Originally Posted by afk314
What other things might I need to think about? Have you done this? Why isn't this more common?
I haven't actually dry-camped in winter. I still had an electric hookup, but due to prevailing conditions I did without the water hookup and sewer hookup, so my experience wasn't
exactly like you envision, but close enough, perhaps.
One of the main reasons winter camping isn't more common is that Airstreams aren't insulated as 4-season trailers. You will lose a lot of heat through the metal skin, skylights and roof vents, and windows. That will require a lot of propane going through your furnace to replace that heat. Especially if you leave a window and your bathroom roof vent cracked open to provide air exchange and keep the interior from getting stuffy from high CO2/low oxygen.
Also, condensation will be a problem on the interior of every outside wall and/or window. Everything from your breath to the stove burners adds water vapor to the inside air. Running a dehumidifier will help, if you have battery power to do it. Dehumidifiers don't dry the air quickly enough to just run one while you're on generator power; you need it on all the time.
Also, unless you go to a porta-potty for waste elimination, or have an outhouse or slit latrine handy outside or a composting toilet inside, you won't be camping
completely waterless. You'll still need to flush, for sanitary reasons and odor control. Fortunately, you can pour water from jugs to flush with, and flushing water can be a 50/50 mix of water and RV antifreeze.
You can heat water on the stove for a sponge bath, but you
can also go waterless for bathing (if you have short hair, or no hair like me) by using waterless hand sanitizer to wash
all of your skin instead of just your hands. You won't actually
feel as clean that way, but your skin will be 99% germ-free!
