Old 05-06-2015, 04:00 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
'09 Dodge 2500, 4X4, Diesel????
I was very interested in purchasing an 09 Dodge 2500 4X4 diesel Laramie until I read the March issue of Consumer reports and they listed the "07,09 Ram 2500 and 3500(diesel)" as "Used model to avoid". I would be interested in any advice from people with this vehicle.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 05-06-2015, 04:20 AM   #2
Tincampers's Avatar
Sneedville , Tennessee
When I was researching diesels, it seems the favorite was the Duramax LBZ
History of the Duramax Diesel Engine - Diesel Power Magazine
Tincampers is offline   Reply With Quote
Old 05-06-2015, 04:53 AM   #3
Gainesville , Florida
Never trusted CR since they were caught lieing several years ago. So many of their evaluations are misleading at the very least. Jim
Old 05-06-2015, 05:02 AM   #4
2003 31' Classic
Terra Alta , West Virginia
Ron,
I have a friend who has one in that catagory and his biggest issue has been oil leaks. I am kinda partial to the 5.9 in Dodge. Certain Duramax years were a little better like the LBZ mentioned . Other than injector issues, I have not heard too many bad Duramax stories. Now for Ford, it's hard to beat the old 7.3. My dealer says the recent 6.7 is doing well with exception of some turbo issues. For now I will continue with my old 7.3 F250. It still pulls like a mule, uses no oil, and gets good mileage. It's been cheap to maintain too...a Motorcraft oil filter at Walmart is 9.97! After 25 years of diesels, when I shop, I may look at a gasser or be very selective on which used diesel as a new one does not fit the budget. Who knows my 20 yr old one may just keep going for a long time. If you have a good 7.3, shop carefully.
Dave
wvstreamer is offline   Reply With Quote
Old 05-06-2015, 05:21 AM   #5
2014 27' Flying Cloud
Wenatchee , Washington
I had a 2009 Ram Bighorn 3500 QCSB SRW 4x4 for three years and never had a problem with it. The only reason I traded it was I wanted a crew cab (rather than a quad cab).
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 05-06-2015, 05:29 AM   #6
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Ditto on CR.
Is your PowerStroke still in good shape? How many miles are on it?
My 1995 only has 107K miles on it. Runs like a top, pulls well. I have added a bypass oil filter (for excellent filtration, not extended oil change intervals), a large transmission oil cooler, and a magnetic in-line filter for the trans fluid. All I want to do now is add an exhaust brake.
It'll take a LOT for me to part with my 7.3L!!!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-06-2015, 06:50 AM   #7
r carl's Avatar
Lin , Ne
I've had 2 vehicles that CR said they were a POS and to avoid, but they were the most reliable vehicles I've owned.
Old 05-06-2015, 06:54 AM   #8
2009 27' FB International
Silsbee , Texas
I bought new and still own and tow with 09 Dodge 2500 Diesel. (Not a Laramie package). No issues yet. Put new batteries in last year. I change the oil, filter, and Fuel filter every five thousand miles. Changing the fuel filter that often is cheap insurance I hope.
Craig Schrader is offline   Reply With Quote
Old 05-06-2015, 07:27 AM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Use TurboDieselRegister and CumminsForum to investigate your particular model. I read both weekly to keep up with repair and maintenance problems. Mine is an earlier model which was spec'd to avoid problems (2WD, manual transmission) as well as maximize fuel economy. Best vehicle I've ever owned.
Good luck.
Old 05-06-2015, 07:59 AM   #10
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Carver1,
I own an 09 Dodge CTD. I don't know what CR said about this vehicle but here is my take.
The truck is very solid but has an area of concern - emissions. In 2007.5 a new engine was installed into the Dodge truck - 6.7 Cummins tuned to meet the next round of emission standards (2007 thru 2012). The emission equipment allows excessive exhaust gases back into the motor which can allow the variable geometry turbo charger to soot up. My truck had this problem at 40k miles. It was an expensive fix with a rebuilt turbo and second hand diesel particulate filter. I had the trucks computer reflashed with the latest software from the dealership and things have been fine since.
If this is the truck you want to pursue make sure that all the emission equipment is in place and operating correctly. I suggest you pay a dealership or diesel specialty shop to perform a pre-purchase inspection. Many diesel trucks get hot-rodded where you will find legacy problems caused by this abuse.
Many people have removed the emission system (feds do not like this) if they live in an area that doesn't have strict emission inspections etc.... This essentially removes the problem area of the truck.
This particular emission system was used from 2007.5 thru 2012. In 2013 Chrysler went to the emission system that uses DEF fluid and it is considered a better system due to less problems and it allows the engine to perform to a much higher level. Ford and GM also use this DEF-SCR emission strategy.
I don't know what your budget is but if buying this particular brand of truck I would get the 2010 or newer (4th generation) because the creature comforts were much better than those of the 3rd generation (2003-2009).
Also in 2007.5 and newer Chrysler put a 6 speed automatic or manual transmission with integrated exhaust brake. These work very, very well towing a heavy load. The transmissions are considered very reliable at stock power levels.
You may want to check other internet forums or PM me for more info.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-06-2015, 08:05 AM   #11
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
I only have 180,000 miles on my 7.3. Recently had to replace the Turbo, which was a major expense. Looks like I'll keep my 7.3. I admit that the Jake break is on my wish list. Thanks for all the responses.
>>ron<<
Old 05-06-2015, 08:52 AM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I have a 2007 dodge with 6.7 ,90000 miles, just replaced the water pump,no other problems, I don't use it for a grocery getter ......
Old 05-06-2015, 10:41 AM   #13
LeeJ's Avatar
1985 25' Sovereign
Okc , Oklahoma
>>ron<<
I have a 2003 2500 4X4 with 136,000 and it pulls my 1985 25' AS just great! No major issues, a small patch of rust on rear wheel wells.
Lee Johnson
Corriente de Aire
85 Soverign
LeeJ is offline   Reply With Quote
Old 05-06-2015, 11:15 AM   #14
Stowe , Vermont
I have a 2007 Ram, mega cab, Cummings diesel with 110,000 miles. From the get-go, I have been feeding parts into it. In the beginning it was covered by warranty, now it's all mine. Usually a thousand plus dollars a pop lately. Here are just some items - differential, exhaust, turbo issues, jake brake, axel seals, wiring harness for back door, entire radio system (inc. satellite radio), dash board lights, and the list goes on and on (in addition to the normal wear and tear of tires, brakes, oil changes that we all endure. We are now at the big question - keep throwing parts into the Ram or start with something new. If we go with something new, I will probably avoid the Ram because of my history with it. Do our Ford or GM readers have anything that I should consider?
VT Wanderer is offline   Reply With Quote
Dodge Ram 2500 4x4 6.4 Hemi vs 6.7 Cummins ajnjarv Towing, Tow Vehicles & Hitches 60 05-10-2016 11:39 PM
2012 Dodge Ram 2500 4X4 and Stability SteveH Towing, Tow Vehicles & Hitches 24 06-21-2015 09:28 AM
2009 Dodge Ram 2500 Laramie Quad 4X4 Diesel PennyRev Airstream Classifieds 0 04-30-2015 12:01 PM
2009 Dodge Ram 2500 Laramie Quad Cab 4x4 Cummins Diesel Power w/8' bed PennyRev Airstream Classifieds 0 01-28-2015 04:36 PM
2009 Dodge Ram 2500 Laramie Quad Cab 4x4 Cummins Diesel Power w/8' bed PennyRev Airstream Classifieds 0 10-15-2014 12:42 PM
