Old 10-07-2015, 06:32 AM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Newbie ?: Fall nights and condensation
Daytime temps 78, night to 60. When we get up in morning, there in a lot of condensation in AS. 1. Is this harmful?
2. How do you prevent? Would running heat pump at night to maintain a constant temp inside minimize?
Help
DeltaRon is offline   Reply With Quote
Old 10-07-2015, 06:47 AM   #2
Floatingair's Avatar
1994 30' Excella
Kiefer , Oklahoma
An electric dehumidifier with a drain hose to your kitchen sink
drain.
Floatingair is offline   Reply With Quote
Old 10-07-2015, 06:49 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The problem is moisture on the inside with cold walls and windows. Open some windows and/or vents a little to let moist air out and cooler, drier air in. Then run heat if necessary for comfort. Alternatively get a small de-humidifier, if shore power available.
We were in 40 degrees and lower without significant condensation except on windows but we have an older trailer with "mouse fur" which I think provides a little more insulation and doesn't provide a cold surface like the newer metal inside skins.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 10-07-2015, 06:55 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have experienced this problem. When we turn on the heat pump, it gets worse. What we have been doing is to turn on the gas furnace to heat up the trailer a bit. Then we switch over to heat pump. This seems to do the trick for us.
Brian
SuEllyn & Brian McCabe
Old 10-07-2015, 06:56 AM   #5
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
We just keep a couple of chamois cloths on hand and dry all around the windows in the mornings.
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 10-07-2015, 07:06 AM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I have measured high moisture levels in the plywood subfloor below the bedroom pano window from high condensation (cold rainy weather, very humid air inside and outside the Airstream) running down outside and inside the interior walls. This could result in floor rot over time because the vinyl finish floor does not allow the subfloor to dry out easily. There can also be corrosion of metal parts.
Try to ventilate the trailer as much as possible, even running the furnace and wasting some propane to be comfortable while helping dry the air and walls. Circulation of the air with the furnace or a space heater with fan helps a lot. We have vent covers over both Fantastic Fan roof vents so we can keep them open even in rain to help ventilate.
Doug and Cheryl
Old 10-07-2015, 07:30 AM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I run heat and AC together to dry the air.
CRH is offline   Reply With Quote
Old 10-07-2015, 07:49 AM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
When camping I crack open the roof vents. I do not like to run the dehumidifier if I am in the trailer, it is loud and puts out a lot of heat.
MICHAEL
Old 10-07-2015, 08:33 AM   #9
Port Townsend , Washington
We crack our Fantastic vents ( have 2 on our 23fb) a bit, seems to work, no condensation on the windows.
dizzy is offline   Reply With Quote
Old 10-07-2015, 09:22 AM   #10
Mission , Texas
You breathe, you cook, you bathe - all put moisture in the air that collects on cold surfaces and can find its way to your plywood subfloor and in a few years be an even bigger problem.
Open a window or vent, use a dehumidifier, run the AC and heat together (so the AC acts like a dehumidifier).
nrgtrakr is offline   Reply With Quote
Old 10-07-2015, 11:11 AM   #11
1967 26' Overlander
Spartanburg , South Carolina
Add gas heat to the list of moisture sources. Running A/C and furnace together is a good idea. I enjoy cool sleeping weather so I open windows wide, put on an extra blanket and snooze away. Any breeze will keep the inside dry unless it is raining. With shore power, I use an electric heater which does not give off moisture as gas heat does.
Jacob D is offline   Reply With Quote
Old 10-07-2015, 11:27 AM   #12
1977 31' Sovereign
Lynnwood , Washington
Over time, condensation will destroy the floor. You will also have a mold problem.
I use an LG dehumidifier; model # LD301EL. It's the smallest one they make that's on wheels.
I also use plenty of DampRid.
Tom
TomKirk is offline   Reply With Quote
Old 10-07-2015, 11:45 AM   #13
Mission , Texas
Dehumidifier? Think small ...
https://www.eva-dry.com/dehumidifier...-dehumidifier/
Old 10-07-2015, 11:48 AM   #14
2018 33' Classic
Newport , Pennsylvania
Ok
I will stop cooking and bathing but breathing is where I draw the line
haha
Earl
EarlM is offline   Reply With Quote
Cold nights ahead but I'd rather not winterize. Best option? blickcd Winterizing, Storage, Carports & Covers 20 10-07-2012 05:17 PM
Hot Grog for cold nights Lily&Me Stella's Kitchen 2 12-18-2011 11:27 AM
Cold winter nights - hot PJs adonh Our Community 3 02-08-2010 07:15 PM
2006 Airstream Nights moosetags On The Road... 42 01-21-2010 07:04 AM
Just a few nights of freezing? ovrteakettle Winter Living 22 12-15-2009 01:50 PM
