Old 09-26-2014, 09:14 PM   #15
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Originally Posted by rgwatkin View Post
I have a 2012 Dodge Ram 1500 with 5'7" bed. I have owned trucks all my life and never have I had such a good riding and handling truck then this Dodge. I believe it is all about the rear coil/independent springs that make the difference. I have towed my 2012 28ft FC for about 20k miles without an issue and regularly pass diesel pushers on steep hills. I just cannot imagine needing more torque or hp. Over 20k miles towing my average gas mileage was/is 11mpg. I did get the 32 gallon gas tank as an option so..gas is rarely an issue. I recently took my truck into the dealership for transmission service (at 37k) and had them change the oils and check the pressures. All the pressures were perfrect. By the way, the payload on my truck is 1278lbs with 3900lb axles. My total rig weight is 13,000lbs. I do run my P rated Goodyear tires at max capacity of 44psi when towing. Interestingly, the ride is still very good at 44psi. compared to 33psi no load recommended.
It's a very solid design, which led me in the direction of RAM. In 09, the dark days of Cerberus Capital, the truck did not have much press and/or just was eclipsed by the bad times of the day. Funny how, like the Jeep JK, the model started hitting it's stride 3-4 model years later in sales. Now it is Truck of the Year.
My experience is similar to yours, albeit pulling other types of loads.
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Old 09-27-2014, 06:17 PM   #16
Sedona , Arizona
Did monitor the tire pressure, too:
39 psig cold at beginning of trip
41 psig ending 200 miles later
Tires are stock Goodyear SR-A 20". Also failed to mention that the rear dampers are Monroe Gas Magnum. When pulling the tractor, the stock rear shocks overheated within 50 miles @ 55 mph average, with load equalizing hitch. The yellow old-school Magnums held their ability to dampen during the last trip ok.
14 Serenity 28'
#5261
Old 09-27-2014, 07:33 PM   #17
interstateflyer's Avatar
2017 25' International
Los Osos , California
I did my first 200 mile tow in my 2013 RAM 1500 Outdoorsman today....with new Michelin LTX P275/60 R20 M/S2s @44psi @58F.
I ran the OEM Goodyear SR-A for 22K miles. Wish I had put the Michelins on when the truck was new. They are a HUGE improvement over the Goodyears.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-28-2014, 03:08 PM   #18
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
I have a '14 1500 EcoDiesel 3.55 with air suspension. It's my 3rd Ram 1500 and definitely the best so far. I pull a 30' FC with loads of upgrades (read heavy).
People of course will disagree but you can take the payload figures/worries/limits/arguments and throw them into the trash.
This truck pulls incredibly, handles awesomely with the 4 corner air ride and I get 16 mpg at 65 mph PULLING!
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 09-28-2014, 03:24 PM   #19
Sedona , Arizona
Indeed. They're good, benchmark trucks that, in the case of mine, are not such an aircraft carrier to drive (more like an Alaska-class battlecruiser).
14 Serenity 28'
#5261
Old 09-28-2014, 03:35 PM   #20
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Nice WWII reference.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-28-2014, 03:40 PM   #21
Sedona , Arizona
I can't seem to get the "sailor" out of me, post Navy 😝
14 Serenity 28'
#5261
Old 09-28-2014, 04:58 PM   #22
Tomy's Avatar
Seattle , Washington
Thanks for sharing this. I've been eyeing the EcoDiesel, but was concerned that the towing capacity for my level of trim is only 8500. I'm interesting in the 27FB EB and it is listed at 7800. I was wondering if that was cutting it close, but it sounds like you're not having any trouble pulling more. I didn't really want to step up to the 2500.
Which cab/bed length do you have?
Tomy is offline   Reply With Quote
Old 09-28-2014, 05:27 PM   #23
Sedona , Arizona
I know you directed the question to the EcoDiesel owner.
As far as the transmission goes, it makes a significant difference in load-pulling and carrying performance. Since the Motori (as well as all modern electronically-managed diesel powertrains) is heavily boost-dependent...like the Ford DI gas engine...the 8-speed tranny makes it very capable.
14 Serenity 28'
#5261
Old 09-28-2014, 05:46 PM   #24
N/A , N/A
I am happy things are working for you. I would advise that people not throw that number in a trash (it would be wishful thinking to assume those numbers are garbage). I would also like to see your truck in 5 years and compare the list of issues/repairs with a truck that was NOT overloaded.
rostam is offline   Reply With Quote
Old 09-28-2014, 05:59 PM   #25
Sedona , Arizona
Overloaded...like the 78'Cougar Villager 302 2bbl in Mercury literature same year.
14 Serenity 28'
#5261
Old 09-28-2014, 05:59 PM   #26
Rawn77's Avatar
Montreal , Quebec
Trash!
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
Old 09-28-2014, 06:10 PM   #27
Sedona , Arizona
Lol...Back in the day, when my folks and friends pulled Mobile Scouts, Vaqueros, and Holiday Ramblers with Valiants, Monacos, and Ford Elites, we COULD only dream of a puller 1/2 as capable of a 3.7 V-6 Dodge.
14 Serenity 28'
#5261
Old 09-28-2014, 10:55 PM   #28
Tomy's Avatar
Thanks. I know everything is a compromise. I'm trying to walk that thin line between daily driver and safely adequate for a 27FB. This is good info.
First Tow - 2014 Ram 2500 CC 4x4 Laramie w/Cummins BAB Tow Vehicles 20 10-24-2013 06:20 PM
2007 Ram 1500 with hemi - push and pull thomdial Tow Vehicles 8 10-12-2013 04:58 PM
New Airstreamers, our first pull (a long one) rbs Towing, Tow Vehicles & Hitches 29 12-22-2011 02:17 AM
'98 Dodge Ram only rated to pull #4800 Zettervall Tow Vehicles 4 12-12-2003 08:21 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
