Old 11-25-2017, 05:41 PM   #41
1997 34' Limited
Spruce Grove , Alberta
Gmc1500
I tow with a 2015 GMC 1500 c/c with max tow package. They must build the GM tougher than fords. I have no tow issues pulling my 34 limited at any speed. I try to stay within the manufacturer recommendations for the trailer tires. No sway no problems being passed and no porpoising. Many people exceed that for some reason but their day is near. The F150 must have a smaller weight and tow capacty after watching the posts on the issues people are having with tow experiences
wvollans is offline   Reply With Quote
Old 11-25-2017, 06:09 PM   #42
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My Silverado 1500 kicks a$$.
Old 11-25-2017, 09:09 PM   #43
Vintage Kin
Fort Worth , Texas
Ahh, you were both in detention hall the day they passed out the Blue Koolaid during homeroom.
Old 11-25-2017, 10:12 PM   #44
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
I can help a little with your GM superiority complex.
There is very little difference in handling between a 1/2 ton Ford and a 1/2 ton GM truck if they have the same tire and wheel size. The differences here are in hitch configurations.
One advantage of a GM is that it is about 1/2 the cost to put great shocks on it.
The Ford though does come with a good receiver the GM's will twist easier.
On 3/4 ton trucks the GM's are substantially better than Fords or Dodges due to their independent front suspension. Unfortunately, they are just about as tall as the ford and dodge so a lot of the suspension equity is used up controlling the tall centre of gravity.
Give me a dialled in 1/2 ton any day.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 11-25-2017, 10:16 PM   #45
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I long for the good old days when some of the most contentious, but good natured arguments were Ford v. Chevy.....
Old 11-26-2017, 04:57 AM   #46
Lakes Region , New Hampshire
Last summer someone posted photos of their airstream, which had rolled down a hill and came to rest against a tree, at a campground. They also posted pictures of how the welds on the receiver had come apart, where it connects to the tubes. That week I ordered and replaced the one on my Sierra 1500 with a heavy duty Curt hitch. In my opinion, cheap insurance, but the OEM really is junk. (I tried searching for the thread, to link, but couldn't find it)
RandyNH is offline   Reply With Quote
Old 11-26-2017, 05:26 AM   #47
Andrew T's Avatar
London , Ontario
2 WD F150 Towing Stability Issue
The good news is that when I receiver completely falls off it is always at low speed in deep dip that loads it up. I have not heard of one coming off at highway speed.
GM has improved their pickup receivers since then though not fantastic I don’t think they will fall off anymore.
Ford improved their pickup receiver a few years ago. Except the Raptor which gets the light duty receiver. Dodges were always pretty good.
Interesting the Durango which shares its platform with Mercedes has a much better receiver than the Mercedes does. It still needs reinforcement for heavier hitch weights but it’s not going to fall off.
Andrew Thomson
London, Ontario
Old 11-26-2017, 07:00 AM   #48
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
Looks like I made a good decision downsizing from a 2500 GMC to a 1500GMC. We will see, but am looking forward to it.
Mike S. is offline   Reply With Quote
Old 11-26-2017, 03:24 PM   #49
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Lafayette , Louisiana
I would not be afraid of it, setting up a weight distribution though rarely done properly is not rocket science.
Your current combination likely isn’t nearly as stable as you think it is. Sometimes towing on the ball can feel ok but there is very little depth of control to handle the unexpected.
If you like send me an email. andy@canamrv.ca and I can send you a a couple of sheets on how to set it up correctly.
Thanks Andy
LaBigDogs@Me.com
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
Old 11-28-2017, 04:24 PM   #50
TinLoaf's Avatar
2016 30' Classic
Trenton , Illinois
Images: 22
I had the same issue when I got my 2016 F-150 and it was the awful Goodyear Wrangler FORTITUDE tires. They’re super soft, ride great, and are great for fuel economy, but horrible for towing.
I swapped them for Cooper Discoverer AT/3 in load range C and it made all the difference in the world.
Steve
TinLoaf is offline   Reply With Quote
Old 11-28-2017, 05:04 PM   #51
ALTE797's Avatar
1999 30' Limited
Port Perry , Ontario
Sway Control Switch
Did you try towing with the Ford Sway Control Disabled ? Towing my classic 30 with Hensley / Lincoln Navigator felt a bit strange until I turned OFF the Sway Control on vehicle settings/towing -- just a thought. My theory is the Ford Electronic Sway control was fighting my Hensley. I turned it off and everything went back to normal. just a thought.
ALTE797 is offline   Reply With Quote
Old 11-28-2017, 06:14 PM   #52
"Cloudsplitter"
From my GM Dealer daze....
Round bar, short mount=replace.
ID:	299957   Click image for larger version
Name:	2001 SUB #2.jpg
Old 11-28-2017, 06:18 PM   #53
2002 34' Classic S/O
Irvine , California
Images: 11
The recommendations for measuring the dimensions of the truck before and after are silly. You need to weigh the rig, loaded for camping, to confirm that you do not have a light front end. There is no substitution for a scale!
Phil in Irvine
WBCCI # 9759
2002 34 Slide Out Lounge
2005 Yukon XL, 3/4 ton, 4WD, 8.1 engine
pjtaia is offline   Reply With Quote
Old 11-28-2017, 07:48 PM   #54
2017 23' Flying Cloud
Bartlett , Tennessee
But you have to do SOMETHING to estimate the proper WD settings even to get to the scale.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 11-28-2017, 08:50 PM   #55
"Cloudsplitter"
...so who's silly now?
