Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living > Winter Living
Old 06-18-2009, 09:21 PM   #1
Profile:  Currently Looking...
york , Pennsylvania
keeping tanks warm
I'd like an opinion as to which way to go with my airstream, get one with 12v heat pads or one with hot air from the furnace. Both will suck a battery dry but if you keep the heat inside on will this eliminate turning on the 12v pads?
I thought the pads were good while enroute but once you arrive can you survive with the furnace. I'm not sure if the models with the 12v pads are designed differently?
cpaharley is offline   Reply With Quote
Old 06-18-2009, 09:42 PM   #2
truckasaurus's Avatar
Profile:  1961 26' Overlander
Airdrie , Alberta
Images: 24
I'm going with heat pads, if it's cold enough to need the heat I'll run a generator for the power.
preparing for the maiden voyage in 2010...
truckasaurus is offline   Reply With Quote
Old 06-18-2009, 09:45 PM   #3
Commercial Vendor
Profile:  Corona , California
No need for heat pads.
The furnace will provide adequate heat to keep the tanks from freezing.
When your towing, in freezing weather, keep the furnace set to about 55 degrees. The battery will not run down, but make sure you have plenty of LPG in the tanks.
Then, when you get in the trailer, you won't be greeted with a freezing atmosphere.
What year and length Airstream do you have?
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-18-2009, 09:53 PM   #4
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
If you use your heat, then why not let it warm your tanks. But where are you camping when it is below freezing all the time.
To freeze a holding tank under a trailer would take time and sustained cold temps...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-19-2009, 06:05 AM   #5
doug&maggie's Avatar
Profile:  Normal , Illinois
We have a tank heater, use it whenever we are expecting freezing temps (which we try to avoid). We don't boondock in this kind of weather. As we are small, we use a tiny electric space heater for heat---if you are plugged into and paying for electricity, why use your propane? We have seen some really cool electric space heaters which look remarkably like wood stoves, put out an amazing amount of heat and add a lot of atmosphere to the interior in cold weather.
li'l moose
The more you know, the less you need
doug&maggie is offline   Reply With Quote
Old 06-19-2009, 06:55 AM   #6
fr8tshaker's Avatar
Profile:  2006 34' Classic
Sioux Falls , South Dakota
For those of us that prefer not to tow with the furnace running, is a system like www.ultraheat.com doable on the AS? It appears to have the ability to heat the drain lines as well as the tanks.
Could this be applied to all the internal water lines?
Has anyone done this and does anyone know of an installer for this type of system?
Thanks in advance, 'shaker
2006 34' Classic LTD
2004 Ford F350 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 06-19-2009, 11:52 AM   #7
Commercial Vendor
It appears that system is ok for the pipes, but there is nothing in the drain lines, so what could freeze?
The problem is keeping the tank or tanks from freezing.
That requires circulating heat.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-19-2009, 02:36 PM   #8
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
Images: 36
Send a message via AIM to DIMMER
I have had a case of pop freeze In less then 30hr stored In a compartment (under dinette seat) with a outside access panel and sealed off from getting any heat. Inside the camper 75, outside -20 windchill. There's nothing like camping In the snow!!!
DIMMER
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 06-19-2009, 04:49 PM   #9
dstalzer's Avatar
Profile:  2005 25' Classic
This subject seems a bit odd when it is 100 degrees out
dstalzer is offline   Reply With Quote
Old 06-19-2009, 05:06 PM   #10
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
Heat
Don`t over due it ,it was only supposed to get to 98 in Austin today. I`m of the feeling if I have to run the heat,I need a change of latitude.Dave
easyride is online now   Reply With Quote
Old 06-19-2009, 07:18 PM   #11
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
I put a little diverter in my line at the tee. It blew enough hot air to keep the tank from freezing at 15 degrees F. Skip the heat pads. If the have a problem they tend to get a hot spot and can melt a hole in you tank. Your TV may not be able to keep up with the energy used by heating pads.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 06-20-2009, 02:51 AM   #12
fr8tshaker's Avatar
Oops!
2004 Ford F350 PSD
Hensley Arrow Hitch
Old 06-20-2009, 02:53 AM   #13
fr8tshaker's Avatar
Andy,
Good point.
Just curious as to why do alot of RV sites and publications give instructions on how to build boxes with insulation and light bulbs, etc. to prevent the drain lines from freezing?
We always close our lines after emptying.
We disconnect the Sewer Solution and put it away after draining any remaining water in the hoses when in low temps. Maybe some don't.
'shaker
2004 Ford F350 PSD
Hensley Arrow Hitch
Old 06-21-2009, 10:16 AM   #14
york , Pennsylvania
air or 12 tank heaters
In deciding on which airstream to purchase, I notice some have 12v tank heaters other have heater air to the tanks. I'm asking those that have either of these systems which they prefer, the pro and con of each type. This will help me decide which model to get. Thanks
Its getting warm out....I need A/C Bearmechanic Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-04-2009 09:03 AM
Like it warm we when get there! Kansas65TW 1959-69 Tradewind 7 10-07-2008 02:47 PM
How warm should I be ? B4WEDI 2006 Bambi - all models 39 02-04-2007 12:22 PM
Need help staying warm! dickwhite1 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-09-2006 11:40 PM
Warm Welcome hantri Member Introductions 3 02-23-2006 05:59 PM
