Old 12-12-2007, 10:04 PM   #1
subfan1
Profile:  La Habra , California
1/2 ton vs 3/4 ton towing?
We would like to down grade from our 3/4 ton Suburban to a new 1/2 ton Suburban.
Would there be any difference in towing between leaf springs or the coils on the 1/2 tons? Sway? anything?
Other than maybe not having enough power, I ready to sacirfice that for more fuel economy.
subfan1 is offline   Reply With Quote
Old 12-12-2007, 10:29 PM   #2
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
Subfan
It would help if you mention what size of trailer you are towing. Approximate weight and length will give us an idea of how to respond based on our combined experiences.
Merry Christmas
Barry
The best things in life are health, family, friends and enjoying your Airstream in a campground. Wally on Bro
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
AIR #7364 WBCCI #8110 member 4CU
safari57 is offline   Reply With Quote
Old 12-12-2007, 10:44 PM   #3
subfan1
Its a 25 ft, and weighs about 7000lbs
So in general, what if anything would I expect between the two sizes?
Old 12-12-2007, 10:56 PM   #4
2airishuman
2airishuman's Avatar
Profile:
fuel economy?
hi subfan...
are u expecting better mpg while towing?
or is this a daily driver vehicle issue?
what year tv? what engine and axle ratio?
the best axle ratios for towing usually reduce mpg a tiny tiny bit....
moving from a 3/4 chassis to a 1/2 ton (in the burboun line) means less brakes, less towing and less payload...
do 1/2 tons come with e rated tires?
you might wanna work the 'math' for this switch...
there's only about 6 variables so it's not that hard to project the dollar changes...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-12-2007, 11:18 PM   #5
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
We have an '05 Safari 25 FB, weighing in at apprx 7500#. We usually tow the Airstream with an '05 Suburban 2500 4x4x4 (Quadrasteer). This combo gets 10.5 mpg. We also tow the Airstream with our '04 Chevrolet Tahoe with the 5.3 liter. The Tahoe doesn't due nearly as well in the towing department, and gets the same 10.5 mpg when towing the Airstream.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 12-13-2007, 09:49 AM   #6
safari 28
safari 28's Avatar
Profile:  2004 28' Safari
holland , Michigan
When researching tow vehices I looked at the new suburbans and the problem was they have lowered tow ratings for the half ton models. You have to order the 2500 series to get higher ratings. I wanted a 10k rating and the Ford f150 set up as ours alongside the chev 1500 hd max gave that figure. It also gives a smooth ride and easy on the AS.Our 28 safari weighs 5700lbs dry. We are very happy with our decision but you might be pushing it with your AS, as I remember the half ton suburbans were maxed at about 8k tow rating. But then again our friends in Canada are towing 34 classics with hemi powered 300 chryslers. So, what do I know???
safari 28 is offline   Reply With Quote
Old 12-13-2007, 11:38 AM   #7
ckeysor
WBCCI 11067 WDCU
ckeysor's Avatar
Profile:  1986 25' Sovereign
Atlanta , Georgia
As I looked at the Silverado, I think they downsized the towing specs on all 1/2 ton models. I had to go to the 1500 hd max to get to the 10K rating with GCVW at 15,000. The chevy dealer said that they were now measuring the towing capacity at 80% of the real number to make sure people weren't over-hauling. Don't know how true that was but I figured I would go up to the 1500 HD max since I didn't need a true 3/4 ton.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 12-13-2007, 04:10 PM   #8
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I think about the only perk to going back to 1/2 ton is the softer ride, other than that, for a 25 footer tipping over 3 tons....you are in 3/4 ton territory.
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 11:13 PM
1/2 Ton Silverado enough? IceCactus Tow Vehicles 22 11-11-2007 07:47 PM
1 Ton Van TV and 25 ' AS - what hitch? bernermom Towing, Tow Vehicles & Hitches 18 10-30-2007 04:35 PM
Finally got a 3/4 ton TV wheel interested Tow Vehicles 36 08-26-2006 02:22 AM
Who's towing with a 1/2 ton? wildwoodrver Tow Vehicles 50 11-29-2004 08:05 PM
test