Exactly....
What is SILLY is going to the scales WITHOUT doing everything you can do to get the rig as safe as you can with MEASUREMENTS.
We were only 175 under what the scales told us.
Old 11-28-2017, 08:56 PM   #56
Sun Rae
jack9443's Avatar
1977 Argosy 28
Lewisburg , Tennessee
make sure you weight distribution hitch is lowering your front end 1/2 inch after bars are installed
jack9443 is offline   Reply With Quote
Old 11-29-2017, 04:27 AM   #57
Mantua , Ohio
What all this proves is that an improperly setup wd hitch can be just as bad as towing on tbe ball. My initial set up onmy avion took so much weight off the rear that it was dangerous. This on a on a one ton. Get the wd sc set up properly by at least doing the measurement method! Confirm with weights if necessary later. Renember in this case the truck was already very light in the rear, removing weight compounded the problem even though the front did not Feel Light. The same thing can occur with a half ton truck because of the rear weight bias.
Old 11-29-2017, 06:07 AM   #58
LaBigDogs's Avatar
Yesterday I installed the Blue Ox BXW1000 SwayPro Weight Distribution/Sway Control - 1,000 lbs Tongue Weight paired with the B&W Hitches HB94050 2 5/16" Chrome Hitch Ball 1 1/4" Shank Dia. 16K Capacity. TV is 2018 F-150 Platinum 3.5L V-6 4x4 Max Tow 6.5' bed (Factory Tires) pulling the SS Clipper our 2015 27fb International Serenity. Installed myself (it was very easy) after watching many hours of you tube videos and good information obtained here, fellow Airstreamers and from Andy. Dialed it with measurements from each bumper of the F-150, and each corner of the Airstream. Took it out for a test spin on the freeway and it was solid and stable, very agile with the low center of gravity of the F-150. The independent front suspension paired with Max Tow's factory installed front stabilizer bar proved to be solid and planted to the pavement. The rear was solid and with no roll thanks to our installation of the Roadmaster Active Suspension kit. (About $350). I know this is a 4X4 but wanted to share my experience with my setup. The reason for us owning an Airstream is to keep it simple and the F-150 is the perfect marriage for towing with it's low center of gravity, monster torque, and hp to spare.
WBCCI 11100
Old 11-29-2017, 06:16 AM   #59
Mantua , Ohio
There you go! Properly set up riig per instructions!
Old 11-29-2017, 06:33 AM   #60
Anytown , New Hampshire
To the OP:
There are several things at play here, most of which have been mentioned.
1. The 4x4 system adds weight to the front. You have a differential, axle half-shafts, vacuum-operated hubs...plus the weight of the transfer case and front driveshaft a little further back. So not only will the truck be a little lighter in general, it will be lighter on the front end.
2. The 2015+ trucks are all aluminum except for the frame, axles, suspension, and firewall...making the whole truck several hundred pounds lighter than your previous truck. This will not make towing more stable.
3. The suspension is a little softer on the aluminum body trucks than the previous generation like you owned. The reason is because the suspension has to hold up the payload plus the weight of the truck minus unsprung weight like the wheels and axles. Since the aluminum body and bed of the truck weigh less than before, the new truck can have softer springs for a better ride while maintaining the same payload as before. Despite the lighter truck with the same payload, those softer springs still have to deal with your same heavy trailer. A lighter weight truck does not make a more stable towing vehicle.
4. Tires play an important role. A "10-ply" tire which would be found on a 3/4 ton truck will mean a harsher ride and likely worse fuel economy. I've also heard the significantly heavier weight of these tires causes premature front ball joint failure because the ball joints are not designed to constantly have this extra weight bouncing along. Nevertheless, they will tow much better...you won't have any concern for overloading your tire capacity and the sidewalls will flex much less.
5. Ford vs GM vs RAM comments: All of the half tons are pretty similar. From an engine perspective, the EcoBoost is most similar to a diesel and has excellent pulling characteristics. I'd certainly prefer it over any of the normal V8 options for towing. I doubt it will be long before the GM and RAM half tons are also aluminum, or mostly aluminum. Shedding weight means better performance and fuel economy. Ford trailer hitches are not bending, either.
6. Have you considered a 3/4 ton? Although I think with tires and maybe a bit of W/D hitch tuning your truck should tow your AS comfortably, a 3/4 ton truck is only marginally more expensive to buy (if you pick the gas motor). Yes, it will achieve less fuel economy and not steer as nimbly...but a modern 3/4 ton is pretty easy to drive.
troverman is offline   Reply With Quote
Towing Issue with a 2015 F150 and 2017 25’ FC KatMacz 2016 - Current Flying Cloud 41 04-24-2018 12:21 AM
Stability in high winds Toasty's Dad On The Road... 7 11-02-2006 06:41 AM
Tongue Weight and Stability Steve Heywood Hitches, Couplers & Balls 22 06-14-2006 11:24 PM
Trailer Stability markdoane Off Topic Forum 4 05-18-2005 04:46 PM
Jack stability? frozen chosen Our Community 1 07-08-2004 06:51 AM
