Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Winter Living
Old 10-14-2010, 05:17 PM   #1
2008 22' Safari
Daniel , Wyoming
Plug in AS with no batteries
Can I plug in the AS without the batteries to use it as an emergency guest room during the winter (temps to -20f)? I store the AS covered, without the batteries.
fotozone is offline   Reply With Quote
Old 10-14-2010, 05:47 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
I have a 1976 Sovereign and it's been plugged in, on and off, all summer without a battery. I use the 12 volt off the converter. The converter doesn't seem to care if there's no battery or not. I have the cables isolated and insulated.
Gary
Old 10-14-2010, 06:36 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The converter would prefer to have a battery attached. The load of the battery smooth out the voltage from the converter and keeps it within an acceptable range that. No battery load the converter will put out close to 14 volts. If you have a large draw with all the lights and the heater on you may exceed the capacity of the converter. The battery would provide that additional current.
2004 Excursion 4x4
Old 10-14-2010, 07:13 PM   #4
tpi
Trabuco Canyon , California
If your trailer is equipped with Parallax 7300 series it is OK to not have battery in the circuit. It is in the following document-
http://www.parallaxpower.com/7300/51...%20rev%20G.pdf
If this is not the model converter/charger in your trailer there should be documentation to answer this question.
While I run my 7300 Parallax with batteries out of the circuit at times, I prefer to have them in the circuit when possible, as a protection against surges caused by a failure in the converter/charger.
tpi is offline   Reply With Quote
Old 10-14-2010, 07:31 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The ripple ac voltage present on the 13 volts produced by the converter is damped out by the presence of a battery. For some electronics that are susceptible to noise on the power supply line may have noisier audio 60 cycle hum.
Old 10-14-2010, 07:38 PM   #6
Dag68's Avatar
1965 22' Safari
Shelter Island , New York
Images: 20
Is there a reason you can't store it with the battery in place?
Come on a (1965) Safari with me!
Dag68 is offline   Reply With Quote
Old 10-14-2010, 08:00 PM   #7
tpi
This has not been my experience with my 7355. I had one of them open and saw several large filter capacitors. When converter is shut off with a light load you can observe the capacitor's voltage decay. I have observed no difference in noise in the audio system whether the batteries are in circuit or not. All indications to me are the power is very well regulated.
Now if there were some type of failure all bets off.
BTW I take my AGM batteries out of circuit when they're fully charged and its hot.
Old 10-16-2010, 01:58 PM   #8
2008 22' Safari
Daniel , Wyoming
Thanks everyone for all the info. I generally remove the batteries and store them in the basement, off the ground to protect them from the very cold temperatures we have here in Wyoming. But I think will need to use the As as a extra guest room over Christmas. Again, thanks for the info.
Old 10-24-2010, 07:22 PM   #9
HCR
HCR's Avatar
Livingston , Full time traveler
Thanks for posting the question as I have been long interested in the answer and all the details that were posted.
HCR is offline   Reply With Quote
Please help me plug in my airstream! PinkLady 1960 - 1965 Safari 13 09-17-2017 12:22 PM
Can I plug it in? bullydogsmom Refrigerators 5 04-12-2009 12:56 PM
Ideal plug mgordon Electrical - Systems, Generators, Batteries & Solar 3 07-07-2003 09:12 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
