Old 04-09-2008, 04:11 PM   #1
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
'08 GM 2500 trailer wiring / safety issue?
Bought an '08 GM 2500 for towing, with HD tow package, integrated brake controller, including "Heavy-Duty Trailer Wiring Harness Package" etc. All set to pick up my Airstream on Saturday. Well, not quite ...
Reading the owner's manual, came across this, buried on p. 4-91: "The fuses for the [trailer brake and battery feed] circuits are installed in the underhood electrical center but the wires are not connected. They should be connected by your dealer or a qualified service center."
In other words, plug in the trailer fine, but the brakes won't work! (nor will the coach batteries charge.) Called the selling dealer. Was told that this was not done as part of delivery prep, and that they in fact don't and won't do it: "We don't do that - it's a liability issue." WTF??!!! liability issue indeed! - how about no trailer brakes and the unsuspecting driver? THAT sounds like a liability issue to me. Went to a second dealer. They were willing to TRY to help, but the service mgr. cannot find a procedure on their GM computer for locating the wires, connecting the wires, etc.
Does anybody here know where these mysterious wires are or how to connect them? I'd be happy to do this myself if I could figure it out ... it seems pretty clear that the General is not going to be of help!
Thanks.
Ryanh
AirsDream is offline   Reply With Quote
Old 04-09-2008, 04:19 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
AirsDream,
I have an '06 GMC 2500 with the HD trailer package and all I had to do was install a 40 or 50 amp fuse in the underhood fuse box. On mine there was a "dummy" fuse in the spot with a sticker over it. Then I hooked up the brake controller with a cable provided with the Tekonsha Prodigy I purchased. All I had to do was remove a cover on a box on the cab side oft he firewall and plug it in. That was all I had to do. Don't know why they would have made it more difficult to hook up an '08.
I think all you will have to do is put a fuse in the underhood fuse box and the extra wiring is for a 5th wheel set up as decribed below...
There was an extra wiring harness that came with mine for use in wiring a 5th wheel trailer, but that is not needed. That one gets plugged into a jack that is attached to one of the frame rails on the dirver side somewhere under the bed of the truck.
Hope this information helps.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-09-2008, 04:24 PM   #3
AirsDream's Avatar
1999 23' Safari
Thanks for the info, but this situation is different; the brake controller came built-in, and the fuse(s) are there ... no dummies, real fuses. But the wires are not connected and are hidden somewhere. I have no idea where or why they are hidden ...
Old 04-09-2008, 04:30 PM   #4
DEITZ645's Avatar
Ryanh,
Are you sure the extra wiring isn't for the 5th wheel set up? You could always take a multi-meter and meter all the pins on the 7-pin plug on th hitch. I think the positions are labeled on the dust cover of the plug recepticle. Start the truck and put the ground pin of the multimeter on the ground pin of the plug and the positive pin of the multimeter to the brake pin on the plug and then have somebody step on the brake. If you get current then you are set.
I guess you could also use a test light to accomplish the same thing.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 04-09-2008, 04:31 PM   #5
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Try this:
DEITZ645's info wont help if you have a 2008. From 2007, GM Full Size trucks there is no longer an electric trailer brake controller pigtail harness.
Since you have the intergrated controller, you are looking for the "AUXILIARY POWER" feed. Look at steps 8-8.4
Chevrolet Questions & Auto Repair Information > connect tlr brake controller 2007 silver > Chevrolet Questions
Hope this helps...
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 04-09-2008, 04:53 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yep!
Thank you Bambi Bandit. Your link showed exactly what I had to do with mine.
Paula
Foiled Again is online now   Reply With Quote
Old 04-09-2008, 05:29 PM   #7
DEITZ645's Avatar
Glad I Have An '06
Geeez, I guess I should be glad I got an '06. Hooking up the trailer breaks was a breeze for me. One plug, one fuse, and done.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 04-09-2008, 06:29 PM   #8
AirsDream's Avatar
1999 23' Safari
Thanks, B-Bandit ... I just came back from my garage, where I did in fact locate the auxiliary power feed wire(s) in question, but NOT the brake wire .... and another issue is that my machine has JL-1 (Integrated Brake Controller), so these instructions don't apply ... as the answer man said, "The information for a truck with (JL1) will be in my next post. There is a difference in the wiring. Thanks"
So now all I've got to do is to find the "next post" which ought to get me to where I'm going. Terrific lead. Thanks very much. If I can't find the "next post" I may write back to you for more help!
Old 04-09-2008, 07:53 PM   #9
holland , Michigan
Now this really sounds like a typical GM stunt. Why are they so small minded in thinking this would some how save a penny, and not realize how they just pissed off a customer who just spent 45k plus. Pitiful!
safari 28 is offline   Reply With Quote
Old 04-09-2008, 08:02 PM   #10
Images: 12
Try this forum
This thread / forum may be of better help to you with quicker answers and ideas:
Trailer/5th wheel wiring on 2008 LMM? - Diesel Place
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
07 Tundra vs F250 vs Dodge 2500 vs Chevy 2500 outthere Tow Vehicles 248 01-13-2011 08:48 AM
Trailer Life Mag Airsteram articles in May 06 issue munimula Airstream "In the News" 1 04-13-2006 04:48 PM
Trailer tire safety article 83Excella Tires 0 08-14-2002 08:44 PM
