Old 01-28-2003, 07:39 AM   #85
Rubyslipper's Avatar
1995 30' Limited
Warsaw , Missouri
Winter Living
Today they say almost 50 and chance of rain.Now the roads over here will be sheet ice for sure.When we had our big freeze up a few days back and found the hose and valves frozen.We found that the hose connector end that comes out from the trailer is off round now due to the pressure of the ice that formed.Hubby thinks he can reshape with a pair of channel locks??I have explored the idea of getting one of those heated tank pads to apply to the bottom of the holding tanks.Guy at the RV parts store says they work well....but those fruit cakes will tell you dogs can fly too!Anyone ever heard for sure if those pads are an ok thing to keep tanks from freezing???
Rubyslipper is offline   Reply With Quote
Old 02-04-2003, 08:52 AM   #86
jburnes's Avatar
Question Checklist For Winterizing From Scratch?
Hi:
I'm seriously thinking about getting a 1977 Sovereign or something similar. I may use it for temporary shelter in Wyoming or Nevada while I build a house. This house building may well last right through winter even if I start in early spring. I noticed Ruby's problems with Winter weather and I thought it best to ask if anyone has a winter weather checklist?
I mean to live in it during the Winter and not just 'winterize' it.
Jim Burnes
jvburnes@yahoo.com
jburnes is offline   Reply With Quote
Old 02-04-2003, 09:18 AM   #87
Thumbs up A-frame
Jim,
I would suggest first building an A-frame that would shelter your trailer from the elements. Maybe even having some spaced horizontal boards to act as a wind buffer, but not too close to trap in the furnace exhaust.
I would also get a 100 Gallon LP tank and run the furnace. At least you're already in a low humidity area and this will help with condensation.
John
John is offline   Reply With Quote
Old 02-04-2003, 09:29 AM   #88
"In my Avion they used one of those spray foam insulations...I wonder why Airstream never went that direction?"
I understand that over time the slight movement of the inner and outer skins from temperature changes as well as traveling will crumble such insulation to dust. True? I don't actually know.
Many trailer manufacturers have found that fiberglass batts settle in the walls over time. This is why Airstream uses a continuous batt from the roof to the floor, glued to both the inner and outer panels.
It does seem to me that one thing they COULD do at minimum extra cost (and weight) is stuff in a heavier batt.
Mark
Old 02-04-2003, 10:45 AM   #89
1995 30' Limited
Warsaw , Missouri
Winter Living
Hi Jim,go to www.rvsafety.com/wintercamp.htm
there is some valuable info there on winter camping.Also a site www.workersonwheels.com.. provides some great insite on winter camping since the husband and wife often ruff it out in Alaska.We are new to this RV living and are learning all the time.Our first priority is keeping ourselves and our A/S from freezing.We have made the propane guy lots of $$$$.Should we ever loose power from ice storm we will have a problem since we do not have a generator.I think good old horse sence is a good thing to have on board.Prepare for the worst case scenerio.
Old 04-21-2003, 09:24 PM   #90
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Rubyslipper
I'm wondering how you faired the rest of the winter, now that spring is here? Please update us....hope all is well!
Shari
Old 04-22-2003, 08:21 AM   #91
1995 30' Limited
Warsaw , Missouri
Winter Living
We made it ok.2 water freeze ups.The first was prior to the heat tape being in place and the second was when "someone" got anxious for spring and unplugged it. The windows have all the plastic off and fresh air is wonderful.Also have removed all the skirting frames we made and there was dry ground underneath so moisture did not build up as one suggested in the beginning.Missouri had over 14 inches of snow which was unusual they say.We did use a 100 lb botttle of propane a week at $38 a bottle.Having the heated mattress pad was a blessing and highly suggest it to anyone as nuts as we are.The Fantastic Vent that opened at 2 am in the middle of a blizzard has been repaired.Turned out that too much condensation had caused the control panel to short out.We find out this week about the duration of our contract.We have decided that if he stays the projected 4 years we will be selling our "cream puff" and building a small cabin.The A/S needs to be flying down a highway going someplace all the time and not setting put.As much as we love it,its best to set her free. Peace to all.Rubyslipper
Old 01-22-2006, 01:52 PM   #92
prettytall
Tallville , California
howdy!
saw this thread refered off another thread on winter living.
im looking to remodel an older airstream, not restore, but moderize and build to my taste. quite possible i wil be wintering in some hardcore places.
i have built a few houses, a couple of products i like are radiant flooring, small boilers and blow-in insulation. i wonder if these would work well in a trailer situation? has anyone tried it?
