then 2wd might be better. Tow rating is slighter more and mpg is slightly better with 2wd. IMHO though, those hits when going 4x4 are far outweighed by the benefits of having 4x4. It's literally pulled my behind out of a few jams both camping and normal driving needs.
10-05-2018, 10:12 AM
The Silver TARDIS
2018 30' Classic
Hillsboro
, TX
We often shift into 4-wheel drive in campgrounds while parking our Airstream. The grounds are often soft and the tires just slip in the dirt and grass until we switch from 2 to 4-wheel.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
10-05-2018, 10:20 AM
2017 22' Sport
connelly springs
, North Carolina
This is all dependent on where you go with your trailer, where you live in the USA, if you want to spend $2000 plus for a new vehicle having 4 wheel drive, and the 1-3 mpg gas difference. I have had both and from experience, I can honestly say it is up to what you feel comfortable with. I have a 2014 1500 Silverad with 2 wheel drive and limited slip 3.73 differential which I purchased new. I modified it with bilstein shocks, Michelin10 ply tires, added an anti-sway bar. I also have rear air bags, but they are not pumped higher than 10 lbs when towing. It works for me.
10-05-2018, 10:33 AM
1972 31' Excella 500
Grapeview
Where we live, where we travel to, what we drive on, and 40 plus years of towing. TV vehicle 4 x 4, all our other vehicles are full time all wheel drive. Works best for us. Would we tow our 30' Classic w/a 2 wheel drive vehicle, not unless we had too, not very far or for very long.
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
10-05-2018, 10:56 AM
1994 34' Excella
Warren
, Manitoba
If you live where there is snow or ice, or where there are gravel/mud roads, 4x4 is not an option that you do not want to be without. I have often had to shift into 4x4 on wet grass to get the trailer moving. My summer only convertible is front wheel drive, but only driven on sunny days!! Have had 4x4 for over 45 years on will only give it up when going into the old folks home. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
10-05-2018, 11:17 AM
2006 19' Safari SE
Anacortes
Resale
We bought a Jeep Grand Cherokee in 2014 with 4wd. We have never had an occasion to use it, but I think it was a worthwhile investment from the standpoint of resale. Time will tell.
10-05-2018, 11:29 AM
2017 30' Flying Cloud
Spotsylvania
, Virginia
Normally the price difference between the two trucks is $3,500 if they are equipped the same. If you call a tow truck to get you and your AS unstuck I doubt if it would cost $3,500, unless you venture to some place you shouldn't. I can see if you camp in a wet grassy field a 4 x 4 would be a must. The wife an I pull with a 3/4 ton Chevy 2 wheel drive, never gotten stuck. With that being said we stay at campgrounds with either hard packed gravel roads or asphalt roads. Common sense steers me away from situations where we could or would get stuck........but then that is what road side assistance is for.
10-05-2018, 11:55 AM
2018 27' Globetrotter
Apollo Beach
We live in Florida and would not buy anything but a 4x4 for towing our Airstream here or around the country. While shopping for a 2WD truck, I ended up with a 4x4 due to the limited selection of the end-of-year deals. I didn't know how much I needed a 4x4 until I had one with my Airstream. That 7,000# Airstream creates a lot of drag in mud or sand. I've used it to turn around on dead-end sand roads in Florida. I've used it to pull out of campsites with wet leaves and grass. I've used it to back into muddy grass campsites (that Tennessee clay is slippery). I've used it to pull out from roadsides where I stop for pictures. I use it frequently when climbing steep gravel grades - when the tires slip I switch to 4x4. It has saved me from being stuck several times and is worth $3,500 investment to me.
You may get much of the initial investment back when trading in. Used 4x4s never die, they just keep getting higher lift kits and bigger tires! There is always a demand for used 4x4s.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
10-05-2018, 11:57 AM
2012 23' FB International
Woodstock
, Ontario
Lot's of positives about owning 4wd as noted above, and a few negatives. My own experience is that anytime I needed 4wd it was because I could put myself into the condition that needed it. I deliberately decided against 4wd for my next TV because of cost, gas mileage and payload. But I never put my rig into a situation that I can't get out of with my 2wd Dakota. Only once I buried the drive wheels in sand making a tight turn. I just disconnected, pulled out without the trailer then backed in straight to hook up on a fresh surface. I have never regretted going only 2wd
JCW
10-05-2018, 12:00 PM
Apollo Beach
JCW
Agreed, I've been taught to never use 4x4 to go into a bad situation, only use it to get out!
