Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living > Winter Living
Old 06-21-2009, 10:25 AM   #15
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Originally Posted by cpaharley View Post
In deciding on which airstream to purchase, I notice some have 12v tank heaters other have heater air to the tanks. I'm asking those that have either of these systems which they prefer, the pro and con of each type. This will help me decide which model to get. Thanks
Both require battery power/shore power to operate. The forced air requires that the furnace be left on which means you need LP and 12volt power. Tank heaters keep the tanks warm, but won't do much if anything for pipes, the furnace does.
Many people prefer not to tow with the furnace on (I don't have a problem with it as long as it is shut off prior to refueling the TV) Nothing is nicer than to step into a warm dry trailer on a miserable near freezing day for a quick nap when on the road.
FWIW I am in the process of rebuilding my trailer and am considering adding the 12volt heaters to my tanks as a backup measure.
Aaron
WBCCI #2449 AIR #2495
Old 06-21-2009, 11:59 AM   #16
Commercial Vendor
Profile:  Corona , California
Airstream never install 12 volt heaters, for the holding tanks.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-21-2009, 02:05 PM   #17
doug&maggie's Avatar
Profile:  Normal , Illinois
Hmmmm---we have a tank heater in our 06 Interstate-----it does run off the battery, I believe. Not so?
li'l moose
The more you know, the less you need
doug&maggie is offline   Reply With Quote
Old 06-21-2009, 09:19 PM   #18
Profile:  Currently Looking...
york , Pennsylvania
If you read the specs, some models have hot air tank heating and some have plain tank heaters, here is the quote for the 2009 flying cloud model: "Heated Tanks -12 Volt"
cpaharley is offline   Reply With Quote
Its getting warm out....I need A/C Bearmechanic Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-04-2009 09:03 AM
Like it warm we when get there! Kansas65TW 1959-69 Tradewind 7 10-07-2008 02:47 PM
How warm should I be ? B4WEDI 2006 Bambi - all models 39 02-04-2007 12:22 PM
Need help staying warm! dickwhite1 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-09-2006 11:40 PM
Warm Welcome hantri Member Introductions 3 02-23-2006 05:59 PM
