Old 05-27-2019, 07:20 AM   #1
2019 25' Globetrotter
kirkland , WA
19 RAM 1500 + AS GT 25ft - Having Payload/Tongue Weight Issues?
Hello,
New to this forum, please take it easy on me.
I've got a great problem, My wife is saying "when you gonna get the truck and airstream." She is pushing me because the weather is getting good
I'm about to pull the trigger on :
19 RAM 150 Limited with all the tow related options and 20" tires.
19 Airstream Globetrotter 25
I'm reading about issues with the tongue weight and a low payload specific to this RAM/AS combo.
adult - 200lbs
adult - 130lbs
3 toddlers - 100 lbs
We pack heavy.
I do not want to jump to 2500 due to size and features.
What do you guys think?
qualitydays is offline   Reply With Quote
Old 05-27-2019, 07:28 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Ha!
You will get a slew of answers, in every possible configuration. You did not say what kind of hitch, which is also a factor. I have a 25 with a ProPride and I was at my payload limit with my 1500 with two adults, a dog, and not packing heavy, a BAK flip tonneau on the truck bed.
I now have a 2500HD without a worry about payload and a topper that lets me keep things locked in the truck bed. My personal experience is that the 2500 tows a lot better than the 1500 did. This is mostly detectable through hills and mountains, and stopping distance. YMMV
Larry
lsbrodsky is online now   Reply With Quote
Old 05-27-2019, 07:39 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You probably need to look at the door sticker on the actual truck for the payload and try to get a viable tongue weight for the trailer. I pull a 25’ with a 2500 so do not know much about the smaller tow combos. Ford has some 150’s with high payload ratings. I know people that have gone from 250 fords to 150 fords with bigger trailers the one you list and have been pleased with the 150. I do not personally know anybody towing a heavy trailer with a 1500 Dodge.
Old 05-27-2019, 08:06 AM   #4
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Definitely check the payload sticker on the vehicle you want to buy. The brochure and the salesman may tell you it has a 2000 lb payload, but that's for a stripped down truck. Then you have to subtract the weight of all the options: 4wd, crew cab, leather seats, diesel engine, RAM boxes, sun roof, bed liner, bed divider, etc. I have seen a 1500 Limited door sticker showing 960 lbs of payload capacity.
out of sight is offline   Reply With Quote
Old 05-27-2019, 08:15 AM   #5
2012 19' International
Southeastern MI , Michigan
Most 1500s are between 1200 and 1400 lb payload.
2018 International Serenity 27' FB
Michelin 16 tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 05-27-2019, 08:22 AM   #6
kirkland , WA
Ok shucks, sounds like 1500 won't cut it.
I thought the 1500 was big, the 2500 is huge!
Now considering 2500 - I do not want a diesel, does the 6.4 do the job?
I see a big jump in Payload. Are there any concerns the 2500 wouldn't have similar weight issues?
I am carrying 2 yamaha 2000 generators and a trailer mover in the bed amongst other things.
Old 05-27-2019, 08:56 AM   #7
2014 22' FB Sport
Davie , FL
My 2500 limited with all the options, diesel, 4wd, shortbed has a payload sticker of 1835 lbs.
Note that RA publishes their weights and capacities for each configuration, including axle base weights, in their Trailer Towing Chart, available online. There's a chart for each model (1500, 2500, 3500). You still have to deduct for the additional options you want.
Old 05-27-2019, 09:02 AM   #8
lsbrodsky's Avatar
No issue with the 2500 on payload, it can carry all you want. I have a Chevy gas because I am not a diesel fan and the Chevy 6.0 tied with its 6 speed and towing package has got plenty of umpfh. It is big, but so is any pickup. I was worried about comfort but the dealer let me drive it for a day before I made a decision. No worries, trucks today are as comfortable as most cars; the days of buckboard rides are gone. I will confess that I try to avoid parallel parking, but that was also true in my 1500. I have been driving the 2500 for two years now, no bumps or scratches. Just my opinion and experience, but am much happier with the 2500. Oh, the 36 gallon tank was a big selling point although I understand some trims of FORD half-tons have a big tank.
