Old 04-06-2007, 07:04 AM   #29
2008 27' Classic FB
West Of Boston , Massachusetts
I like that better than blowing air into the system.
I feel more comfortable with doing that than blowing air into a system.
I will go outside and try to find all the items you suggested on my AS.
Best,
Irish.
Life Is Not A Dress Rehearsal
"It's Okay to have too much fun"
New England Unit WBCCI 8701
TheThreeSeas is offline   Reply With Quote
Old 04-06-2007, 09:39 AM   #30
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
It takes a lot of air flow to really dry out the water lines and your typical 12 volt pump only does a passable job. My dealer uses high pressure and he will guarantee that your lines are dry. For myself, I blow them out and then inject RV anti-freeze through the water pump. That's they only way to make sure you've displaced any lingering drops of water.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-06-2007, 11:14 AM   #31
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Took about three hours and un-did it about a month later. Don't put any in your water tank. It takes awhile to get he taste out. The inlet to your water pump has a screw on fitting a garden hose is supposed to fit.
Michelle TAC MT-0
Sarah, Snowball
weather stripping Londoner Windows, Doors, Locks & Vents 7 07-13-2008 08:03 PM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
Need new weather stripping kit lizh Windows & Screens 8 08-30-2002 07:49 PM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
