Old 11-10-2008, 03:52 PM   #1
Profile:  Currently Looking...
Santa Clarita , California
19' international behind an LR3
Hi all, my wife and myself are looking to purchase an airstream international bambi 19 footer... well, we think 19'... We will also be looking at the Land Rover LR3 as a tow vehicle. I know there are numerous threads on the LR3's shortcomings when it comes to towing medium-large trailers, and that the LR3 will limit us to a smaller airstream. I only ask about this combo because we were originally looking at the 23' international... and the airstream dealer thought that the LR3 may fit the bill... but i am beginning to think that an LR3 will be better suited to a 19' International rather than the 23'. Is this correct? Will an LR3 even handle the 19' international? Thank you!
lexlaws is offline   Reply With Quote
Old 11-10-2008, 07:08 PM   #2
Sorry... I meant the International sig series 19 footer... my bad... i'm a noob
Old 11-11-2008, 07:43 AM   #3
Profile:  1999 19' Bambi
Fairfax Station , Virginia
I tow my 19' Bambi with an LR3. The LR3 tows just fine, plenty of power, very stable, no sway problems, and I get about 14 mpg when towing.
I had the LR3 first, so I didn't buy it as a tow vehicle. The LR3 fits my needs otherwise as a very versitile and capable vehicle- but there are several things you should know. One is that the max hitch weight for the LR3 is 550 pounds- even though the max trailer weight is 7700 pounds. The other is that Land Rover advises against the use of weight distributing hitches. If you think you may want a bigger trailer in the future, you should keep that in mind. The 19' Bambi is probably the biggest Airstream you could go with tho stay under the hitch weight maximum.
Overall, I'm very happy with the way the LR3 tows.
kenjengrif is offline   Reply With Quote
Old 11-11-2008, 10:10 AM   #4
Excellent kenj! Thank you for the information! The dealer at the Airstream lot figured the LR3 would even tow the 23' International, but was wary of the air suspension system, thus limited us to the 19' International given the LR3's type of suspension and the 550lb. hitch weight. I suppose the LR's 113.6" wheel base also may play against towing a 23' trailer. Seems that the 700lb. hitch weight of the 23' is out of the LR3's handling range. We LOVE the 19' Bambi with paprika... And we loved our 2006 Rover Sport HSE that we just traded in for a BMW 335i... so, we figured an LR3 would be a nice tow vehicle since we are used to the Rover platform and miss the Sport. So... is the 23' out of the question with an LR3 because of the tongue weight and wheel base? Just ask about the 23' because we have two medium sized dogs who will prolly want in on the Airstream action Thanks again to kenj and anyone else who may chime in!
Old 03-01-2009, 09:18 AM   #5
Kay
Profile:  2008 25' International CCD
Simpsonville , Kentucky
If you look on the receiver it is stamped 770 lb max. tounge weight. One tenth of the 7700 lb max. towing weight. LR is no help with this. Has anyone been successful towing an International 25 FB with an LR3 or RR Sport?
Kay is offline   Reply With Quote
Old 03-01-2009, 12:31 PM   #6
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Just my opinion, But LR wheelbase and high center of gravity and gross vehicle wgt would turn me off for any thing greater than 19' . U would not attempt to pull are railcar with a tri-cycle.
Just an opinion TO EACH HIS OWN COMFORT LEVEL
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Land Rover LR3 towing story reventlow Tow Vehicles 44 10-17-2009 09:52 AM
2008 Nissan Pathfinder & 2005 19' International CCD Gregory Fear Tow Vehicles 30 11-30-2008 04:44 PM
19' or 23' which is best Jack Nance Member Introductions 17 01-15-2007 01:07 PM
19' Bambi International CCD Deal Dawgfan 2006 Bambi - all models 10 08-04-2006 10:45 PM
Toyota Tundra & 19' Bambi International CCD Plotrow 2006 International CCD 12 06-09-2006 02:03 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
