Old 10-17-2008, 10:52 AM   #225
Wayward's Avatar
Cary , North Carolina
Originally Posted by Journalist View Post
Aftermarket Porsche Cayenne gears cost nearly as much as a good used HD pickup.
wow - I'd have to reconsider that cost equation is that case
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Raleigh, NC
Old 10-18-2008, 08:48 AM   #226
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Apple
Originally Posted by BillTex View Post
Yeah, but...there's Macouin apples and there's Fuji apples...
This Apple was grown in Indiana...............
Ed Emerick is offline   Reply With Quote
Old 10-18-2008, 08:49 AM   #227
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Porsche Cayenne Turbo vs BIG Diesel
Thanks all.... my Cayenne has lot's of torque and will easily pull the load. Unfortunately, the power is from about 2200-4500 rpm. This means it runs in 5th gear up hills into a headwind. Also it is adding about 5 - 8 lbs of turbo boost. Without a trailer it will accelerate from 0 - 100 mph in about 12 - 13 seconds... and 1 gallon of Premium! While changing the final drive ratio is an interesting option, I think the comment about the cost is inaccurate. To change the final drive ratio on a Porsche Cayenne would cost about the same as a new tractor which would tow nearly 35,000 lbs. >$100,000.
All of this discussion is fun and I enjoy it fully. I also appreciate our varied opinions. One of my girlfriends keeps telling me to get a Ford or I will be sorry. I keep telling her that as a woman over 65 years old, I am going to get what I want, and the seats and color are important. They will all pull trailers if you get a big enough truck.
So, once I buy one, I will report back and will most likely see some of you on the road. Or... in the paddock at Road America, VIR, Road Atlanta, etc. Mine will be the Airstream with the Porsche logo on the tail...
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-18-2008, 09:32 AM   #228
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm sure I posted this somewhere, maybe even way back on this thread, but since the thread has Toyota, Ford and Chevy being asked.....here are a few videos to consider as you purchase tow vehicles....being a GM man myself, I was a bit unhappy to see GMs showing, but clearly, I was not at all expecting to see Toyota's showing...clearly food for thought:
YouTube - Ford F150 vs Toyota Tundra - Frame Strength
YouTube - Ford F150 vs Chevy vs Toyota - Bed Bounce
Old 10-18-2008, 10:23 AM   #229
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
In the frame strength video, the speaker refers to "our" Ford frame, so it sounds like he works for Ford, or the outfit that did the tests was hired by Ford. Note also that there was no comparison with Dodge or GM, so if they used the same test, maybe those frames would deflect less than Ford's. In the "bed bounce" video, no Dodge.
I haven't a clue what these tests prove, if anything. Any testing should be done by an independent company. If those tests are accurate (a big "if"), perhaps a frame that flexes more has a good purpose.
I know my Tundra rides fine with or without a trailer. The way the American companies are doing, there may only be Toyotas and maybe General-Ford Motors some day (Chrysler completely swallowed or owned by Hyundai or Tata).
Gene
Old 10-18-2008, 11:52 AM   #230
Aluminut
2004 25' Safari
. , Illinois
Though I agree, the bottom line is 3 vehicles went through the same tests. I have personally seen the Toyota offerings on the pothole riddled roads here in northern IL. I saw a Toyota pickup do the exact same thing on a series of bumps and potholes on a piece of road near the house. I then took my dad's 2000 2500 Silverado and followed behind my brother driving it on the same road. The results were identical to that of the video. The GM had some flex, but significantly less than what I saw on that Toyota. Regardless of who did the test, it would appear to me there is some merit in what is in the linked videos.
Old 10-18-2008, 12:41 PM   #231
Gene's Avatar
Maybe (probably) I wasn't clear. Flex maybe good. A rigid object will not absorb shock the same way a frlexible object will. Maybe flex helps hold the road better, or makes the contents not bounce as much. There's too much flex, not enough or just right depending on the goal of the manufacturer. I don't know the answer. I expect there are different answers depending what kind of ride you want a truck to have. All these companies test these things to achieve a certain goal. Ford wants one kind, GM another, etc.
Gene
Old 10-18-2008, 02:14 PM   #232
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Either way,,, As I said before the TEST is Crap.... Your just looking at a frame.... and putting weight on it... You need the rest of the truck to be an accurate test... And who in there right mind would drive over big bumps like that at that speed with a trailer or without....>><<
Yes the frame bends and it is flexible... But I'm with Gene. I rather it flex than stay ridgid and bounce the crud out of everything....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-18-2008, 03:57 PM   #233
Aluminut
2004 25' Safari
. , Illinois
I respectfully disagree on both counts. Obviously folks who own Toyotas will most likely feel that way.
Flex in the back end in this manner is NOT considered a good thing, and how could it be? Frames moving drivers to passenger side and back good flex? If it can flex that much just going over bumps.... How can you simply dismiss the test so quickly? Clearly there are rough roads and of course going off road. I'm not saying it has to be like one solid piece of steel, heck the GM truck didn't do as well as the Ford and I'm not happy about that, but as I said before, I saw a Toyota pickup do the same thing, went back to the same street and took a Silverado on the same road.....mirrored the test.
