Old 08-05-2004, 11:00 AM   #1
'02 Yukon XL for Towing
I'm curious to know if my vehicle will be ok to tow an A/S with. I'm considering a 25' Safari ('04 or pre-owned), but have also looked at 28' Classic models (pre-owned). Any suggestions or comments would be greatly appreciated.
Sandy H is offline   Reply With Quote
Old 08-05-2004, 11:09 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
3/4 ton? 1/2 ton? Gears, engine, etc all would help get you the answers you're looking for.
Old 08-05-2004, 12:55 PM   #3
Sorry. Guess I'll have to get out my owner's manual & look for all those things.
Old 08-05-2004, 02:21 PM   #4
Aluminut
2004 25' Safari
. , Illinois
Actually the owner's manual might not help too much. It mostly covers generic type things.
Inside the glove box, there will be a bunch of 3 character codes on a sticker like label:
You're looking specifically for
MT1 or MT5 (that is the 4L80e transmission code for either a 6.0L or an 8.1L)
LQ4 or LQ8 (6.0L engine or 8.1L engine)
G80 (Locking differential)
Z82 (Trailer package)
GT4 or GT5 (3.73 or 4.10 gears)
My fav would be MT1, LQ4 (better fuel economy- less power than LQ8), G80, Z82 and GT5.
If you see these codes on the sticker in the glove box, you should be in good shape. If you have none, then I would say you might need to modify the truck a bit and/or consider a different truck if it has the 5.3L engine.
Hope this helps a bit.
Old 08-05-2004, 06:24 PM   #5
If you have the 3/4 ton version, with either the 6.0 or 8.1, you are just fine. I have an 03 3/4 ton Suburban, 6.0 and 3.73 that I use to pull a 25 ft Sovereign (about 6,000 lb). The combination works very well.
alan is offline   Reply With Quote
Bambi 19',2000-2003 pro and cons Hubba Airstream Trailer Forums 13 01-22-2013 12:47 AM
TOW VEHICLE--Help me decide!! 96 Yukon or 01 GMC Shelby Copeland Tow Vehicles 9 04-23-2004 07:52 AM
Does AS defy conventional thinking? mikey Towing, Tow Vehicles & Hitches 3 08-19-2003 05:41 AM
Towing a 25' Airstream with a Yukon? HowardD Tow Vehicles 16 07-04-2003 02:20 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
