Old 01-23-2016, 05:26 PM   #1
Asheville , North Carolina
Send a message via Skype™ to shupack
Think I need stronger struts for the front shade..
You can just see it on the right, the weight of the snow collapsed the gas-struts, but didn't slide off... other than that, no problems!!
'71 Silver Streak Deluxe Rocket- "Arthur".
shupack is offline   Reply With Quote
Old 01-23-2016, 06:41 PM   #2
1981 31' Excella II
New Market , Alabama
There are two things that kill those gas struts. One is cold temperature causes the gas to contract lowering the pressure and number two is age. They loose a little pressure each year till they won't do the job. The good news is that you can buy them pretty cheap from places like mcmaster.com. You need to know the extended length and the collapsed length and the force you are trying to resist. In this case that would be gravity. If you remove both of the struts then measure the force required to hold the awning up with something like a fish scale, you divide that number by 2 to get the force needed on each side then add 20-30% to that number you have your force. Sometimes the strut has this printed on it. You want to pull in the same direction that the strut is in. If the strut is at 45 degrees then you need to pull at 45 degrees. Personally, I HATE these things because they don't last more than a few years then you have to pay to replace them. If you go to an auto parts place they want as much as $50 each for them. I expect you can get them for about $20 each.
Of course, rich folks that buy Airstreams and German tow vehicles can afford this kind of maintenance.
Perry
Old 01-28-2016, 07:23 PM   #3
I just installed them, 15# (the awning is just sheet aluminum). Originally sliding/locking struts, but they rusted out, so I swapped them for gas, quite easy.
And my tow vehicle is British
Need cabinet struts. mapley3 Cabinets, Counter Tops & Furnishings 0 07-26-2013 09:59 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Front to Back Struts beyond Repairing/Replacing Floor &/or Frame 5 01-01-2010 07:34 AM
Lift struts for access to under bed storage... Phil/Edee General Interior Topics 8 10-02-2008 01:43 PM
Gas assist struts for lifting bed to access storage. Phil/Edee General Interior Topics 13 09-27-2007 10:12 AM
