Old 12-13-2010, 03:05 AM   #141
frankfarmer's Avatar
1992 34' Limited
Snead , Alabama
Making it OK, down Lake Guntersville, north Alabama area, full skirt all around, 2 heat bulbs underneath, left water running in all faucets, all seems to be OK. high today here 24 & low of 14. Good luck to all other full timers.
frankfarmer is offline   Reply With Quote
Old 12-13-2010, 07:23 AM   #142
1960 22' Safari
1988 25' Excella
cedar lake , Indiana
new problem.....ice cycles below water heater door on exterior..... the water heater is working. I am running the water line. It is hooked up to city water, that is wrapped and heat coiled.
No water leakage seen.
It is a 88 excella 25'. Could this be a water plug leaking?
suggestions are welcome........
HoosierGypsy is offline   Reply With Quote
Old 12-13-2010, 08:34 AM   #143
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Icicles
Use a hair dryer or heat gun to melt the ice off the door and open and inspect the tank area. It may just be the heat or the unit melting the area above the door. If its the plug, wrapping with a little tethlon tape should do the trick.(available at any hardware/auto store)
If you have a big leak it would probably show up on the inside on the floor.
Dave
Old 12-13-2010, 09:32 AM   #144
fmrcaptevil's Avatar
Weldon Spring , Missouri
It's not unusual for the pressure relief valve to vent a small amount of water as the tank heats up, especially if it's been off for a while.
fmrcaptevil is offline   Reply With Quote
Old 12-13-2010, 09:45 AM   #145
1960 22' Safari
1988 25' Excella
It has been running for days. I am able to break away the ice cycles to open the water heater door. The ice is a lot! but there seems to be no water dripping within the area. I lifted the release valve and steamy water shot out.
the drain plug doesn't seem to be leaking but it doesn't seem to be installed all the way?
no water inside detected. I have yet to remove the bed.......
Old 12-13-2010, 09:49 AM   #146
1960 22' Safari
1988 25' Excella
no water in the exterior storage adjacent to the water heater, what next?
Old 12-13-2010, 01:12 PM   #147
masseyfarm's Avatar
Images: 56
Icicles
Not sure of your setup, but if your problem is below the fridge roof vent, (heat from fridge causes melt) then the water may be running down and freezing up at that point where it drips.
Doesn't sound to serious.
Dave
Old 12-13-2010, 04:47 PM   #148
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Hoosier,
The plug doesn't look like it goes in all the way on mine either. All that is important is that it seals. Usually plastic plugs seal better than metal, but teflon doesn't hurt. If you feel any drip or dampness under the plug, then you have a problem. The plug threads are much softer than the water heater threads, so be careful not to overtighten it and strip the plastic threads.
I expect moisture moves down the side of the trailer in the sun, collects on the upper edge of the water heater door and gradually drips down, or frost collects on the door at night and melts during the day, or the heat from the water heater attracts condensation on the door and above it. One or more of these things causes some moisture to run down the door and then freeze at the bottom where it's colder.
Gene
Old 12-13-2010, 06:33 PM   #149
1960 22' Safari
1988 25' Excella
icicles
ok, I am going above freezing this week and will empty the water heater, then see if it is the plug?
the refrigerator is further forward.
this is a 25' excella with rear bed. the water heater is below the bed street side. water turned icicle.....is below the water heater door, coming from inside the water compart somewhere? the only dampness I can locate is the drain plug area and the release valve...
I am keeping the heater lit this is gas only heater. I am also leaving the interior water running.always something.......
thank you everyone for your advice and suggestions
hoosier heading further south
Old 12-14-2010, 07:30 AM   #150
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Hoosier
I agree with Gene's take on the source of the water.
I don't see any reason to empty the wh to see if the plug is leaking. Once you get above freezing you will be able to see if the wh drain plug is leaking.
Dan
Old 12-14-2010, 09:20 AM   #151
masseyfarm's Avatar
Images: 56
Icicles
[QUOTE=HoosierGypsy;926465]ok, I am going above freezing this week and will empty the water heater, then see if it is the plug?
hoosier heading further south[/QUOTE]
Just make sure you shut off the water heater before draining the tank. (dumb things happen)
Dave
Old 12-14-2010, 09:25 AM   #152
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I think it is from the water heater popoff valve. Natural for it to happen during times of use, usually not visible unless it's cold enough to leave evidence (such as icicles).
Unless it is a big one, I guess.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-14-2010, 12:12 PM   #153
Master of Universe
Gene's Avatar
An empty water heater will not leak.
The only way you can tell is if the tank is full. If it's dripping, you will either see it or feel it. The water should be warm or hot if the water heater has been on. Check the area around the plug where it is screwed into the tank to see if it is damp—you can check this with a dry paper towel. Any dampness will show up on the towel. Then see how tight the plug is if there's any leak. If it's loose, tighten until it's fairly tight—maybe 10-15 foot pounds. If there's dampness or a leak and it was tight, tighten it maybe 1/8 turn, dry off the plug area and come back in an hour and check again. At some point, you'll have to stop tightening because you'll strip the threads.
If you get to that point, turn off the water and the hot water heater. Wait for a while for it to cool down a little, then release pressure by opening the pressure relief valve with gloves on while standing aside (it'll be hot for hours). After the water stops coming out, you can take out the plug. Inspect it for stripped threads or dirt. Also inspect the threads on the tank to make sure there is no dirt. Put some white teflon plumbing tape around the plug and reinstall it.
It doesn't sound like there's much of a leak if there is a leak, so you don't have to worry about it. Just check it out when you can. These kind of plugs do not leak very often if tightened properly.
Gene
Old 12-14-2010, 12:35 PM   #154
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Here is a dumb question. When hooked to city water does the heater automatically fill up with water? I was wondering about it when I was checking the heater flame worrying there might be no water in it.
cclarkego is offline   Reply With Quote
Full timing, where possible? dmac Winter Living 13 01-07-2010 02:22 PM
full timing in the winter photocodo General Repair Forum 1 08-13-2009 09:04 PM
Full Timing & Winter Living Kate&Spence Full-Timing 4 05-25-2008 11:45 AM
Full Timing Winter Living davidh Winter Living 4 01-22-2006 05:31 PM
Full Timing abruce Full-Timing 10 01-29-2005 11:29 PM
