Old 08-13-2018, 11:50 AM   #1
Magnet18's Avatar
Churubusco , Indiana
Hydronic Heating
Hi all,
My wife and I full time in our '83 310 class A motorhome
We will probably be in the Midwest until AT LEAST the end of the calendar year
Before winter comes around, I plan to insulate the floor from underneath, (motorhome, easy) and also install a heated floor. (In addition to electric heaters on all the potentially freezy water systems)
I have seen a lot of talk about electric radiant heat installs, but not as much about doing a hydronic heat install, other than I have seen it done on a couple high dollar renovations.
Apparently a company called aqua-hot makes hydronic heaters specifically for RV use, but I can't find a whole lot of information or feedback on them, has anyone used them? Does anyone have more information?
Seems like it could be a good way to boondock or provide an additional kick of heat during the winter, but I could see it being a pain to install if you have a belly pan to deal with
Magnet18 is offline   Reply With Quote
Old 08-13-2018, 02:29 PM   #2
Magnet18's Avatar
This is the system that has piqued my interest
http://www.aquahot.com/products/RV/250P.aspx
http://www.aquahot.com/files/product...Sell_Sheet.pdf
http://www.aquahot.com/files/owners_...TE-300-000.pdf
http://www.aquahot.com/files/install...nual-REV-C.pdf
My concern would be, how much propane is this thing going to chug through to heat a floor?
Of course, energy conservation says it should be at least as efficient as the furnace, hopefully quite a bit more.
1983 Airstream 310 Class A Motorhome
-Rob
Old 08-16-2018, 02:57 PM   #3
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
I’m interested too. This looks like the Alde system. We had an Alde in our T@B and found it to be great heat. Quite and dry. I’d love to hear about anyone having done a retrofit on a trailer!
Llittle54 is offline   Reply With Quote
Question about Tank Heating Duct and Bath Heating Register KJRitchie Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-15-2017 07:36 PM
Hydronic Heating Startup and Review rheiniger General Repair Forum 13 07-27-2016 07:57 AM
Underfloor hydronic heating. DaytonaDan Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-17-2016 01:04 PM
Problem with '84 345 with hydronic heating!! joe gooch Member Introductions 5 03-04-2009 08:06 AM
