Old 11-17-2008, 01:02 PM   #1
kmamedia's Avatar
2002 26' Land Yacht 26
Seabrook , Texas
08 Vue Towing
Just got the base plate on the Vue installed $650 plus seperate taillight wiring $250.
Car weight 4025Lbs, 26 ft 02 Landyacht 13880Lbs wet, total 17,905Lbs.
Workhorse P32 chassis rated at 19,000Lbs. Do I have this figured right about being legal?
Also, you must pull the 2amp ign fuse or your battery goes death within the hour. Found this out the hard way, with no help from Saturn Custm Support.
No wounder they are going broke, with techs like that.
kmamedia is offline   Reply With Quote
Old 11-17-2008, 02:52 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Welcome to the forum! I am a bit concerned about your numbers:
Weights: curb weight (lbs) 4,325, gross trailer weight braked (lbs) 3,500 and max payload (lbs) 569
This is from the Saturn Website. According to their numbers tha max for towing weight and cargo in the VUE would be 4,069. Also you need to recheck your trailer weight. A brand new 27FB is 8,800. Look forward to your corrected numbers.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 11-17-2008, 03:08 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Workhorse P32 chassis rated at 19,000Lbs. Do I have this figured right about being legal?Also, you must pull the 2amp ign fuse or your battery goes death within the hour. Found this out the hard way, with no help from Saturn Custm Support.
When "they" wired in the lights on the VUE did "they" install diodes to the VUE wiring? - For 250 bucks, "they" should have.
I have a Saturn SW2 toad, but have never experienced a battery drain, and have never had to pull any fuse or breaker prior to pulling it - the 4 down sure is nice.
Combined weight needs to be less than 19/22K GCVR as per the off-site specs below - The GVWR (15 to 18K, depending on the chassis) is the LY itself, and the GCWR is the LY combined with anything towed. If you are at 17.9K for the combined weight, you should be OK.
Have you actually weighed the VUE or the LY ready to travel?? The weights you have quoted above seem to be really light (both the LY and the VUE).
If you haven't, please post the discrepencies here to share the "actual" vs the "stated" single and combined weights - you may be really surprised at the actual weight. Usually, most of the "advertised weights" - not to be confused with the ratings- of the MoHo's are less options and liquids. It's ALWAYS best to weight them yourself at a CAT scale - then you know for sure! Be sure to have the MoHO "set up" for travelling (full fuel, normal water, and propane, clothing, tools, and "other stuff" when you weigh it.
Land Yacht (gasoline models only)
Floor plans: 3
Floor plans with slideouts: 0
Dimensions: exterior length (min/max), 26 feet/33 feet 5 inches; exterior width, 96 inches; exterior height with roof A/C, 10 feet 2 inches; interior height, 6 feet 7 inches
Wheelbase (min/max): 158.5 inches/208 inches
Weight ratings: GVWR (min/max), 15,000 pounds/18,000 pounds; GCWR (min/max), 19,000 pounds/22,000 pounds
Tank capacities: fuel (min/max), 60 gallons/75 gallons; fresh water (min/max), 44 gallons/60 gallons; gray water (min/max), 23 gallons/36 gallons; black water (min/max), 24 gallons/34 gallons; LPG (min/max), 19.5 gallons/82 pounds; 25 gallons/105 pounds
Water heater capacity: 6 gallons
Furnace rating (min/max): 30,000 Btus/34,000 Btus
Chassis/engines available: Workhorse P30 Series/Chevrolet 8.1-liter Vortec V-8
Base suggested retail price: $94,885
Options: Dual-pane windows; VCR or DVD player with video control center; 10-cubic-foot refrigerator with ice maker; three-burner cooktop with oven; 130-watt inverter; Fan-Tastic Vent fan in bedroom.
Highlights: Patio awning; driver's door with power window; convection-microwave oven; 13,500-Btu air conditioner with heat strip; 5-watt solar panel; Fan-Tastic Vent fan with rain sensor; 5.5-kw gasoline generator; heated holding tanks.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-17-2008, 03:09 PM   #4
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Numbers
My 27 FB is an 05. The plate on the trailer says 7600lbs GVWR.
When I weighed it last month the steering axle on the truck (3/4 ton GMC) was 4380 lbs, the drive axle was 4660 and the trailer axle was 6140, for a total weight of 15180 lbs.
I hope that someone else will post some numbers so that we can compare.
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-17-2008, 05:14 PM   #5
RBolton's Avatar
Belington , West Virginia
Appears to be some confusion. I think kmamedia is towing the Vue behind a motorhome.
RBolton is offline   Reply With Quote
Old 11-17-2008, 05:33 PM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up yepper
You are so right..
It's a MOHO
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-17-2008, 06:31 PM   #7
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Does the Vue really weigh in at 4000lbs? or is that GVWR on door tag.
It seems a bit much. I figured maybe 3300lbs max.
mustang is offline   Reply With Quote
Old 11-30-2008, 04:44 PM   #8
kmamedia's Avatar
Seabrook , Texas
I weight the Motorhome and the 08 Vue together on a truck scale, the weight is correct.
I was not talking about what the vue can tow.
Just got back from a 600 mi round trip to Fredrickburg,Tx and was impressed with the pulling power of my 8.1 vortec.
I did have aproblem with the ignition switch on the workhorse chassis.
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Help with Towing CAAR Hitches, Couplers & Balls 3 07-18-2006 02:42 AM
Vista Vue Windows Stagehand Windows & Screens 10 10-29-2004 06:13 PM
Towing perfuse2004 Tow Vehicles 5 10-01-2004 04:51 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
