Old 01-28-2013, 05:52 PM   #15
Columbus , Ohio
Are any A/S trailers considered 4 season? I am asking about 2007 or newer. Is a Sport less insulated than an International or is a Classic the best insulated or are all A/S 2007 to new insulated all the same?
tuffr2 is offline   Reply With Quote
Old 01-28-2013, 07:14 PM   #16
2013 28' International
Bozeman , Montana
Although I'm still new at all of this from everything I gather they are more like a 3 1/2 season trailer, not the best for super cold temps. I also believe the insulation is the same across all the current models. They did switch to the ecobatt insulation in 2013 from fiberglass but I don't think it changes the r value. The ribs do transfer cold from the out skin to the inner. Also, the windows are single pane glass. That being said, there are people using them in the winter and the newer ones do have heat ducts around the water tanks. Hope this helps.
HeadWest is online now   Reply With Quote
Old 01-28-2013, 07:39 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Our '65 Caravel does not seem to be very well insulated. Rain is loud. Fortunately, the A/C and heat work well enough to keep comfortable in all weather.
Our '83 Excella is insulated very well. We never hear rain unless it is really coming down hard. We were in a freak freeze at South Padre Island, with 1/2" of ice all around and ice cycles hanging on the trailer and the furnace kept is cozy and warm without running itself a lot. When we shut the door, most outside noise is gone. The walls are covered with vinyl down to the bottom of the windows, and a carpet material the rest of the way to the floor. That was factory installed. Love it.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 01-28-2013, 08:17 PM   #18
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Jim, sorry to digress. My avatar shows my long gone 1947 British competitor to the US 47 Chev. Mine could tow a load of sticks to the fire pit. Morris 8.
Jim Flower is offline   Reply With Quote
Old 01-29-2013, 09:15 AM   #19
Columbus , Ohio
Headwest - thanks for the reply and good useful information. 3 1/2 season would be fine as I never plan to winter in the northern tiers of the country. But will probably get stuck when the cold spells hit the middle of Florida, S. Texas or S. Arizona. The colderest I have been in was 19 degrees for a few hours last year in Florida.
Again thanks
Old 02-02-2013, 12:40 PM   #20
1996 28' Excella
Mobile , Mississippi
I just left NJ, been there 3 months working hurricane Sandy in my 1996 28 footer.
I had included Electricity, so I ran one space heater in the front, and one in the back.
This was fine till it hit the mid to low teens.
Then I needed to turn on the gas heat.
This is without doing anything to insulate the window other than drawing the curtains.
Nomadic1 is offline   Reply With Quote
Old 02-02-2013, 12:57 PM   #21
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I am planning on using some Reflectix insulation from Home Depot inside all the cabinets, lockers and ceilng. I will cover the insulation on the ceiling with vinyl. Dont know if it will help much, but couldn't hurt. The photo is from a 60s AS.
Lumatic is online now   Reply With Quote
Old 02-02-2013, 02:59 PM   #22
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Any idea on how the ceiling vinyl is held up? I am still planning to use a layer of reflect-stuff, a layer of 1/2 inch blue or pink foam, and a layer of some sort of paneling from the floor up to about 48". Like wainscoating. The vinyl/reflect combination looks like a good way for the ceiling. Along with a white rubber roof and high darkening film on the windows. Maybe it will stay warm or cool at appropriate times. (Of course, after I redo the floor, re-wire and replumb. Oh... and install new axle and new tires.)
Cheers,bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 02-02-2013, 05:26 PM   #23
Lumatic's Avatar
1993 34' Excella
Images: 16
Cheers,bill b.
My upholstery guy said upholstery snaps. I don't think I will try and simulate the square lines but use the snaps in a square grid.
Old 02-02-2013, 07:04 PM   #24
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Sounds about right. I rode in an old Air Force C-47 that had been insulated in that way once, long ago. If I recall correctly that aircraft was built a lot like an airstream. And probably got an insulation upgrade when they decided to use it to carry people. It had some sort of button like holders, so I am guessing that upholstery snaps in a square pattern would look good. The inside was covered completely and was more puffy appearing. Maybe thicker fiberglass insulation.
Bill b.
Old 02-03-2013, 09:29 AM   #25
Wild-Air's Avatar
2012 25' FB Flying Cloud
Minden , Nevada
It has been my experience this winter that the walls radiate cold. My solution has been the use of Reflectix (same as Prodex) against the windows on the inside. That was step one and it helped a lot.
Step two was to make covers for the ceiling vents from the same material.
Step three was to temporarily apply the Reflectix along the head of my bed using 3M Blue tape. I really don't want to mar up the interior with permanent "fixes", though I have thought of drilling out rivets and installing the Reflectix in the ceiling.
Russ
Wild-Air is offline   Reply With Quote
Old 02-03-2013, 09:33 AM   #26
Wild-Air's Avatar
Minden , Nevada
Rather than paint that rubber coating stuff on the roof, consider using Super Therm paint. It has very effective insulating qualities which the rubber doesn't have. It's white and easier to work with.
Russ
Old 02-03-2013, 10:10 AM   #27
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
Our "cocoon" remains warm in the winter with the furnace and an aux. heater in the LR as needed. The only significant problem is water condensation on the windows--addressed elsewhere. Our AS is much quicker to heat ( about 3 minutes) than our well insulated Fifth wheel and stays warm much longer.
I have read that those who live in very cold temps, skirt their AS, and run the heater often to protect the tanks and plumbing.
We have experienced freezing of the hose from the water source in cold temps, but this could obviously be resolved with heat tape.
All in all our AS seems to be well insulated. As stated above, it's probably a 3 season unit, and stretched to 3.5 with proper insulation. BTW, we once lived in Wyoming, and saw temps into the -50's.....!!!!! Zigi
Zigidachs is offline   Reply With Quote
Old 02-03-2013, 11:11 AM   #28
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, we have camped in freezing temperatures several times and had the frozen water hose to prove it. We use a small oil filled heater and our furnace. Our Safari has small windows, vinyl headliner, and mouse fur walls, this helps insulate our trailer better than some other models. Two big problems were air leaks at the door, which I fixed be adding a second weather seal around the door opening frame and the storage compartment door, which I installed a double seal around the door itself.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Commercial Airstreams? Roadrunner Airstream "In the News" 1 12-20-2011 07:26 AM
Where have all the Airstreams Gone? joe hall On The Road... 79 12-11-2011 06:10 PM
Question regarding cold/waste water tanks on Argosy's and similar vintage Airstreams. Rick F General Motorhome Topics 5 09-13-2011 06:37 PM