Larry
Old 05-27-2019, 09:25 AM   #9
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Thumbs up
First thing is do not take the word of any dealer about the capability of any truck to tow or payload. Do the research Here is a YouTube video to consider.
https://youtu.be/qwFLOBrADBs
La Dolce Vita Brick & Mona
2004 International 25CCD "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 05-27-2019, 10:07 AM   #10
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
I have a 2014 Flying Cloud 25 Front Bedroom Twin. The Airstream Web site shows only front bedroom floor plans for the Globetrotter; it is identical to mine.
The specified tongue weight is 837 lbs. I had it weighed at Jackson Center loaded for travel with about a half tank of water and probably 75% propane. (I was there for warranty work, returning from two weeks on Louisiana.) Total cargo in the trailer was about 800 lbs. The tongue weight was 1,252 lbs.
When I ordered it I did my home work assuming 837 lbs. and selected a 144" wheel base F-150, max tow, max payload. I was using an Andersen hitch which will not transfer much weight. After the 1,252 lb. surprise I made a number of trips to CAT scales. The drive axle was overloaded by 850 lbs. I switched to a Blue Ox with 1,500 lb. bars and eventually got the steer axle to the unhitched weight and the drive axle to 100 lbs. over is weight rating but the trailer ride was very rough, based the stuff that was on the floor, etc. That concerned me a lot. I traded the Ford for a GMC 2500 Duramax, reinstalled the Andersen, and revisited the scales. All good.
The moral of the story: Be sure you have an accurate assessment of your total cargo weight. Airstream weighs every trailer right, left, and tongue as they come off the line and they will give you that information if you ask. Front bedroom 25s have a reputation for heavy tongue weights.
Good luck. I recommend a "3/4 ton" and I love my diesel.
BillfromWI is offline   Reply With Quote
Old 05-27-2019, 10:51 AM   #11
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
I hear that you want to use a Ram 1500 to tow an AS 25, and that you are getting some feedback suggesting that's not such a great pair, and that you should consider a 2500 instead, which you would not prefer to do.
Alternatively, you could go in the opposite direction and get a smaller AS instead. That doesn't seem to have been considered yet, although that should allow you to use a 1500 probably quite satisfactorily.
I should make my prejudices clear: I bought an AS 27 and towed it with a Ram/Cummins 2500, which, after 30K carefree miles, I traded in for a Ram/Cummins 3500, which I find ideal.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 05-27-2019, 10:53 AM   #12
2018 27' Globetrotter
Mesa , Arizona
RAM 1500 pulling 27FB Globetrotter
I've been pulling a 27' Globetrotter with a 2017 RAM 1500 for 18 months (12,000 miles) and have not had an issue. I have the 4X4 5.7L V8 with a Crew Cab and the 3.92 Axle rating. The max trailer weight on this set up is 10,140 lbs with payload of 1510. I have an equalizer weight distribution and anti sway hitch and it sits well and hasn't had an issue pulling up steep hills or stopping down them. Hope this helps!
dgutwein is offline   Reply With Quote
Old 05-27-2019, 11:08 AM   #13
greenflag's Avatar
2016 30' International
Quartz Hill , California
I towed my 25 foot AI for two years with a 1500 GMC. I stepped up to a 2500 and was much happier. The whole tow experience was much more stable. My 1500 handled like it was over payload.
With three toddlers I don't think I would go to a smaller Airstream. I see you got the same pressure from your wife that I got. I took the plunge and have not been sorry.
Welcome to the Forums.
greenflag is offline   Reply With Quote
Old 05-27-2019, 11:16 AM   #14
2016 25' Flying Cloud
RR#1 Thornbury , Ontario
Originally Posted by qualitydays View Post
Hello,
adult - 200lbs
adult - 130lbs
We pack heavy.
A WD hitch transfers the tongue weight to tow vehicle front axle (30%) rear axle (40%) and trailer axle (30%). I just went through this with my MB GL350 and everything worked out perfectly while I thought originally I would need a bigger vehicle to tow my AS International 27FB Experts on this subject are the folks at Canam RV in London Ontario.
Robv3 is offline   Reply With Quote
2019 RAM 1500 Towing & Payload Hans627 Tow Vehicles 113 03-13-2018 09:53 AM
Forgive me: Does tongue weight count against payload? marter Towing, Tow Vehicles & Hitches 105 09-24-2017 07:51 PM
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
RAM 1500 EcoDiesel, payload, weight distribution spelunkus Tow Vehicles 24 02-26-2016 10:42 PM
