I have been doing some reading on tow vehicles here it the forums, but i would like to double check my figuring.
I have a 2007 Chevy Silverado 1/2 Ton New Body Style (GMT-900), extended cab standard box (143.5" wheel base), 2WD with the 5.3L Engine. It also is equipped with the heavy duty tow package (NOT the max package) and is Z71 so it has upgraded "towing" suspension and a trans cooler.
Im looking at purchasing a 1979 Argosy 26'. I dont actually know the specific weight of the unit im looking at, but a 74' 26' that i was looking at previously weighed 3980 with a 320lb tongue weight
My GCVWR is 13,000 Lbs, so i figure my TV curbweight, 5100 Lbs + say another 5000 for the trailer should put me at 10,100 + another 400Lbs in truck = 10500/13000 = 80.7%
Now i prolly went a little high on the numbers there but i would rather factor in say a worse case scenario.
Now with say an Equalizer WD Hitch or a Reese Dual Cam sway control and a prodigy brake controller with all 4 wheels braking on the trailer would i be in the range of "comfortable towing"?
Now i jsut realized something when typing this, i thought i remembered my truck weighing less then 5000Lbs, and it does, those specs are for 2008 model, mine has the same towing cap of 7700 Lbs, but in the 08 models they put a heavier duty trans in the truck (SOB! i would have liked that ) So that upped the weight by almost 200Lbs, my truck weighs around 4800 Lbs.
Looks you are "comfortably" in the ball park.
You might want to find the UBW (dry empty weight) of the Argosy and then double check your numbers. I've found that using the the trailer's UBW makes for easier calculations than trying to use the GVWR.
Looking at the Chevy specs, if needed, you could changes to 4:10 gears and upgrade the tranny cooler if you wanted a bigger towing margin. That won't change your cargo capacity but would allow you to pull more trailer weight.
The Reese Dual Cam WD and sway bar setup will give you a very controlled stable rig for a reasonable price
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
Hello IceCactus -- Welcome to the Forums! I've got a '74 24' Argosy -- those numbers sound pretty close. I believe you would have a rather higher tongue weight when you're ready to camp. Look in the manual for how to weigh tongue weight with a bathroom scale (or else here).
You are looking at the numbers properly. You will be happiest, safest and have fewer wear issues if you can keep a tow and your truck payload no higher than 80-85% of the maximums. Payload is the easier number to exceed and your link says your truck's payload is 1895#. Don't haul bricks in the box and I think you'll be just fine. The tranny cooler and other tow features are important to have. The 5.3L won't roar up the mountains but you'll find it adequate, especially on the more gradual grades of the interstates. Take it easy like the rest of us (well, there are a few...) and your Argosy will outlast yet another tow vehicle!
__________________ . BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
We have a '03 Sierra 4x4 extended cab with 4.8l, 4 speed auto and 3.73 rear gears.
Works great around here for us.
If I were going to the Rockies with the wife, 3 kids and their stuff I might think a little bigger or go lighter on the stuff.
We get better mileage than with the old '97 Yukon and the 5.7l.
Are you a heavy hauler?
Scales tell no lies.
I like 80% of gross capacity for comfort and safety.
R
A 'riff-raff Airstreamer' is an oxymoron, we all know better, Airstreamers reek of class.
"Talk is cheap, Airstreams are expensive," Wally Byam.
Yes, it does have the 3.73 gears, you get that automatically with the z71, i should have specified that
I also made a mistake, the rated tongue weight of that 74' that i was looking at was 380 not 320.
As for me being a heavy hauler, Well to be honest im not sure. I havent actually bought a trailer yet. I bought the truck a lil while back intending on really only towing a boat eventually. I saw this argosy and really liked it. i have never towed ANYTHING before.
I estimated the trailer weight to be 1000lbs more then the UBW weight of it just to be safe. and im still 80% of the GCVWR.
Get a 3/4 ton...minimum.
Its not the engine or gears, those are available to pull anything.
Its the brakes...and suspension that really makes the differance.
__________________ Your opinion is valued, please not your opinion of someones else's opinion.
Well yes, they make a difference for cargo hauling but only in extreme load situations and not so much for conventional towing. Just look at the specs.
Consider the 2008 specs for the F150 vs F250, both with a 5.4L v8 and 4.10 gears.
Maximum Cargo Capacity
F150: 3080 lbs
F250: 3170 lbs
Maximum towing capacity
F150: 11,000 lbs
F250: 11,100 lbs.
Either truck can safely pull pretty much any Airstream and gear.
So for towing and cargo hauling the F150 and F250 are about even. The F250 has a 1600 lb advantge in GCWR - which essentaily means the F250 can carry 1600 more pounds of cargo compared to the F150 when both are pulling near maximum trailer weight - an advantage to 5th wheels and construction hauling but not a very common Airstream occurance.
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
In 1979, the tow vehicle of choice was a large family car or station wagon. I think that your truck will be just fine. I would not hesitate to tow the Argosy behind either my PowerWagon or Lincoln.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Well i already bought the truck and its a brand new truck so getting rid of it isnt an option. I just wont buy the trailer.
Originally Posted by wkerfoot
Icecactus,
I think that you are within the reasonable comfort zone with the TT/TV comination that you are proposing. Where a 3/4 ton excells is in the brakes department. This advantage does not necessarily reflect in the towing capacity figures. You should have sufficient baking power to stop your rig. That being said, I would highly encourage you to make darn sure that the bake system on the Argosy is up to snuff.
Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Cactus, I do not see anything wrong with the towing numbers you posted. The numbers appear well within the specs of your truck. As I suggested above just confirm the the UBW (empty weight) you used.
You can find infinite TV opinions on this site. Some people need a belt and suspenders, others just get the right size belt. Just run the numbers as you did.
Focus your analysis on choosing the brake controller and a good WD/sway bar setup.
Decide on buying the trailer on its own merits.
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
