Old 09-22-2007, 11:02 AM   #1
Jackson , Wyoming
winterizing
I'm new to A/S forums - not sure what is meant by "winterized" - are some models better insulated than others - and if so, what is this option called?
twall7 is offline   Reply With Quote
Old 09-22-2007, 11:29 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Winterizing is the term we used when preparing our trailers for winter storage. Dependent upon the age of an Airstream, the type of insulation used will vary although it's all fiberglass based. Any new Airstream trailer today will have the same insulation. The slideouts do use foil backed insulation in the floor (that's what I've been told by A/S).
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-22-2007, 11:51 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Sooner or later - I knew someone would mention that nasty "w" word.....
Old 09-22-2007, 12:56 PM   #4
2005 19' Safari
Inyokern , California
Right. Winterizing is definitely the "W-word" that Airstreamers whose TTs are outdoors in 4 season climates hate to hear. I have a 16-point procedure that I run late in November. Your owners manual should have a basic version, but you will add your own steps with practice. Key concepts are not leaving any water in your tanks or lines to freeze, causing costly repairs, and maintaining your batteries.
larreat9905 is offline   Reply With Quote
Old 09-22-2007, 02:24 PM   #5
Alaska1966's Avatar
1966 17' Caravel
Fairbanks , Alaska
In Alaska if we leave water in the jacuzzi, Airstream, or dirt in the flower pots, they expand with the cold weather and snap...repairs in the spring time when we realize pipes are broken or pots are cracked.
We actually froze here last night. Winter is on it's way soon....
Alaska1966 is offline   Reply With Quote
De-winterizing frozen chosen Winterizing, Storage, Carports & Covers 9 12-06-2007 07:14 PM
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 02:44 PM
Help with winterizing snpotratz Winterizing, Storage, Carports & Covers 31 12-18-2006 08:27 PM
Winterizing jacobjames Member Introductions 1 10-13-2006 03:32 PM
Winterizing... PWRSTRK Winterizing, Storage, Carports & Covers 15 10-09-2004 08:30 PM
