Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living > Winter Living
Old 02-03-2006, 02:17 PM   #1
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
Skirting an Airstream
Hi I just wanted to post some pictures showing how I skirted my airstream with 1" styrofoam to help keep floor warmer and to also save on propane cost.
ID:	18162   Click image for larger version
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-03-2006, 02:41 PM   #2
2airishuman's Avatar
Profile:
looks good david.........
very clear what you have done....
just a suggestion..........
you ask a moderator to change the thread title to "skirting an airstream" or 'skirting secrets revealed' or something similar.
this comes up a lot and folks will be able to find these useful photos more easily.......without looking through the antifreeze/ pipes/ hay bail and other winter issue threads.
did you jack the trailer or is it on the tires/stabilizers?
is there any vent holes or were they not needed? any moisture under there?
cheers
2air'
Old 02-03-2006, 03:17 PM   #3
1977 31' Sovereign
davidh's Avatar
Skirting An Airsrteam
2airishuman good point sent message to a moderator to change title. Tires are still on, no vent system for moisture, styro is tucked up under just tight enough to hold in place, is not a perfectly tight seal so it can breath. Back to the moisture on inside of trailer, when the temps hit -20 I had just a little moisture on the very bottom of my curbside vista view window in loung, as far as moisture under mattres'es none, and no other moisture problems thru out trailer, I guess I am one dry fellow, but that is the truth, I do have dualpane glass thruout trailer and also heat ducts to all water tanks, that also makes a big differance..
Old 02-03-2006, 05:52 PM   #4
1977 31' Sovereign
davidh's Avatar
Here is one more picture..
Old 09-02-2006, 08:54 AM   #5
Profile:  1969 25' Tradewind
Barstow , California
Probably a stupid question - where can one get long panels of styro like this for skirting?? Home Depot?
lianimals is offline   Reply With Quote
Old 09-02-2006, 09:19 AM   #6
trevisgardne's Avatar
Profile:  1973 31' Sovereign
Maryville , Tennessee
Cool....
What are the details on your neat blue stone guard?
trevisgardne is offline   Reply With Quote
Old 09-02-2006, 09:19 AM   #7
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I have seen that material at both Home Depot and Lowes.
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
Old 09-02-2006, 09:55 AM   #8
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Originally Posted by davidh
I do have dualpane glass thruout trailer ..
Wow! I've never seen an Airstream with a dual-pane window option! Didn't even know it was available (other than in Vista Views, of course). Could you take and post some detail photos of the windows and how it was done please?
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
1994 Airstream B190 & 2006 Bigfoot 25B25RQ
Old 09-02-2006, 10:35 AM   #9
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Dual-pane was standard in the 70's. My 75 has them. It is interesting that mine (except for the vista view) are clear. The 76's that I looked at all had problems with a layer of tint between the glass that had gone bad. Many of these owners have punched out the inner glass to clean up the window.
Richard
Charter Member Four Corners Unit
Old 09-02-2006, 10:51 AM   #10
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
David ---nice job!!!---we're going fulltime next year and skirting was an issue i was thinking about should we sometime end up in cold weather. this looks nice, and i would think not real expensive. have seen other attempts that just plane looked trashie. thanks for the idea and picts---pieman
Mike Lewis is offline   Reply With Quote
Old 09-02-2006, 11:37 AM   #11
85MH325's Avatar
Images: 37
My '70 Safari had standard panes.
Roger
Old 09-02-2006, 12:29 PM   #12
Profile:
hello all
davidh who started this thread relocated/moved back to minnytota...
in april....
http://www.airforums.com/forum...0-post105.html
expected about a week off line so unless he has a new account...
don't think he's posted since the move...
a member lost in cyberspace.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 09-02-2006, 12:57 PM   #13
Foiled Again's Avatar
Virginia Beach , Virginia
Skirting ideas
That 1 inch foam doesn't look too bad. I' went through last winter (in Virginia Beach, VA) without skirting at all. Used water all winter too, but we didn't have our usual 2 week hard freeze. Did leave a faucet dripping, cabinet drawers open and heater on low.
I do travel even in winter so any skirting I do needs to be easily to remove, store and set up. Of course I also don't want it to be a public eyesore either. I would worry that the duct tape will let go after a while. Other than using the shiny metal tape which has better adhesive, This system seems to work and is certainly light weight.
I'd considered using the foil backed foam insulation and draping it over something like chicken wire, cut to fit the wheelwells and tongue, but this looks lots easier. THANKS
Paula Ford
Old 09-02-2006, 01:38 PM   #14
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I think the dual pain windows were an upgrade or option. My 75 does not have them and my 80 Excella does.
Aaron
WBCCI #2449 AIR #2495
Cost to restore a gutted Airstream Draco General Interior Topics 26 03-17-2009 10:12 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 11:20 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 11:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
