Old 07-20-2007, 09:39 AM   #1
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Question Questions - Re-insulating for Cold Weather
Hello,
I want to get the highest value insulation I can in my vintage Airstream so that it can withstand longterm living in a colder climate (western Pennsylvania). I've been told that Blue Dow has the highest R-value per inch, followed by Polystyrene, then pink fiberglass. I've also been told that Blue Dow presents a fire hazard and should not be used for RV insulation by someone who restores Airstreams for a living, and that they recommend the polycyanurate panels. But I also know HitchHikers use Blue Dow to insulate..
What is the difference between Polycyanurate and Polystyrene insulation?
What is the safest & best insulation to put in an RV?
What other things should I be asking in regards to keeping the Airstream temperate inside (I'm a total newbie)?
Thanks in advance! I've learned so much from these forums over the last few weeks lurking - very helpful with my dream!
Brock
BrockLives is offline   Reply With Quote
Old 07-20-2007, 09:48 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Brock -- Welcome to the Forums! My dad was from Clarion -- you've got a beautiful state!
This is a tall subject that has occupied a lot of time here at the Forums. Have you checked out the Winter Living subforum, http://www.airforums.com/forums/f462/?
Issues cover topics like insulation (conductive aluminum ribs!), water, waste, condensation, and on and on. How you answer these can vary between whether you want a mobile Airstream vs. a stationery one.
5 meter Langford Nahanni
Old 07-20-2007, 11:24 AM   #3
BrockLives's Avatar
1972 29' Ambassador
Question Crosspost: Re-insulation Questions
Hello,
Crossposting this from General Repairs -
I want to get the highest value insulation I can in my vintage Airstream so that it can withstand longterm living (but still remain mobile) in a colder climate (western Pennsylvania). I want to reinsulate the entire trailer between the walls with the most punch possible and am exploring my options.
I've been told that Blue Dow has the highest R-value per inch, followed by Polystyrene, then pink fiberglass. I've also been told that Blue Dow presents a fire hazard and should not be used for RV insulation by someone who restores Airstreams for a living, and that they recommend the polycyanurate panels. But I also know HitchHikers use Blue Dow to insulate their 5ers..
Brock
Old 07-20-2007, 11:28 AM   #4
BrockLives's Avatar
1972 29' Ambassador
Thanks Bob! We sure do, especially here in the Laurel Highlands
I crossposted with a little more information there. I also checked out a lot of threads and made extensive notes (I'm back to doing that after this post)!
Brock
Old 07-20-2007, 01:00 PM   #5
Say Brock, it is neither necessary nor desirable to crosspost threads here. Moderators act to put them back together. I did merge them and kept the product in the Winter Living subforum. Your question will probably stay higher on the list in that subforum anyway. Summer weekends see participation drop off around here -- I'll look in on this later Sunday and make sure you're getting some views.
Old 07-20-2007, 01:17 PM   #6
Images: 59
Brock,
I think I would use fiberglas because of the ease of insulation. If doing mine over again I would also use rubber tape for a thermal break at the ribs.
Under the floor where you can use flat pieces I would certainly use polyisocyanurate with foil backing. It has a high R-value, is readily available, and is fairly inexpensive.
Here is a list of R-values. I believe the Blue Dow would be extruded polystyrene. The Hitch Hiker claims that Blue Dow is better than the white bead insulation (expanded polystyrene). I would stay away from the white stuff as it falls apart.
Old 08-31-2007, 12:20 PM   #7
Balto. , Maryland
water system question
Hello. Not only am I interested in freeze prevention issues, but I would also like to post a question about the water system in general. I am hoping to purchase an Airstream to use as a lont-term temporary residence and want to know if a water hook-up from a well would provide too much pressure. Can the Airstream water system tolerate a water pressure from a well water source? Thank you.
rdorrett is offline   Reply With Quote
Old 08-31-2007, 12:25 PM   #8
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
The Airstream will come with an internal water regulator. If the trailer is an older model, I would have the regulator checked or purchase an inline model from any RV supply house. They also sell them (cheap ones in plastic) at Walmart.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Questions about a 2000 Land Yacht jberndt Mechanics Corner - Engines, Transmission & More... 3 01-08-2003 10:12 AM
Prospective AS owner with questions jborning Our Community 0 10-14-2002 08:50 PM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