Now if you are comfortable towing heavy trailer with that much flex, more power to you, but the test IMHO is valid, I duplicated it in some small way and I can't see that much flex being such a good thing....maybe when it comes to semis with 12 tons and such, but for our applications, I can't see the side to side flex being beneficial in any way....sorry Toyota owners.
Old 10-18-2008, 04:24 PM   #234
purman's Avatar
1968 28' Ambassador
Your welcome to your opinion Silvertwinkie.... IF you hate Toyota that much just say so..... But back to my point..
WHO WOULD DRIVE THAT FAST OVER BUMPS THAT BIG WITH A TRAILER OR WITHOUT ONE.
AN IDIOT or someone who doesn't like their truck...
I have 2 Toyota's, '75 dodge 3/4 ton, Jaguar and a Jeep, I've towed with my Father in laws '07 3/4 ton dodge and still prefer my Sequoia for towing my AS...
Better ride, more room for the family, and plenty of power, and no frame twisting as I don't go over bumps like that at 35+ mph.....
Until you tow with one, which I guess you haven't, I find it funny your making an assumption on two skewed tests...
I wouldn't worry about you truck flexing at all... Unless you like to drive fast over bumps and I'm guessing you don't.... I did in my '85 blazer but that was to get air, and I was young and a little more reckless....
Until I here about a frame snapping on a Toyota I'm not worrying about it...
PS you still need a whole truck for an accurate test. It's like testing a house strength with just the framing up... It's not as strong as when the whole house is done... Same with a Truck or SUV...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-18-2008, 04:59 PM   #235
purman's Avatar
1968 28' Ambassador
I just got done reading the first few pages of this tread again...
Silvertwinkie and others feel The Tundra isn't a good TV.. But it seems everyone who has one thinks it is....
It's Not a 3/4 ton diesel and doesn't claim to be.... If you want a diesel you will have to go with one of the American 3 well Toyota is made in America too.. Different topic...
IF you feel safer in a 3/4 ton or 1 ton then get it, and be happy, I'm happy with what I have, Wish I could tow with a truck but I need the room for family and the Suburban just isn't reliable as toyota... "mine and others opinions" I do know Suburban owners who have had no problems but more that have....
I found it funny, someone said Ford is the #1 selling truck in the world... They must not travel abroad much... I go to England and Europe about every other summer as we have family there... Don't see many Ford trucks, in fact I can't ever remember seeing one in England at all.. People don't drive trucks around over there... Only builders and then there just small 1/2 ton trucks... Gas is to expensive over there...
A Diesel motor will out perform a gas motor in towing there is no arguing that point
So why compare a Tundra to a 3/4 ton Diesel and why Trash the Tundra if you have never towed with one.. Everyone who does seems to like it....
Now When Toyota builds a 3/4 ton Diesel Ford will no longer be #1
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-18-2008, 05:07 PM   #236
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
The Tundra may very well be a wonderful TV, and built in the USA.
To each their own.
I have a long memory.....Sorry.
PFC.....
“After all these years the reason I continue to love Thanksgiving.....I still sit at the kids table.”
RLC
but I’m the Husband, so we went to Cleveland.
RLC
Old 10-18-2008, 05:11 PM   #237
purman's Avatar
1968 28' Ambassador
I remember they had a 1 ton in the 80's our Friend in Trinidad has one... not a very big bed on it, I laughed when he said it was a one ton but it really was.... two wheel drive to boot..... Don't even know if you could put a ton of stuff in the back it's so small...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-18-2008, 05:40 PM   #238
Aluminut
2004 25' Safari
. , Illinois
Jason, I never said what you claim I've said. I have said many times over Toyota is a good truck and useful to a point as is any vehicle. If you recall the GM truck didn't fair the best either. I'm not taking it personally and I have a GM truck. Bottom line the reality is what it is. I offer the info to the masses to interpret the way they'd like, but please don't read or misquote me. The Toyota is a useful vehicle and I was about as shocked as anyone to see the results. In a free society one picks what they feel is best. Others may not agree. I think if we keep it accurate and constructive no one's feelings get hurt.
I don't know about you Jason, but roads here in Illinois are not all that great. Maybe in your neck of the woods there are no washboard roads or roads in need of serious repair. We have them here and if I can duplicate what's in the video, it does raise the question, which I think is relevant to the conversation. Identical to the test in the videos? Not exactly, but enough were I can take a truck to test and get the same results....and it's not a test track, it's a public road around here...and my point was that you don't have to drive fast to see this phenomenon. Just cross a rough railroad track and you can see it in a much smaller form.
It's true Detroit has been lazy and that they are now reaping what they sew....but just for the record, Toyota too isn't doing all that hot in the truck arena either. To me, Toyota's issues seemed to start when they started building here....same with Honda. I have no ax to grind with either...offer my opinion and let folks make their own decision and draw their own conclusions.
Dodge Ram 2500 Diesel Foiled Again Tow Vehicles 23 10-18-2007 10:01 AM
Chevy 2500 HD question? rebel beck Tow Vehicles 35 03-06-2007 08:31 PM
Titan vs GMC 2500 ? Daniel LOUIS Tow Vehicles 18 08-27-2005 03:45 PM
Suburban 2500 springs George Jr. Tow Vehicles 9 07-22-2005 11:59 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 03:34 PM
