Old 04-03-2013, 08:29 PM   #43
Columbus , Ohio
Seems to me that aluminum is a soft metal. That after time the body panels will develope gaps that will eventually leak and let in cold air and start to leak.
Probably if you bought a new AS and moved it one time onto a permanent RV lot. Then did not move it would last 75 years maybe more. But towing anything will cause things to loosen up. It is just the way things work.
tuffr2 is offline   Reply With Quote
Old 04-03-2013, 09:37 PM   #44
1972 31' Excella 500
Mount Vernon , Is For Lovers
Welcome to the Forums ! Great 1st post and those pics are worth a thousand words to anyone contemplating insulation upgrades.
Sylver Slypr is offline   Reply With Quote
Old 05-30-2013, 01:28 PM   #45
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
I heat a 6 by 16 greenhouse that is aluminum and plex in the winter to 80 degrees easly with a old fashion electric oil filled heater. Looks like the old steam heater coils. Has anyone who is plugged in try one of these?
beetlebob is offline   Reply With Quote
Old 05-30-2013, 01:36 PM   #46
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this is what we use.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-30-2013, 03:19 PM   #47
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
We use the oil filled, like you describe, in our 31' Sovereign. Works for us. But we usually don't go if it is going to get below about 40 degrees outside. I hate propane in an enclosed space. Especially if you bounce it up and down the road for forty years and then use it while you sleep.
Cheers bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 05-30-2013, 04:00 PM   #48
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The effect of the already meager insulation is further damaged by the aluminum channels. See this article for details.
Old 11-24-2013, 11:34 AM   #49
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
For the Street Rod community, a product called Lizard Skin is available. One type is for sound deadening and another is for insulation. Both are a spray in material and they can be used together. They are sprayed on just a couple of mils thickness and have been proven very effective to deaden road noise and insulate the interior of vehicles. Might be worth looking into for your AS.
http://m.lizardskin.com
tsunami is offline   Reply With Quote
Commercial Airstreams? Roadrunner Airstream "In the News" 1 12-20-2011 07:26 AM
Where have all the Airstreams Gone? joe hall On The Road... 79 12-11-2011 06:10 PM
Question regarding cold/waste water tanks on Argosy's and similar vintage Airstreams. Rick F General Motorhome Topics 5 09-13-2011 06:37 PM
