Old 01-20-2015, 08:04 AM   #15
1974 Argosy 20
Kooskia , Idaho
Originally Posted by Hoboplayer View Post
Can anyone explain why a propane tank fails to supply gas when 1/4 full and the weather is below freezing? I have experienced this condition. I don't relish filling a 1/4 full tank as our local suppliers charge for a full tank.
I assume the switch over valve switches when the tank pressure drops below its set point. And I also assume that the set point is reached only when all the liquid is expended. So how does the fill level have any impact?
Hobo
Propane in the tank is a liquid and changes to a gas (evaporates) to supply the system. It takes heat to evaporate the liquid to a gas. When it is very cold outside and you are using a lot of gas, the surface area of the tank is not large enough to heat the liquid so it evaporates. The liquid actually freezes solid in the tank and the evaporation to gas stops. The lower the level of propane in the tank, the easier it is to freeze the remaining propane.
You can gently heat the tank (say with a small heater or a light bulb) to heat the propane and un freeze it until it is all gone.
Old 01-20-2015, 08:17 AM   #16
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Just a little correction... Propane freezes at -356 degrees Fahrenheit, so you're not getting a solid chunk of propane in your tank. What happens is that as the liquid propane evaporates, it draws the tiny bit of heat left in the cold air out (same principle as an air conditioner uses, or the reverse of a heat pump) which does cool the remaining liquid propane even lower, which makes it evaporate slower, this supplying less gas to your appliances. The faster you draw it, the colder it gets, so the slower it evaporates...The advice on heating the tank does work. We use a water hose to safely warm freon tanks while working on A/C systems in cooler weather down here in Florida... You can use your torch set, but the pressure rises pretty quickly that way.
-Red, been to school on this stuff...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-01-2015, 11:09 PM   #17
StreamlineAK's Avatar
2014 25' FB Flying Cloud
Anchorage , Alaska
Images: 12
Gas pressure in a propane tank drops in sub-freezing weather. Make sure your tank(s) are at least half full, or your furnace may not light. Also, the furnace will likely flame out and fail to re-ignite when the propane level drops to 1/4 to 1/3 full. This is normal, and all that is required is to refill the tank(s).
I have not had an issue with this in 3 years of winter trailer living.
StreamlineAK is offline   Reply With Quote
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
2015 Flying Cloud woof 2009-2015 Flying Cloud 13 04-05-2015 12:53 PM
Selling our 2012 Flying Cloud 30' Sofa for 2015 Bunkhouse Hibby 2009-2015 Flying Cloud 12 03-15-2015 08:08 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Flying Cloud front lounge changes Endodoc 2009-2015 Flying Cloud 4 10-10-2014 06:11 AM