this stuff is great, Warmboard-
http://warmboard.com/explained.html#whatis
and a small boiler to run the Warmboard and supply domestic hotwater
http://www.blueridgecompany.com/radiant/hydronic/325
then use BIBS (Blow In Blanket System) insulation in the floor and walls and one could be pretty toasty eh? the radiant floor setup could help with freezing issues?
thetallone
tallone is offline   Reply With Quote
Old 01-22-2006, 03:30 PM   #93
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
skirt your trailer with 1" thick styrofoam it will take about four and a half 4 by 8 sheets of styrofoam. By doing this it will help to keep your floor much warmer and you will use less propane. At each seem of styro on your skiting use duct tape to hold it together messure 8' leangth's messure from bottom of trailer to the ground cut styro leangth wise to your messure ments and just wege the piece between trailr and ground dose not half to be super tight fit just so it is snug enough to help hold the piece in place. do this all the way around your trailer and you will notice the diffeance in comfort and also $$$$$$ savings in propane I have done all this and have delt with -20 temps with no problems.. I am full timing it in my Airstream so if you have any ? contact me and I will do my best to help you out. Also check out my post in member introduction ( winter living in a Airstream)
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 06-23-2007, 09:49 AM   #94
Sierra Papa
2007 25' International CCD
Preston , Idaho
Winter camping question: Is it reasonable on a 3 or 4 day outing to fill the grey and black water tanks 1/3 full of anti-freeze? We would drain the freshwater system and carry water in jugs inside the trailer. We would use the jugs for cooking and to flush the toliet. We anticipate a few ski outings into Wyoming where temps can dip to -40F. Is this a workable idea? I have a heated shop I can pull the trailer into upon arrival home to melt and thaw.
Sierrapapa is offline   Reply With Quote
Old 06-23-2007, 10:21 AM   #95
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
An Aluminum tent. Does work. Are you planning on using the furnace? Using RV antifreeze in all the lines and in the holding tanks will work. Drain the water tank put a little there and pump it into the lines. Drain hot water heater. bypass it and run the hot water. Put some down the sinks and shower. I have stayed in my AS down to about +10F. Still fully useful. The furnace ran constantly.
Michelle TAC MT-0
Sarah, Snowball
Old 06-23-2007, 11:03 AM   #96
Sierra Papa
Preston , Idaho
Michelle, thanks for the label of the "aluminum tent" I like that. We are thinking of parking at places like the bottom of Teton Pass during the winter and some places in the Colorado Rockies, but only for 2, 3 or maximum of 4 days at a time and really using the AS as a ski base camp. Just doing my homework so I will be ready to roll come January of 08.
Old 06-23-2007, 11:19 AM   #97
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Most RV antifreeze is pre-diluted and will be ineffective if diluted further (in the grey or black tanks). You don't need it in these tanks if you drain them and don't use them. I'd never put it in the freshwater tank, even though it isn't poisonous because we drink out of there and it tastes nasty. The couple of gallons of water you can't get out with the bottom drain won't hurt the tanks when it freezes. Use the intake side of the water pump to get antifreeze into the lines (including the toilet sprayer) and use a water heater bypass to prevent needing 6+ gallons there. Just drain the water heater with the plug. Pour enough of it into the sink and shower drains to overcome dilution in the traps.
Since you aren't going to be using the shower (use the campground's), sit a self-contained Porta-Potty in the shower. That's what we do when we use our semi-permanently winterized 34 now. Use dishpans in the sink rather than let water in the drains and just toss it out on the ground like a tent camper.
Honestly, I don't believe our furnace could keep up with -40F, and the damage to the Airstream from condensation and road salt would far outweigh the cost of motels as far as I'm concerned.
Maurice
Old 06-23-2007, 11:32 AM   #98
Sierra Papa
Preston , Idaho
Road King, I appreciate your insights. I was planning on not using the freshwater system, but was hoping to use the blackwater and greywater by the antifreeze method. I do see that the porta-potty idea would work, I had just hoped I could use the built in system except for my fresh water which would be in jugs. I agree motels would be cheaper and in fact I think motels would be cheaper than the whole AS deal for my overall use, however I am just tired of motels, and for the winter back country sking and some other activities the dammed motels are not in the right locations. Hence the AS.
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Winter camping - low temps etc. Mariner On The Road... 5 12-12-2003 08:45 PM
winter camping wheel interested Winter Living 12 11-02-2003 11:30 AM
Winter hikes Pahaska Our Community 1 01-06-2003 11:51 AM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 12:11 PM
