Old 10-11-2013, 07:22 AM   #1
2014 30' Classic
Columbus , Ohio
Newbie question - winter travel
We're new to the AS community: '14 28' Serenity. Can you operate the furnace on LP while towing the trailer?
Kokomogoggy is offline   Reply With Quote
Old 10-11-2013, 07:42 AM   #2
SteveH's Avatar
Common Sense , Texas
Yes, and I recommend it in sub-freezing weather. It will keep your water pipes from freezing, within limits. I've done it and was successful in weather in the teens, but would not rely on it for much lower temps.
Regards,
Steve
Old 10-11-2013, 09:45 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes, we do it as necessary.
Depending on your itinerary and the availability of shore power at your destination, you may want to be sure that the charge line from your tow vehicle is working properly so that the battery in the trailer isn't depleted.
You will go through a fair amount of propane.
