Old 02-08-2015, 08:29 AM   #1
Annapolis , Maryland
Woodstove placement
I would like to hear from anyone who has installed a woodstove in their trailer. I haven't yet purchase a trailer, but it will be 24' or under.
(1) Where could I find space to install one?
(2) Could one be installed in lieu of the stove/oven?
starwolf is offline   Reply With Quote
Old 02-08-2015, 08:37 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Use the SEARCH Function - under that Select GOOGLE and just type in "Wood Stove" - it will bring up numerous threads. Some have done quite nice installs - but don't forget it's another hole in the roof!
http://www.airforums.com/forums/f459...ve-100085.html
http://www.airforums.com/forums/f462...e-44907-4.html
Frankly I wouldn't do it. There are a few very nice, very very small wood stoves out there - most of which cost over $1000! And a small wood stove doesn't hold enough fuel to last the whole night - so if you have to get up and feed it ever 3 or 4 hours how much good is it?
I do like the look and feel of the flames - but did you know there are marine propane or diesel stoves that can provide that (and keep a teapot warm on the top? One even had a flexible two layered hose/chimney that brought in cold air to the combustion chamber and exhausted the spent air to the outside - very efficient and safe!
You'll sacrifice a good deal of floor , wall and chimney space - and the smaller the trailer the more significant losing even 1 cu. ft. can be.
Paula
Old 02-08-2015, 09:24 AM   #3
r carl's Avatar
Lin , Ne
I've wondered about small coal stoves before.
Old 02-08-2015, 10:05 AM   #4
Alcoa Roller's Avatar
Dallas , Texas
I would think the heat from a wood stove would run you out of there except in the most bitter of cold. Unless this would be a permanent park job for a hunting camp in an extreme location I would not do it. But yes it can be done and yes people have done it.
Alcoa Roller is offline   Reply With Quote
Old 02-08-2015, 10:05 AM   #5
1994 30' Excella
Mississauga , Ontario
have one in my house.
Would never think of one in my trailer. Unless parked to die(never going to move).
To much work with fuel and ashes etc.
Al
Al and Jean
TAC ON-3
Old 02-08-2015, 12:18 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If wood stoves were great in a trailer, most of us would already have one.
We heat with wood at home, but would never consider it for a trailer. Too many good other options.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 02-08-2015, 03:09 PM   #7
The reason I am considering a woodstove is because I need to avoid gas, oil and propane for health reasons. If I'm living in the trailer full-time and need to be in a place for income purposes that's very cold in the winter, I need backup in case the grid goes down for several days or longer. i.e., a generator is not an option.
So experienced answers are much appreciated....
Old 02-08-2015, 03:19 PM   #8
1972 23' Safari
Camas , Washington
check these out
Unforgettable Fire, LLC | Kimberly™ & Katydid™ Wood Stoves
Pams72 is offline   Reply With Quote
Old 02-08-2015, 03:34 PM   #9
1975 31' Sovereign
Munich , Bavarian
Images: 16
Hi look at this great guy http://jonsonglobetrotter.de/ he is living on the road since 30 years, he lived in many let me say rv or trailer. Now he is heating his trailer ( no AS ) with a marine wood stove. (Uk) He is doing great, and for me If I would live in a Airstream or so It would be the first work what I would do. To have the choice heat both way is be wounderful. All the best
nmayer1 is offline   Reply With Quote
Old 11-28-2015, 09:08 AM   #10
1976 Argosy 26
Squamish , British Columbia
I'm installing a navigator sardine in my 26' 1976 Argosy as we speak. Lucky for me, I had a deceased propane fridge right next to the door, which leaves me a space for my stove to sit on a 2 cubic foot wood box, with the chimney going literally directly up into the existing vent from the fridge. Even better than that, there's a low hatch that used to be for accessing the pilot light and such on the fridge, and I'm able to Jimmy a small pipe to add a fresh air return (this has been the biggest controversial issue surrounding CO emissions in an enclosed space) this also stops the stove from suckling air in from other parts of the trailer.
I've heard tonnes of nay-sayers chirp about it getting way too hot, or having to stoke the stove every couple hours, but the reviews I've heard of this particular little guy (The Navigator sardine) is that you can get 6-7 hours of burn time out of a proper load when you use good quality wood/hardwood lump charcoal. I don't think alot of these people understand quite how tiny these little units actually are, the issue of cooking me out of my trailer has yet to be proven. I'll gladly be the guinea pig.
Perhaps I spoke too soon, but it's looking like a seamless installation so far. I'll let you know how well it worked in a week or 2 when I've broken her in.
P.S. Ive been living full time in this vintage beauty on the West Coast of Canada for 2 years now (with my 9 year old daughter). Electric heaters just don't cut it when the cold snaps hit, and propane heat causes WAY too much condensation=mold.
Liesl is offline   Reply With Quote
Old 11-28-2015, 09:27 AM   #11
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Really interested in this, as a wood stove is on the list of things to do - after this year's composting toilet and next year's solar upgrade.
I've seen some wonderful installs and have lived with wood stove heat (with no fresh air return) on a boat in the UK, where one well placed stove kept a 42' narrowboat (also known as canalboats) toasty all winter long.
Would love to see some pictures of people's solutions.
andreasduess is offline   Reply With Quote
Old 11-28-2015, 10:05 AM   #12
Toronto , Ontario
Originally Posted by nmayer1 View Post
Hi look at this great guy jonsonglobetrotter.de he is living on the road since 30 years, he lived in many let me say rv or trailer. Now he is heating his trailer ( no AS ) with a marine wood stove. (Uk) He is doing great, and for me If I would live in a Airstream or so It would be the first work what I would do. To have the choice heat both way is be wounderful. All the best
Oh my lord.
This guy is insane. I love how far and wide he travelled and the vehicles he used. Tractors. Trailers. Circus wagons.
The site is in German, but well worth visiting. A free spirit indeed.
Old 11-28-2015, 10:16 AM   #13
JimGolden's Avatar
1977 31' Excella 500
Anything heavy, mount it ahead of the axles. probably best location is just slightly ahead of the front axle so that it's in the proper place, but not so far forward as to really bump up your tongue weight.
I'd cut the hole in the side of the shell, not the roof. Run your exhaust out the side and then turn it up. I'd also make a little visor or "eyebrow" from aluminum and rivet to the skin above where the pipe hole is...kind of like the one above the entrance door.
Be careful not to set anything on fire. Other than that, have at it
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 11-28-2015, 10:53 AM   #14
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Best of luck,
I like that...
Here's a picture of a 1989 34XB that had a wood stove in it.... vented through the roof. I like the suggestion of venting through the side wall. As for too much heat for a trailer..... that's what the windows are for....
I love wood heat.
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Winter Living off grid in Vermont with woodstove cmell Winter Living 59 10-28-2009 04:02 PM
Jack placement Chitown AirStreamers On The Road... 10 10-07-2003 08:56 AM
Deadbolt placement? Gunnyusmc All Argosy Trailers 0 09-12-2003 06:10 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
