Old 01-03-2010, 04:03 PM   #1
Cracker's Avatar
Pittsfield , Maine
Using Furnace to Shed Snow/Ice
We're thinking about heading south and, at present, the AS has a foot or so of snow and ice on the roof. The weather here has just moderated (for a short period of time---) with daytime temperatures around the mid 30's. Not wanting to subject following traffic to ice flying off the roof as we drive south into warmer areas, I was wondering if firing up the furnace for a day or two before we leave would create any problems - i.e., leaks, condensation, etc. I'm particularly concerned about ice dams causing leakage into vents and the like. If I wait too long we'll be back into sub-zero temps and the "probable" heat loss may not be adequate to achieve de-icing. I normally don't remove the snow and ice from the AS during the winter so that's the reason for this question.
Cracker
Cracker is offline   Reply With Quote
Old 01-03-2010, 04:11 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Wash it....
I would stop at a truck stop and wash it before getting on the Interstate..
Have a safe warm trip...
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 01-03-2010, 04:18 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If I remember the roads and vehicle condition after traveling, I would wash after the trip ;-)
Old 01-03-2010, 04:25 PM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
How about saving the fuel and using a broom to clear off the snow?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 01-03-2010, 04:31 PM   #5
Rodney,
OUCH
Can't even use a nice soft boars-hair brush without scratching, ask me how I know.
I think nice warm water a little easier, especially up here in the cold.
W. H. Auden
Amanamus
"Tahawus"
Old 01-04-2010, 11:13 AM   #6
Cracker's Avatar
Pittsfield , Maine
Note that I said "de-icing!" The snow here in Maine is seldom so powdery as to permit simply brushing it off - especially after being hit with a mix of rain, snow, and then a thaw. Further, as per Robert Cross, even the finest brush can damage and, that said, I limit the street broom to the poor old '95 pickup - our winter "beater!" As for truck stops with wash capabilities, by the time I traveled south in Maine to find one the AS roof would probably be clear.
Back to my original question about thawing out using the furnace???
Cracker
Old 01-04-2010, 11:27 AM   #7
Lily&Me's Avatar
Normal , Illinois
Having previously had our Interstate frozen in with snow and ice---here and in Missouri , our suggestions would be to try to get it melted off the roof before you hit the road, presumably with your funace. If you take it to a car wash, that could result in freezing your locks and perhaps doors.
You might consider investing in a cover, which will keep the snow and ice off your roof and out of crevices which will expand with the freezing.
Old 01-04-2010, 01:07 PM   #8
_
hi cracker...
how much propane do you wanna use?
that unit (i think) has a butyl tape barrier between outer skin and ribs.
so it will not conduct heat as QUICKLY to the outer skin.
and IF the winds blowing that won't help either.
but IF you crank up the furnace and let her RUN it will melt stuff around the vents and fans...
and around the skylights and the windows and so on.
but once started, u really are committed to the process then GOING SOUTH.
because when it starts REfreezing, there will be water in all the tiny cracks/gaps/seams and so on...
i would just hook up and GO, it' not likely that some ice falling off the sides/top is gonna stop traffic.
or that u won't encounter snow again in a day or 2 and get MORE dumped topside.
put a sign on the back that warns of falling ice! and get out of dodge...
and don't forget to check TIRE AIR PRESSURES before hitting the road.
cheers
2air'
Old 01-04-2010, 01:18 PM   #9
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
I wouldn't be too concerned...we see more than ice and snow flying off the big rigs here in the mountains of PA...
Roadrunner is offline   Reply With Quote
Old 01-04-2010, 05:02 PM   #10
Cracker's Avatar
Pittsfield , Maine
Yep - I've had sizeable sheets of ice shatter on the road ahead of me after flying off the roof of semi-trailers - and that's what bothers me. I've already taken a large cooler lid through the windshield of my TV that damn near took me out and I don't want to be responsible for causing an accident that hurts someone else. The "re-freeze" that 2Air mentioned is also a concern with respect to damaging the AS - since I doubt that I'll be able to reach warmer climes fast enough.
Cracker
Old 01-04-2010, 06:14 PM   #11
1976 25' Caravanner
Campton , New Hampshire
I've used a SnowBrum to get the bulk of snow off then let the furnace do the rest. They work better if you pull like a rake rather than push . Use it on the truck all the time with no paint scratches. Try your local auto store. Good luck and have fun.
ticki2 is offline   Reply With Quote
Old 01-04-2010, 08:03 PM   #12
2005 31' Classic
Gretna , Nebraska
Furnace & snow.
Gentle furnace heat on an above-freezing day should be a gentle approach. Refreezing happens every night whether the furnace runs or not.
A gentle brush will reduce the amount of propane needed. The heat will transfer well enough on a warmish day.
Dwight
16595 is offline   Reply With Quote
Old 01-04-2010, 08:10 PM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Your foot of ice and snow won't let a steel shovel near your Excella unless you worked at it.
Proud of ya for trying to eliminate the flying traffic hazard.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Any pics of Airstream carport or shed you have built? Lothlorian Off Topic Forum 49 06-01-2015 06:00 PM
The PO was going to turn it into a shed! kenthelen Member Introductions 9 07-18-2008 09:57 PM
Automatic Load Shed Device 68 Overlander Commercial Listings 2 12-12-2006 10:28 AM
Snow and Ice rebel beck Our Community 23 12-02-2006 03:44 PM
not meant to be a storage shed Larry Goede Member Introductions 4 05-22-2006 07:48 AM
